Toymods » General Car Talk » 18RG Dipstick
Bluewire
Adelaide, South Oz
18RG Dipstick Tue, 25 February 2003 14:02 Go to next message
NEED SOME HELP
Ive got a 18RG the twin cam..Got it from USA
I had to bolt the oze 18R oil sump to it, so it fits my RA40 crossmember..
Now the dipstick hits before it gets to the bottom of the oil sump....Dos'nt get to the lowest point.
What can i do or what can i get that fitts..
Sad
crostek
Oyster bay NSW
Re: 18RG Dipstick Tue, 25 February 2003 14:24 Go to previous messageGo to next message
From what I can recall( not much these days) is the stick on the intake side of the block at the front of the block?,
Did you get supplied with the dip stick? if so check it with the original and see if it is the same.
I had a problem with the hilux where I swap the blocks and the stick hit the windage tray in the hilux sump. drilled throw windage tray and it was fine.
Also check the pick-up is in the right place in the sum!
good luck
Shane
Re: 18RG Dipstick Wed, 26 February 2003 00:29 Go to previous message
There are several locations for the dipstick, depending on whether it's a front sump or mid sump engine. Obviously you've swapped sumps so you'll need to move the dipstick to suit. I can't recall if you have to drill out the block to do this, but you should be able to see the spot where it's meant to go.
Previous Topic:ANYONE HAVE CORONA RT50 PICS?
Next Topic:ST165 GT4 - price/where?
Current Time: Thu Nov 19 18:38:48 UTC 2026
Total time taken to generate the page: 0.0095689296722412 seconds
