Classifieds » Miscellaneous » FS: SW20 MR2 driveshafts
CeLiCa
FS: SW20 MR2 driveshafts Sat, 22 February 2003 11:43 Go to next message
Ive purchaced a set of MR2 turbo driveshafts because i needed the inner ends that connect into the gearbox. I payed $270 for the set. I have no use for the rest of the shafts which is pretty much the entire thing minus the inner end that goes into the gearbox and then bolts into where the CV's are. This is ideal for someone that has stuffed CV's and is looking for a replacement. All you do is bolt it straight onto your current inner ends.
Considering they go for around $300 for a set normally and they are pretty much complete im asking for $150 for both driveshafts. They have been used for 40000km and are in great condition.
[Updated on: Sat, 22 February 2003 11:45]
wagonist
Toymods Club Treasurer
Re: FS: SW20 MR2 driveshafts Mon, 24 February 2003 05:44 Go to previous messageGo to next message
Can you get photos?
I'm looking at putting these shafts onto my car as I have the unequal length ones, so I get huge torque steer.
So, what's left is the outer shaft & CV, the next shaft, & then what?
Are you able to measure from where the shaft comes out of the box to where the bearing bolts to the block, I'd like to see if I have the holes on my block to see if they'll fit up.
CeLiCa
Re: FS: SW20 MR2 driveshafts Mon, 24 February 2003 13:15 Go to previous messageGo to next message
Basically on these driveshafts theres the bit that goes into the gearbox then an inner joint then the shaft then the outer joint then the bit that goes into the hub. I have used only the bit that goes into the gearbox and the rest i have bolted straight off and put aside... ill get measurements later
wagonist
Re: FS: SW20 MR2 driveshafts Mon, 24 February 2003 20:51 Go to previous messageGo to next message
Is the shaft that comes out of the gearbox on the long side one piece up to and including the bearing mount, or does it disassemble?
CeLiCa
Re: FS: SW20 MR2 driveshafts Wed, 26 February 2003 08:00 Go to previous messageGo to next message
The long driveshaft has 2 bits.. the long bit and the part where the cv's and stuff come off... makes both of the driveshafts the same length when inner ends are removed...
wagonist
Re: FS: SW20 MR2 driveshafts Wed, 26 February 2003 20:54 Go to previous messageGo to next message
You've used the long part of the driver's side shaft then?
Do you still have the old bits?
I also need measurement of diameter of the spline that goes into the gearbox.
CeLiCa
Re: FS: SW20 MR2 driveshafts Sat, 01 March 2003 06:27 Go to previous message
Yeh ive used the long piece on the drivers side... whats left is part where the two CV's are and the thing that goes into the hub
Previous Topic:Laptops for sale- good prices!
Next Topic:GTR Intercooler PRICE REDUCED
Current Time: Fri Oct 16 22:06:43 UTC 2026
Total time taken to generate the page: 0.0049610137939453 seconds
