Toymods » Tech & Conversions » Geting out rounded bolts.
EvilJack
Sutho/Hills NSW
Geting out rounded bolts. Wed, 26 February 2003 01:45 Go to next message
anyone got any ideas on how to remove rounded bolts?
i tried super cheap auto and auto 1 for some tools but have none.
i have heard of easy outs? duno who sells them though.
i have tried vice grips but cant get around it enough to grip.
was also told you can weld a nut on the top of it but then again i dont have a welder Razz
any tips ? thanx
Cool
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Geting out rounded bolts. Wed, 26 February 2003 02:31 Go to previous messageGo to next message
I'm suprised Auto 1 don't have easy outs, I'm sure I've seen them at my local store. It's like a tapered screw, but the spiral/thread goes backwards. So once you've drilled a hole in the stuck bolt, you start threading this in, but anti-clockwise, and once the taper gets a grip it'll spin the bolt out.
You could try chiseling into the sides of it then using the chisel or a screwdriver with a hammer to knock it 'round so it undoes.
EDIT: plus give it a squirt with WD40 or penetrene or the like, the longer it can soak the better.
[Updated on: Wed, 26 February 2003 02:32]
Re: Geting out rounded bolts. Wed, 26 February 2003 05:17 Go to previous messageGo to next message
depends what the bolt is doing...
my usual tactic is grab a drill bit I have for the job (large diameter, excellent quality) and just drill the head of the bolt off, until just before the drill bit touches what the bolt's holding together.
then just a tap of a hammer and you can remove it.
of course if it's a sump plug that's a bad idea since it's a threaded bolt.
if you want some easy-outs, go to bbc or bunnings or hardware house, something like that... any decent hardware shop should have them
EvilJack
Sutho/Hills NSW
Re: Geting out rounded bolts. Wed, 26 February 2003 05:27 Go to previous messageGo to next message
i finaly got it out
i hammered a slightly smaller ring spanner on top of it, seem to work good.
thanx guys
Re: Geting out rounded bolts. Wed, 26 February 2003 05:30 Go to previous message
I hope you didnt damage the ring spanner
Previous Topic:New member with a few questions??
Next Topic:FWD/4WD Celica Swaybars
Current Time: Wed Oct 14 12:04:38 UTC 2026
Total time taken to generate the page: 0.13733696937561 seconds
