Toymods » Tech & Conversions » Microtech MT8 won't start.
pepsicola
Microtech MT8 won't start. Sun, 23 February 2003 23:47 Go to next message
anyone know anything about it, all the wiring has been hooked up, but it won't turn on as the leds on the microtech doesn't light up.
is there any tricky things about it?
Ribbo
Northern Beaches
Re: Microtech MT8 won't start. Mon, 24 February 2003 01:36 Go to previous messageGo to next message
check your earths with a multimeter, I had a similar problem with my microtech digi 1 and it was a dodgy earth.
[Updated on: Mon, 24 February 2003 01:36]
pepsicola
Re: Microtech MT8 won't start. Mon, 24 February 2003 02:20 Go to previous messageGo to next message
earth is ok.
Hachi Roku Trueno
Re: Microtech MT8 won't start. Mon, 24 February 2003 03:24 Go to previous messageGo to next message
What about ECU power? Does the fuel pump kick over?
SUPRAGTE
North Sydney
Re: Microtech MT8 won't start. Mon, 24 February 2003 23:00 Go to previous messageGo to next message
Its quite simple, the Microtech only needs 3 things to turn on.
1. Main 12v direct from battery, don't take it from any other point.
2. Negative, also run this direct to the battery.
3. 12V from the ignition switch to the IGN input on the m/tech.
Are you getting this third one?
Also your main supply to the m/tech should be fused right at the battery, is that fuse blown?
MaNGeW
Formerly TRD_RoLLa
Re: Microtech MT8 won't start. Mon, 24 February 2003 23:35 Go to previous messageGo to next message
Update:
The ECU/mt8 now powers up.
The fuel pump initiates.
The ignitor doesn't seem to work though, no spark.
juzzo84
Hornsby, N.S.W
Re: Microtech MT8 won't start. Tue, 25 February 2003 03:50 Go to previous messageGo to next message
make sure this has a very good earth, my corolla had a similar prob, NO SPARK, it was cause of NO EARTH.
JUZZO
SUPRAGTE
North Sydney
Re: Microtech MT8 won't start. Tue, 25 February 2003 07:14 Go to previous message
Is this the first time you have run the microtech?
Sounds like a few teething problems your having.
Check there is power on the positive side of the coils permanently when you turn on your ignition.
The Microtech only sinks the current from the coils. It returns the current to the battery through that main negative wire but you've now checked that and the Microtech now turns on indicating your negative is somewhat adequate.
Previous Topic:place to do engine conversion??
Next Topic:mr2 turbo conversion
Current Time: Sat Oct 24 09:57:31 UTC 2026
Total time taken to generate the page: 0.0053751468658447 seconds
