Toymods » Tech & Conversions » 7m / 4age shim sizes??
ed_ma61
Lost in the K hole
7m / 4age shim sizes?? Sun, 23 February 2003 09:56 Go to next message
anyone ... anyone...
1) do they use the same shims?? they use the same OD buckets, so im wondering if they use the same shims- 7m shims are 25mm dia and are in the range of ~3mm thick.
2) what is the smallest thickness shim available? im after as close to 2mm thick as possible.
ed
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 7m / 4age shim sizes?? Sun, 23 February 2003 10:38 Go to previous messageGo to next message
My Hanes Corolla manual has a little table of available shims & thicnesses, & thinest is a number 02, which is 2.500mm.
TE72_Turbo
Re: 7m / 4age shim sizes?? Sun, 23 February 2003 12:24 Go to previous message
could you machine them thinner? surely the surface hardening is only critical on the side that contacts the cam lobe?
Previous Topic:cam grind and bucket/shim assembly ...
Next Topic:sprinter engine question
Current Time: Fri Nov 20 05:40:43 UTC 2026
Total time taken to generate the page: 0.10154700279236 seconds
