Classifieds » Engines, Accessories and other Mechanicals » E58 LSD Gearbox + 4AGE Motor +other parts.
sikmr2
E58 LSD Gearbox + 4AGE Motor +other parts. Thu, 20 February 2003 02:25 Go to next message
Ive got an E58 gearbox from an AE101 levin GTZ. Any offers over $450
Complete 86kw 4AGE motor with AFM, wiring loom and ECU. $850. Was still going hard when i had it in the MR2, not blowing smoke and not burning any oil. No nasty noises.
Also radiator from Levin and air con condensor.
Power steering pump, from 4agze.
GZE flywheel and clutch assembly.
Also im in Adelaide, so pick up is a must.
nos4ag
Re: E58 LSD Gearbox + 4AGE Motor +other parts. Fri, 21 February 2003 08:13 Go to previous messageGo to next message
just curious mate, how many k's on the 4AGE? Are there any drive shafts with the gearbox? Cheers Mate
Regards NOS4AG!
nick.parker
January 2005
Re: E58 LSD Gearbox + 4AGE Motor +other parts. Tue, 25 January 2005 13:37 Go to previous messageGo to next message
Why didn't you use the E58 in your MR2? I am trying to find out if there are any issues with doing this. Do all E58's have LSD?
Cheers, Nick
AW11 SC
mr2gze
Re: E58 LSD Gearbox + 4AGE Motor +other parts. Thu, 27 January 2005 07:28 Go to previous messageGo to next message
I believe the e51 has the linkages on the other side to the e58. Its not a simple bolt off e51 and bolt onto e58 either, as the actual casting on the case is the opposite, fairly sure thats right. Thats not to say it isnt possible to use the e58 in the aw11.... its been done. Not all e58's have lsd, the last digit must be odd, or c, in the trans code e.g. e58-11c is lsd, e58-474 is open, there is a thread somewhere on here
Also interested whether you have the shafts with the e58 sikmr2?
cheers shane
TerryOBeirne
Redbank Plains,near Ipswi...
Re: E58 LSD Gearbox + 4AGE Motor +other parts. Thu, 27 January 2005 21:58 Go to previous message
Correct, the gearbox cases are different MR2 to Corolla and cant be easily swapped. I have cash for the g'box if it definitiely has a LSD in it and you have axles. do you have the code off the car build plate??. PM or email me at work ASAP roadandtrack@hypermax.net.au. thanks
Previous Topic:100 KW 4age for sale
Next Topic:JZA70 cooler
Current Time: Sun Nov 22 01:04:12 UTC 2026
Total time taken to generate the page: 0.0059049129486084 seconds
