Toymods » Tech & Conversions » cam grind and bucket/shim assembly ...
ed_ma61
Lost in the K hole
cam grind and bucket/shim assembly ... Sun, 23 February 2003 09:45 Go to next message
ok, time for ed's dodgy box of cheap ass ideas to be re-opened...
i would really like to get new cams to support all the headwork ive recently done, but alas, getting the cam faces welded and reground is a *tad* expensive.
so, ive been thinking how i could get away with simply regrinding my existing cams, and figuring out some way of dealing with the reduced lobe base circle dia...
so, im thinking, say i grind 2mm of the base of the cam lobe. to compensate, it seems possible that i could whack an *extra* valve shim UNDER the bucket, thus pushing the whole bucket assembly out of the hole some 2mm. as the etra shim would be about 3mm thick, i'd also have to grind the valve stem down some ~1mm to make all the clearances correct spec.
give the rest of the cam grinding id, be doing, i cant imagine id be increasing lift to over 8.8mm or so, and the profile wont be to steep, so hopefully i wont be facing shim spitting issues (for the top shim).
question is, can anyone see something terribly WRONG with this idea? is the 'under' shim going to be prone to dislodging (i cant see thats possible - its a tight fit for it inside the bucket). is it potentially BAD for the bucket to be protruding an extra 2mm? (theres still A LOT of bucket inside it bore)
heres an image of what i mean... 30k big
http://www.eds.au.com/toymods/valveshimsteup.jpg
any thoughts at ALL as to why this wouldnt work would be appreciated. as too a pat on the back for this being a potentially UN-stupid idea
ed
icon10.gif  Ed's ghetto spec high lift cams Sun, 23 February 2003 10:16 Go to previous messageGo to next message
Nice choice of colors for the pic Ed. Very Happy
Might work but will add a lot of weight to the assembly.
EDIT: A little more thinking time.....
What is the under bucket shim resting/loaded against?
Just wonder if having the bucket sitting out of its bore by 2 mm more might result in a slight increase in the bucket rocking, with greater wear/ increased propensity for the shim to spit? Just wondering...
[Updated on: Sun, 23 February 2003 10:35]
ed_ma61
Lost in the K hole
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 10:35 Go to previous messageGo to next message
**in the ghetto** (cartman voice)
it will add the weight of 24 shims, minus the weight of 24mm of valve stem Smile
hehehe, minus the rotational inertia of the cam meat removed!!
sriously, is this a completely barmy idea, or is it kinda do-able?? is there anything fundamentally wrong with grinding the base circle of the cam too btw??!!
anyway. i knew id net you in with this one!
ed
(ps - screw you and your 'colourism!')
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 10:39 Go to previous messageGo to next message
I choose to spell 'color' without the superfluous 'U'. I think I went into this at great length once......
See edited post above. Might just work, but I'd try it on something cheap, nasty and disposable like a 4AG first......... Very Happy (joke)
ed_ma61
Lost in the K hole
Re: Ed's ghetto spec high lift cams Sun, 23 February 2003 11:10 Go to previous messageGo to next message
gianttomato wrote on Sun, 23 February 2003 21:16
the underside of the bucket has a small flat 'nipple' who's machined face usually interfaces with the stem of the valve. the face of this nipple sits about .25mm proud in the roof of the bucket. the UNDER shim would sit between the machined face of said 'nipple' and the valve stem immediately beneath it.
thus, in a completely 'unloaded' situation, the shim could potentially rock ever so margianlly from side to side. i doubt this would happen thou, as the shim sits ever so snugly within the side walls of the bucket. nishad just raised this issue - re making sure the valve stem has somthing square and stable to interface with to prevent deflection of the stem during load cycles.
i could potentially use that loctie high temp, high strength epoxy to bond these UNDER shims into place (thats extreme, but an outside option none the less). i have to go see how possible it is for the UNDER shim to deflect.
