Toymods » Tech & Conversions » Carb to EFI Conversions
BansheeBuzz
Gold Coast
Carb to EFI Conversions Sun, 23 February 2003 10:40 Go to next message
OK to start things i am a qualified auto elec. I have a 95 hilux with a 22r engine. I have just about finished my carb to efi conversion on this vehicle. Only have the wiring to go. Just wanted to write this post for people who may be considering a EFI conversion. Alot of toyotas vehicle came in carb and efi versions, although this is specifically about the 22r the majority of it is relevant to other toyota vehicles and EFI conversions
The donor vehicle
Ok started by finding an old corona with the 22re engine in it. Easy enough i found an 86 model in Brisbane and got it for $600 complete and running but no rego.
The strip out
Towed the car to the gold coast on a trailer and basically stripped the car. Removed all panels, motor, gearbox, fuel tank, wiring harness, anything for the EFI and a few other bits and pieces. The shell of the car and anything else not worth keeping of selling was dropped off at the local scrap yard.
Prep work
Had a surge tank made to house the original high pressure fuel pump and mounted under the tray-back. Swapped exhaust manifolds. Striped and cleaned intake manifolds. Mounted battery into my toolbox in the tray(this had to be done to allow air filter to fit were battery lives). Mount lift pump.
Conversion
Stripped anything related to the carb off. Fitted EFI intake manifold to engine(one brake line had to be reshaped to allow manifold to fit and egr was removed), intake pipe, airflow meter and pod filter. Mount fuel filter on bracket with the modded corona steel fuel line to the tank. Mounted the injector resistor. Mounted and connected all fuel lines(from rail to surge and surge to tank.
Still to be done
wiring for air flow meter, o2 sensor, fuel pumps, coil/igniter, relays and ecu. The manifold harness was separate and that is all run.
If there is anything i can help you with please ask. Sorry for the long post but i just wanted to share this with you all. I will probably finish off the wiring over the next couple of nights and all will be done.
Pheonix
Wa
Re: Carb to EFI Conversions Sun, 23 February 2003 14:34 Go to previous messageGo to next message
could u tell me how u wired the coil/igniter once u get it done, cause im using the 22r-e coil/igniter on my 2t-geu and its causing me a lot of grief, i cant get any spark, thnks
M.W.P.
Rocky Mountains, Canada
Re: Carb to EFI Conversions Sun, 23 February 2003 14:41 Go to previous messageGo to next message
Could you explain the 22re's distributor trigger?
Its is reluctor, hall, optical wheel, etc?
Trying to work out the easiest dizzy to use on my 18r.
Thanks.
BansheeBuzz
Gold Coast
Re: Carb to EFI Conversions Sun, 23 February 2003 20:35 Go to previous messageGo to next message
M.W.P - its a reluctor type. Do you plan on using this with an EFI setup or Carb? The distributer has no vacume advance because the 22re system has electronic spark timing.
Phenoix - i will get back to you when i get to that
M.W.P.
Re: Carb to EFI Conversions Mon, 24 February 2003 03:08 Go to previous messageGo to next message
BansheeBuzz wrote on Mon, 24 February 2003 07:05
Bugger...
I was hoping it would be optical or hall Sad
Thanks.
[Updated on: Mon, 24 February 2003 03:09]
Pheonix
Wa
Re: Carb to EFI Conversions Mon, 24 February 2003 03:13 Go to previous messageGo to next message
electronic spark timing, that doesnt sound good 4 my case, that would mean a wire from the computer connects to the igniter, am i correct cause if it does ive been told to buy the wrong bits as the 2t-geu doesnt have computer controled spark
BansheeBuzz
Gold Coast
Re: Carb to EFI Conversions Mon, 24 February 2003 07:08 Go to previous messageGo to next message
Pheniox - Yes the igniter needs to be run by the ecu. You may be able to use a igniter of a 22r-c thou.
[Updated on: Mon, 24 February 2003 07:10]
ROBBO_ma61
Re: Carb to EFI Conversions Tue, 25 February 2003 11:49 Go to previous messageGo to next message
want a 5me efi system?
djmickyg
Re: Carb to EFI Conversions Sun, 18 July 2004 13:36 Go to previous messageGo to next message
hey BansheeBuzz,
I been searching the net for ages on some info on this very topic..
a few questions to start off with..
how hard was it?
(I'm a machinist by trade and i have rebuilt an rx7 b4, so i'm ur average back yard tinker that knows his way around average tools..)
how much did it cost? u said u got the car for 600 but how many other cost did u have to put out?
how long did it take?
and most importantly was it was it worth it? was the power increase noticeable and was the fuel consumption alot less?
Mick
peewee
adelaide
Re: Carb to EFI Conversions Sun, 18 July 2004 13:40 Go to previous messageGo to next message
banshee buzz last posted in january so i dunno how much luck you're gonna have there, maybe email him directly if he has his address listed
djmickyg
Re: Carb to EFI Conversions Sun, 18 July 2004 14:38 Go to previous message
hmm good thinking..
im gona do that
Previous Topic:1j cressi
Next Topic:JZZ30 Soarer - Axle Tramp
Current Time: Sun Oct 25 21:26:10 UTC 2026
Total time taken to generate the page: 0.004706859588623 seconds
