Classifieds » Parts Wanted » 5MGE bits
clubagreenie
1st street on the right
5MGE bits Tue, 25 February 2003 00:01 Go to next message
OK, need the following together or as it comes,
front engine parts, crank, oil pump and idler pulleys and front covers (both behind and in front of the pulleys) and the oil pump drive shaft.
Or a short/long motor with all this.
There is one at Pick n Payless but someone took to it with a hammer??? and smashed all the alloy bits.
ROBBO_ma61
Re: 5MGE bits Tue, 25 February 2003 11:52 Go to previous messageGo to next message
ive got a shitload of 5me parts...very similar bar head parts. Spare efi, fuel lines...pretty much everything and also a complete engine for sale...can show all working.
clubagreenie
Re: 5MGE bits Tue, 25 February 2003 13:48 Go to previous messageGo to next message
Need ge bits as I have a rebuilt ge head, do you know if the oil pum drive shaft is the same from 5me to 5mge? as me just sticks out as its chain drive and the ge is sealed behind the cam belt.
ROBBO_ma61
Re: 5MGE bits Wed, 26 February 2003 07:22 Go to previous messageGo to next message
fark difficult question...norbie?? he may know...anyway i think intake fuel lines etc r similar...clutch fans etc i have ...ask more specifically wat u want and ill let u know if ive got it.
clubagreenie
Re: 5MGE bits Wed, 26 February 2003 22:27 Go to previous messageGo to next message
OK heres what I need
1. Timing belt pulleys. full set.
2. Timing gear covers,
one behind pulleys onto engine
lower front cover (aluminium)
upper front cover (plastic)
3. Oil pump drive shaft (if different to me)
The rest are not necessary but I could finish a rebuild more completely before fitting with these,
1. 5MGE distributor.
2. Mid sump oil pump and sump.
3. Alternator, igititor/coil, inj resistor etc.
Thanks to all, if anyone knows of these in a wrecker even, let me know.
Justin
ed_ma61
Lost in the K hole
Re: 5MGE bits Thu, 27 February 2003 08:20 Go to previous messageGo to next message
AGGH dude ! i just THREW OUT a mid sump and mid sump pick up oil pump!! DO'H!!
anyway...
5me bits pretty much dont work on 5mge
oil drive shaft is different from what i recall (5me has a chain sproket, ge belt sproket, and i think they attach differently)
cam covers are all different
fuel injectors are different, manifolds are different, dizzy is different, loom is different
maybe the clutch fan will fit, but water pumps are different. pullies are all different too. not sure about acc brakets
ed
ROBBO_ma61
Re: 5MGE bits Thu, 27 February 2003 10:36 Go to previous messageGo to next message
ok well if you need aq clutch fan i have 2 in pc...replaced them with thermos. just had new fluid put in them.
BlackSupra
Re: 5MGE bits Thu, 27 February 2003 11:22 Go to previous message
i have a 6mge in pieces currently which i think ill sell off.
Previous Topic:wtd: 18R-G parts - 9.7:1 pistons, camshaft(s)
Next Topic:WTB: JDM AE86 OEM LSD clutch member components
Current Time: Tue Oct 13 06:37:59 UTC 2026
Total time taken to generate the page: 0.083235025405884 seconds
