Toymods » Tech & Conversions » 7A-FE ?
Alchemist
icon5.gif  7A-FE ? Tue, 18 February 2003 05:28 Go to next message
Heya guys,
Just wondering what the specs on a 7AFE were, so far I know its a 1.8L 16V EFI inline 4 but I was wondering if it was DOHC and what sorta kW we were talking on this? Its outa a bog standard '95 Rolla.
Ta,
wilbo666
Re: 7A-FE ? Tue, 18 February 2003 10:21 Go to previous messageGo to next message
Yep 1.8L, the "F" stands for economical (narrow) twin cam head / cam design ("G" stands for performance DOHC design / cams) Toymods has some good Tech articles if people look at them.
Bore and Stroke 81x85.5 mm
Power 85 KW
Torque 154 Nm
More on the 7AFE here
[Updated on: Wed, 19 February 2003 01:48]
Johnny
Sydney, OZ
Re: 7A-FE ? Wed, 19 February 2003 01:46 Go to previous messageGo to next message
I think Wilbo means 1.8L (1762.5cc)... If you search the forums, there should be a heaps of info on what can be done with them, or email me direct, I can give you a run down of what I run and have done with them so far.johnek@ozemail.com.au
wilbo666
Re: 7A-FE ? Wed, 19 February 2003 01:48 Go to previous messageGo to next message
Yep I do..silly me..doh!
Alchemist
Re: 7A-FE ? Wed, 19 February 2003 12:23 Go to previous messageGo to next message
Thanks mate, that sites got lotsa good info on it. Its actually a really sweet engine to look at Razz doesn't go too hard, but stock its just neat and stuff Smile
wilbo666
Re: 7A-FE ? Wed, 19 February 2003 13:40 Go to previous messageGo to next message
Yeah they are not that bad an engine, but the 4AGE head design is a little better in terms of making power but that said the 7A gets a little more torque than most of the 4A's due to its extra size so it is good for the later Rolla's as they got quite porky!
The 7AGE is a VERY interesting kettle of fish!
Johnny
Sydney, OZ
Re: 7A-FE ? Thu, 20 February 2003 00:00 Go to previous messageGo to next message
you mean like this one Very Happy http://members.ozemail.com.au/~tazlk/7AGE.jpg
I've got to upload the new pic's of it together and finished! Just waiting for ECU and fitting to the donar car.
For a 7AFE, the best I got so far is 70Kw@wheel's, but I'm waiting for the new engine to be dynoed, to see if It'll pass this, ATM it feels like it does have a heap more grunt and it's still tight, so it will be interesting once it's run in.
wilbo666
Re: 7A-FE ? Thu, 20 February 2003 01:16 Go to previous messageGo to next message
Hey Johnny can you tell us a bit about your setup?? Smile
Did you use 4A pistons, 4A or 7A rods?, 7A crank obviously but did you prep it in anyway? and also what did you use for the timing belt? Also what did you set the redline at and are you using aftermarket management? Looks like a bigport head, what made you decide to use the bigport, do you think the smallport / 20v would be better? Stock 4A injectors?
Sorry for the barrage of questions!
Looks pretty nice man Smile , does it feel like it has a fair bit of torque? Very Happy
Johnny
Sydney, OZ
Re: 7A-FE ? Thu, 20 February 2003 02:57 Go to previous messageGo to next message
Firstly, this is a trial engine, so everything is pretty much left as standard. The bottom end is a completely standard 7A Item except the 4AG pistons and crank timing gear. The head is a small ported, mildly ported, dual valve springs with Big port cams (higher lift and duration) and verniers (from Damo), though these cams may change for a custom grind. Porsche 944, 928 are a bad fit, the 944 is perfect. Few other minor mod's are needed as well that involve the water pump and casing. So far, this engine hasn't be run and is going into a street drive car, the Rev limited will be decided once it's on the dyno. The 7AFE that is raced, is a totally different kettle and it has a redline of 7,500, runs forged everything. This bottom end and a GE head is on the books at a later date, more or less after I replace the current 7AFE with a works 20V.
wilbo666
Re: 7A-FE ? Thu, 20 February 2003 03:15 Go to previous messageGo to next message
Wow some good info there for anyone wanting to go 7AGE!
Shocked Smile
Johnny
Sydney, OZ
Re: 7A-FE ? Thu, 20 February 2003 03:40 Go to previous message
Forgot to mention that the piston's on a 7A are an interference fit and a 4AGE piston uses a floating fit.... you can either use convert the 7A rod to a floater or the 4AG pistons to allow and interference fit, the floating is the better choice.
Previous Topic:Help : No dash and rear driving lights
Next Topic:Electronic Speedo
Current Time: Sat Nov 21 10:58:17 UTC 2026
Total time taken to generate the page: 0.0073540210723877 seconds
