Toymods » Tech & Conversions » Brake upgrades (again...............)
silversup
Brake upgrades (again...............) Tue, 25 February 2003 21:56 Go to next message
Has anyone got a tech document on ta22 brake upgrades. There seems to be a lot on the 23 upgrades but not a great deal on the 22. Can I make an assumption that they are the same (or very similar)...
If not the same has anyone got details of what they did and how it all turned out!
[Updated on: Tue, 25 February 2003 22:01]
Re: Brake upgrades (again...............) Wed, 26 February 2003 00:48 Go to previous messageGo to next message
Unfortunately the TA22 has completely different brakes, hubs and stub axles, so RA23 upgrades do not apply to the TA22. However, it's not hard to put RA23 struts in a TA22; there are probably others who can explain the details.
silversup
Re: Brake upgrades (again...............) Wed, 26 February 2003 01:09 Go to previous messageGo to next message
Sounds good! Thanks Norbie
Who out there can help me out with more info!!
And on a side note, are the diffs on a 22 replaceable with those of a ra23? Is there a way of identifying one from the other? I was given a box of parts and don't know whether they are for a 22 or ra23...
The reason for the question is I have a pretty loud diff whine going on, is there a way of reducing it or eliminating it all together? or do I need a new diff?!
gold28
Madrid - Spain
Re: Brake upgrades (again...............) Wed, 26 February 2003 02:40 Go to previous messageGo to next message
The TA22 diff is different to the RA23 diff, it is a bit narrower and I think the centre is different also, but don't quite me on it.
I havn't had a close look at a 22 diff, so I am not sure what the difference is.
Depending on which noises it is making, you more than likely just have worn out wheel bearings. Not hard to fix but the bearings will cost about $80 a side.
Re: Brake upgrades (again...............) Wed, 26 February 2003 03:01 Go to previous messageGo to next message
RA23's have a T series diff centre, usually a T292. Later TA22's have a T series centre also so they are interchangeable, however some earlier TA22's have a D series centre.
silversup
Re: Brake upgrades (again...............) Wed, 26 February 2003 03:48 Go to previous messageGo to next message
OK...Well I know nothing about the spare diff - I don't even know whether or not it will be any better!! So how can I tell by just looking at it whether it is a T series or a D series???
Thanks again guys.
silversup
Re: Brake upgrades (again...............) Mon, 03 March 2003 02:32 Go to previous messageGo to next message
Hello...........
some one help me with a little more info here please!:
So how can I tell by just looking at it whether it is a T series or a D series diff???
Jayem
Finland
Re: Brake upgrades (again...............) Mon, 03 March 2003 02:41 Go to previous messageGo to next message
T Series is 10 bolt. Im not sure but I believe that D series is 8 bolt. You might check that. If its no help then you might measure crown wheel.
silversup
Re: Brake upgrades (again...............) Mon, 03 March 2003 03:59 Go to previous messageGo to next message
Thanks for that - I will check when I get home.....
now if they are the same (number of bolts) can I hook it straight up??!!!
how can I tell before I put it in if they will make the "whine" like the old ones did?? Or if they are any good at all!?
once again thanks
Re: Brake upgrades (again...............) Mon, 03 March 2003 05:13 Go to previous messageGo to next message
If you're not sure of the condition of the unit, take it to a diff shop. An inexperienced eye won't be able to pick a good diff from a bad one.
Jayem
Finland
Re: Brake upgrades (again...............) Tue, 04 March 2003 02:09 Go to previous messageGo to next message
Basic checks: examine that there is no bearing play in drive shaft inner/outer(?) bearings and same to front/rear drive pinion bearing. Check play in final gear and pinnion play by spinning them.
This is just some basic stuff. For more accurate inspection go to diff shop.
silversup
Re: Brake upgrades (again...............) Tue, 04 March 2003 22:58 Go to previous messageGo to next message
EXCELLENT thanks!!!
But Jayem what is difference in the crown wheel, what should it be in the 'T' and 'D' diff!??
Jayem
Finland
Re: Brake upgrades (again...............) Wed, 05 March 2003 02:29 Go to previous message
T is 6.7" and D is 6.62"
Previous Topic:18R-Z ?¿?¿?
Next Topic:Push or Pull Type Clutch?
Current Time: Wed Nov 18 16:12:18 UTC 2026
Total time taken to generate the page: 0.0066139698028564 seconds
