Toymods » Tech & Conversions » Do any shops make toyota camshafts?
BlackSupra
Do any shops make toyota camshafts? Fri, 21 February 2003 02:21 Go to next message
Looking for a list of cam shops that do actually work with toyota cams, not just if its required, semi specialists.
ta Smile
[Updated on: Fri, 21 February 2003 02:22]
BlackSupra
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 07:56 Go to previous messageGo to next message
ok more to the point, im looking for 5mge inlet and outlet cams in blank form ie. not yet had lobes cut.
Rolling Eyes
CelicaRA45
nth ringwood, Victoria
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 09:35 Go to previous messageGo to next message
may be back in 1985 when they were racing them ,why dont you get them hard faced
BlackSupra
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 11:02 Go to previous messageGo to next message
explain hard faced? as in machined from billet?
i have hks specs but the lift is larger than stock, and thus require blanks. Rolling Eyes
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 13:10 Go to previous messageGo to next message
Get someone to weld up the lobes and get your HKS grinds put on the lobes.
Any half decent cam place can do this. Will set you back 5-600 though.
Definitely won't be able to get new billet 5MG cams today. Like Glenn said, maybe in 1985.
ed_ma61
Lost in the K hole
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 13:17 Go to previous messageGo to next message
glen,
dont need 'blanks' ...
get your cam lobes welded up with new material, and then regound back to the spec yopu want. damn twincam engines (though youve only got 12v) youre prolly looking around the 1000 mark Razz
and in reply to your PM the other day...
eds list of easy performance DO's
shave head as much as you can without hitting vlave/piston fouling limits, and then get adj cam gears. get your comp/r up as much as you can (assuming you cant get pistons).
do a decent port job on the head. also polish the piston domes and comb chambers to make use of the higher comp with BIG advance Smile
get the bottom end balanced and blueprinted
get a lightened flywheel (cromo)
theyre prolly the simplest things you can do that will yield decent results.
wtf happened with your mum dude!!
ed
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 13:47 Go to previous messageGo to next message
Oh and get a machinist to mill 1-2 kg off your crank dude.
Send me an email and I'll send you a short list of cam people in Australia.
kingmick
Banned by his request
moved to tamworth
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 22:26 Go to previous messageGo to next message
we can do your cams just give me a ring on 9820 4255 on tuesday and ill chase them up for you.
mick
CelicaRA45
Re: Do any shops make toyota camshafts? Sat, 22 February 2003 23:46 Go to previous messageGo to next message
you also will find toyota race cams are made for all the twin cams they use the same profiles from 2tg to 7mgte from 256 duration to 320 duration it just depends on the cam lift and how hot you wont to go i am running 304 duration and 535 thou lift cams in my 3sge motor ,and daves 2jze has 304 and 290 duration cams in his motor
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 01:12 Go to previous messageGo to next message
CelicaRA45 wrote on Sun, 23 February 2003 10:46
...and daves 2jzge has 304 and 290 duration cams in his motor
Actually, they're both 304 duration 435 lift Glenn.
CelicaRA45
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 01:28 Go to previous messageGo to next message
no dave he made them different remember
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 01:42 Go to previous messageGo to next message
Yeah he did but he got them the wrong way around, so just got the small one made lumpy. Now they're both the same.
BlackSupra
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 07:55 Go to previous messageGo to next message
well this is a street car, not a race car or custom drag car.
i beleive the duration is 284 for the hks cams but i just realised i cant seem to read the writing because the photo is too small!
This is not too little, not too much?
Gianttomato - how heavy is a crank if u can take off 1kg?
ed - 1 supra interior + extractors in dads workspace + 1 engine on the back of dads hilux + misc. parts in my room = mum having a snap at me Shocked
dad was going on about boring out the block and running oversize rings. Is this a safe way to do this? the gain is all of 75cc i think, but is this going to put more strain on the engine or perhaps create piston slap?
ta, Glen
[Updated on: Sun, 23 February 2003 07:57]
7mgte83
Barossa valley SA
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 08:36 Go to previous messageGo to next message
All sounds pretty complicated man, before you go spending shitloads of money remember that the 7mgte is an easy and reasonably cheap conversion into the MA61.
just an idea Smile
BlackSupra
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 09:17 Go to previous messageGo to next message
one also must remember i give myself a 50% survival rate if i drove that thing
and the car wouldnt have a chance.
gimmie a few more years experience, get some decent n/a hp first then apply that to a boosted engine.
