Toymods » Tech & Conversions » What size wheels to fit over 323mm supra discs?
benmeyer
What size wheels to fit over 323mm supra discs? Wed, 19 February 2003 13:03 Go to next message
anybody know what size wheels you need to fit 323 mm discs of a JZA 80 supra? theyre going into my ST162 with the 3sgte transplant.
thanks in advance
bergerac
Re: What size wheels to fit over 323mm supra discs? Wed, 19 February 2003 15:28 Go to previous messageGo to next message
Id say at least 17's since there is about 3mm gap between the calipers and the 16's on the ST205 and that has 315mm discs. Sorry cant tell you exactly though.
Re: What size wheels to fit over 323mm supra discs? Wed, 19 February 2003 20:03 Go to previous messageGo to next message
Depends on the wheel and what calipers you want to run. If everything is favorable, then 16's. Otherwise 17's.
ed_ma61
Lost in the K hole
Re: What size wheels to fit over 323mm supra discs? Wed, 19 February 2003 22:11 Go to previous message
what calipers are you using? dpending on the profile of the caliper, you may get under a 16". for ref, one 16" wheel im looking at has an ID of 383mm at the hubface, 397mm at the rear edge. thats JUST big enought to squeeze in a 310mm rotor with a toyota sumitomo st205 caliper.
is youre using the supra mkiv calipers, i suspect youll need to go 17" ive seen these under the stock toyota 17's and there aint much room!
ed
Previous Topic:Electronic Speedo
Next Topic:AE86 tacho signal
Current Time: Sat Nov 21 10:40:41 UTC 2026
Total time taken to generate the page: 0.0051360130310059 seconds