thats a point. but hopefully ill be able to make a gentle, long dur, lower lift profile that can help avoid shim spitting issues.
even being 2mm extra out of the hole, there is still a LOT of bucket still in the bore. hopefullt this will resits rocking a bit. (and theyre in ex condtion atm - very little existing wear)
ed
Re: Ed's ghetto spec high lift cams Sun, 23 February 2003 12:05 Go to previous messageGo to next message
Also just wondering, with lobe being just that bit smaller, even though the profile is the same, because it's smaller, acceleration is higher so therefore a bit nastier than you might expect so maybe top shim more likely to be spat out?
No idea.....speculative....hopelessly bored at work
TA22-3SGTE
MACKAY
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 12:42 Go to previous messageGo to next message
ed
A couple of things to check out ,
(1) If you tip the valves by 1 mm make sure the valve tips still protrude above the valve retainers or the extra shim will hit on the retainers , sometimes after tipping valves the tip ends up lower than the retainer , This is normally not a problem as the underside of the bucket has that protrusion you mentioned as so the bucket and retainer still has clearance .
(2) Is there enough heel on the cams to remove 2 mm , If so would the base circle of the cam lobe still be larger than the cam bearing journal as the edge of the buckets on some heads actually sit slightly under the edge of cam bearing journal , If the cam lobe base circle is smaller the buckets will hit on the cam bearing journals .
Otherwise I can't see any problems with this setup .
Trevor
ed_ma61
Lost in the K hole
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 12:43 Go to previous messageGo to next message
i dont get why 'smaller radius, same profile' = higher acceleration. i just cant conceptualise it tabula rasa...
say ALL i did was grind the back of the lobe off, with NO mod ification to the rest of the profile. surely the ONLY bit of the lobe that produces ANY acceleration different to stock is the transition from the low base circle to the existing ramp of the active lobe. and the slope (= acceleration) of this transition section is going to be nothing compared to the acceleration and associated forces produced by the slope of the main part of the cam lobe.
acceleration is the rate of change of the velocity, ie the rate of change of the height change of the lobe profile. i cant see how a transition from the now reduced base circle compares to the rate of change in the profile of the rest of the lobe...
but bill seems ADDIMENT that its a bad idea... Razz
ed
ed_ma61
Lost in the K hole
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 12:50 Go to previous messageGo to next message
TA22-3SGTE wrote on Sun, 23 February 2003 23:42
yeahm theres plenty of meat there to remove 1mm without fouling the collets Smile
yeah, 2mm is the max i can take off. ive got one of those heads where the bucket will foul the bearing journal if it comes up too much. 2mm grind take the lobe to within 0.3mm of the journal, and then theres 0.5mm from there to the edge of the bearing journal to the actual bucket (not the shim - shim clears, i think).
the actual specifics of the grind are to be fully figured out. but just sussing the general concept for now Smile
ed
Re: cam grind and bucket/shim assembly ... Sun, 23 February 2003 14:01 Go to previous message
ed_ma61 wrote on Sun, 23 February 2003 23:43
I have to agree with him. It might just work, but I have this gut feeling it would fail early. The more I think about it the more I don't like it.
I don't like the fact the bucket is sitting 2-3mm higher, I don't like what the bottom shim might be sitting on, I don't like the extra weight you have introduced into the system, you still have the outer shim anyway with that ability to flick out, it'll still cost you plenty to have the lobes ground anyway, the rest of the money getting a normal weld and grind will go towards getting the other machining done to take valvetips off and grinding down shims to fit inside buckets, and in the back of your head is the perpetual doubt that it will fail, BADLY, such that you have to build another head properly, outlaying a second wad of money.
That's a long sentence.
Previous Topic:Removing AE86 rear bumper?
Next Topic:7m / 4age shim sizes??
Current Time: Fri Nov 20 05:59:18 UTC 2026
Total time taken to generate the page: 0.010993957519531 seconds
