Toymods » Tech & Conversions » Brake upgrade for MX83
biased99
Brake upgrade for MX83 Wed, 19 February 2003 21:54 Go to next message
I need to know what kind of options there are for upgrading my brakes...
For example, would a set of 330mm Supra Rotors bolt up to an MX83? is the PCD the same (114.3 X 5)?
Are these brakes readily available around the place, and are pads easy to get? How much are they likely to cost?
Also, what about rear brakes? I'd like to scrap the OEM solids for some ventilated units (from a Soarer, perhaps). What is likely to be involved here?
I am fitting 17" rims today, so space shouldn't be a problem...
Any advice would be appreciated, as my current brakes are inadequate...
Re: Brake upgrade for MX83 Wed, 19 February 2003 22:17 Go to previous messageGo to next message
I suspect you're on your own a bit here. The Cressi and Supra PCDs are the same.
For the fronts, your problem will be the rotor height. The relative heights of the rotors is quite different. 323 mm Supra rotor is 18mm lower than the Cressi height - this might result in the caliper clashing with the back of the wheel. You'll need to scout around with some Verniers and measure things up. Whatever you end up doing you'll definitely need a caliper bracket made up. I suggest you look outside Toyota for some more adequate rotors (DBA catalogue).
For the rears, your limiting factor will be the internal drum handbrake diameter, which I think will be 190mm on your Cressi. MA70, JZA80, xZ20 onwards Soarers all have 190mm internal drum handbrakes, so they will have suitable rotors for you. The next problem will be rotor height and they all about the same. No idea if the calipers will bolt up to the std caliper mounts - you'll have to measure all this up with Verniers, or suck it and see!
Depending on what mix of calipers you end up using, you'll find you have upset the braking balance. You may end up needing to run some sort of adjustable proportioning valve.
biased99
Re: Brake upgrade for MX83 Wed, 19 February 2003 22:35 Go to previous messageGo to next message
Hmmm...O.K.
What about Mark 2 or Chaser brakes? (These should be closer?)
Of course, it comes down to availability...
rob_RA40
c'town, NSW
Re: Brake upgrade for MX83 Thu, 20 February 2003 01:10 Go to previous messageGo to next message
upgrading the rears will be overkill
Southo
Re: Brake upgrade for MX83 Thu, 27 February 2003 01:44 Go to previous message
Give Pittwater Brake and clutch a call, (they have banner ads running on the forums here)
I too am going the 330mm Rotors on my MX83 (preparation for 2JZ) and these guys were most helpful
Slotted Rotors were about $250 each - BRAND NEW
Calipers were about $50
As soon as I can find some 17's that are subtle enough - I'll be getting mine done.
*Edit* Pittwater Brake and Clucth at Narrabeen, not Narrabeen brake and clutch..
anyway - look for their banner ad on these forums
[Updated on: Thu, 27 February 2003 02:11]
Previous Topic:Good welder for diff conversion - Melbourne
Next Topic:AE101 GZE fuse box
Current Time: Sun Oct 18 01:16:39 UTC 2026
Total time taken to generate the page: 0.0060179233551025 seconds
