Toymods » Tech & Conversions » How much to convert 4AGE 20v to intake trumpets with sock filters?
inertia
icon7.gif  How much to convert 4AGE 20v to intake trumpets with sock filters? Wed, 26 February 2003 04:28 Go to next message
How much has it cost some of you to convert your 4AGE 20v to have intake trumpets with sock filters?
Got new job with plenty of cash to burn Evil or Very Mad and a 4afc that might have a serious problem in a few months Twisted Evil
CelicaRA45
nth ringwood, Victoria
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Wed, 26 February 2003 05:37 Go to previous messageGo to next message
trd 1s are 100 each but they only fit the black top 1s
Johnny
Sydney, OZ
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Thu, 27 February 2003 01:27 Go to previous messageGo to next message
Not much. Pull the plenum off, ring finer filters and they should have the sock your after.
IRA11Y
Club Member
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Thu, 27 February 2003 09:59 Go to previous messageGo to next message
socks from unifilter are about $50 trumpets are about $50 each
roger
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Thu, 27 February 2003 22:06 Go to previous messageGo to next message
Are the 20V map sensored? or air flow?
if map you no longer have the plenumn chamber to gauge manifold pressure. If air flow you still need the plenum chamber to gauge the air flow through. I think you will find most factory engines running trumpets will use a plenum for these reasons. So you will need to factor in a aftermarket computer to tune from the throttle sensor as the manifold pressure reading will become less than accurate, and gauging air flow without a plenum would be difficult.
Unless the 20v already uses throttle position to map the fuel injectors? I highly doubt it they plenum chamber is not just there for its good look Smile
roger
[Updated on: Thu, 27 February 2003 22:08]
Johnny
Sydney, OZ
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Fri, 28 February 2003 00:56 Go to previous messageGo to next message
Depends, The very late model silvertop& balcktops run a map, early models have AFM, so you right, can't remove the plenumn, aftermarket ECU would be the only way.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Fri, 28 February 2003 04:09 Go to previous messageGo to next message
A MAP sensored motor would be ok with no plenum, as the vacuum isn't in the plenum, it's on the other side of the throttle plates.
Rex_Kelway
Re: How much to convert 4AGE 20v to intake trumpets with sock filters? Fri, 28 February 2003 09:42 Go to previous message
Dang!, mr Worm got in first
Previous Topic:quick question
Next Topic:7mgte computer
Current Time: Fri Oct 23 12:52:06 UTC 2026
Total time taken to generate the page: 0.0044379234313965 seconds
