Toymods » Tech & Conversions » 7mgte computer
mkiii
7mgte computer Tue, 25 February 2003 23:59 Go to next message
Can anyone tell me the correct procedure to reset the computer on 7mgte when the battery power has been disconnected, as i have had to do this several times, sometimes it sets it self perfect after a couple of days and sometimes its lumpy for about a month.
mkiii
Re: 7mgte computer Wed, 26 February 2003 02:48 Go to previous messageGo to next message
by reset i mean re-tune, cause the computer loses its settings( i think).
hobbs
Epping NSW
Re: 7mgte computer Wed, 26 February 2003 03:40 Go to previous messageGo to next message
hmm,
i've never heard anything like this before, you may be right though because the computer does 'learn' things as time goes by, don't know if it loses this after battery is disconnected. There's nothing in the manuals about it. If you find out anything let us know yeah?
hobbs
Re: 7mgte computer Wed, 26 February 2003 04:17 Go to previous messageGo to next message
I would be fairly surprised if the 7M-GTE ECU (circa 1986) is advanced enough to contain any self-learning functionality. If there's nothing in the manuals about a reset procedure, there's a pretty good chance such a procedure does not exist.
ma61_turbo
Re: 7mgte computer Wed, 26 February 2003 05:56 Go to previous messageGo to next message
The 7m-gte ecu is indeed self-learning. It's fairly simple I think, but it does do it. No way to retune it yourself though. It will always retune itself according to inputs from the motor itself, no way to modify it yourself.
Dave
[Updated on: Wed, 26 February 2003 05:59]
BlackSupra
Re: 7mgte computer Wed, 26 February 2003 08:25 Go to previous messageGo to next message
Wouldn't prolonged periods of crusing at a certain amount of throttle ie. highway driving help to improve the mixtures as such?
i cant spell the 's' word so i wont even try
celicaboy_2000
Lismore, NSW
Re: 7mgte computer Wed, 26 February 2003 09:04 Go to previous messageGo to next message
Are we sure that the computer is self learning???
SUPRAGTE
North Sydney
Re: 7mgte computer Wed, 26 February 2003 11:22 Go to previous messageGo to next message
Yes absolutely certain it is self learning. It does this for fuel mixtures only. It takes the 02 sensor input and then skews the output to get better af ratios.
Re: 7mgte computer Wed, 26 February 2003 13:11 Go to previous messageGo to next message
Pretty much all ECU's since the introduction of unleaded fuel use the O2 sensor signal to adjust the mixtures at cruise, but that's not the same thing as self-learning. I still don't think an ECU that old would be that advanced...
ma61_turbo
Re: 7mgte computer Fri, 28 February 2003 01:47 Go to previous messageGo to next message
Yes, it does change mixtures in real-time, ie while cruising or whatever. But it also does self-learn and improve upon the basic fuel maps. Granted it's not very advanced, but it does do it. I'm sure if you asked on the SOGI mailing list someone would give you confirmation.
Dave
JZZ30MAN
Re: 7mgte computer Fri, 28 February 2003 05:54 Go to previous message
If you what to change the A/F ratio's significantly the Apexi S-AFC's are compatible with the 7M-GTE. This should allow for more Mods. and amendments to fueling to suit.
Note: Its a piggy-back computerthat intercepts engine signals and modifies them before going to the OEM ECU to fool it.
There is a newish one for sale on ALSC for $470 or can occassionally get second hand from $360-$400.
Previous Topic:How much to convert 4AGE 20v to intake trumpets with sock filters?
Next Topic:changing rear engine mount on a twinky
Current Time: Sat Oct 24 19:58:44 UTC 2026
Total time taken to generate the page: 0.0060300827026367 seconds