The first day it rains with a 7mgte id be into a pole.
p.s oh yeah id love one like all hell, but refer to point 1
[Updated on: Sun, 23 February 2003 09:19]
BlackSupra
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 09:31 Go to previous messageGo to next message
got the full size pic now of the specs.
www.geocities.com/ifli4u/camspecs.jpg
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 10:04 Go to previous messageGo to next message
OK dude. Email me.....I will supply you with a short list of cam grinders in Australia. You then tell them the cam specs you want, and they can tell you what they have. They may not have exactly that grind, but they will have something similar.
Tighe Cams have over 5000 different grinds.....surely they'll have something close.
Important numbers for that grind are 284 degrees duration, 230 thou lift (at the cam, rocker ratio 1.5), and 220 degrees duration at 50 thou lift. This is what the cam guys will ask you.
Just wondering where you got those specs? If you got them from a cam shop, they will probably have the profile too.
Re: Do any shops make toyota camshafts? Sun, 23 February 2003 23:28 Go to previous messageGo to next message
BlackSupra wrote on Sun, 23 February 2003 17:55
I struggle to lift a 7M-GTE double-counterweighted crank off the ground. The 6M crank is not quite as heavy (single counterweights) but still weighs heaps. You wouldn't have to try hard to shave 1kg off something like that.
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 04:03 Go to previous messageGo to next message
Those 4 and 5M cranks weigh well over 20 kg (possibly even 30ish). I can't even fathom what a double counterweighted 7M crank must weigh.
It'd actually be pretty easy to whip off 2kg no probs.
ed_ma61
Lost in the K hole
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 05:14 Go to previous messageGo to next message
you friggin BIG GIRL'S BLOUSES!!
hehehe, seriously, yes the double counterweight crank is heavier than the single, but not by much. not much at all. never weighed them on scales, but to the hand, there's not THAT much in em.
i mean, its all of 2 counterweights different (pistons 2 and 5), and if you look at where the counterweights 'would' go on the single counterweight model, its pretty beefy anyway. so not that huge an addition.
that said, whilst norbie, you are a big girl for not being able to pick em up off the floor, they are very heavy Smile
GT - whats the milling worth? in ballpark terms??
Glen - the weight lost off the counterweight wont so much give you abs power, but will improve throttle response. that said, itll have less angular momentum, so the engine wont be as smooth, and will feel a little on/off...
ed
BlackSupra
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 05:23 Go to previous messageGo to next message
Surely if the milling was balanced this wouldnt happen?
ed_ma61
Lost in the K hole
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 05:32 Go to previous messageGo to next message
balanced just means it wont have harmonic vibrations etc.
but, if you mill your counterweights, the crank weighs less at its periphery, which means it has less angular itertia (making it easier to get spinning) but also has less angular momentumn once spinning (more easily slowed down).
so good throttle response, but back off the loud pedal, and the engine will slow down more quickly too.
ed
BlackSupra
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 09:29 Go to previous messageGo to next message
Like how bad are we talking here when one backs off?
as in noticeable over stock but not annoying?
compared to perhaps revving out 3rd quite high down a slight slope instead of changing to 4th and having a large amount of engine braking slowing you down right away?
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 10:19 Go to previous messageGo to next message
Around 300 for the milling.....pulling my crank out on Thursday night and going for broke.
Almost no difference in smoothness if it's balanced (as it must be) if all other things are equal.
[Updated on: Mon, 24 February 2003 10:29]
Re: Do any shops make toyota camshafts? Mon, 24 February 2003 13:14 Go to previous messageGo to next message
I rand wade cams a while ago, they said they'd make cams for my 4ag for about $220 each new from blanks, at that price I really wouldn't want to go messing with welding the buggers!
Re: Do any shops make toyota camshafts? Tue, 25 February 2003 00:03 Go to previous message
mrshin wrote on Tue, 25 February 2003 00:14
......from blanks,......
Michael, have you tried sourcing these for a 5MG? Very Happy
Unobtainium nowadays, so welding up lobes is his only choice.
Previous Topic:Standard Oil Filter for GT4 Grp A (ST185)
Next Topic: new instrument surround
Current Time: Sun Oct 25 00:40:11 UTC 2026
Total time taken to generate the page: 0.0077228546142578 seconds
