Toymods » General Car Talk » Replacing gaskets
Replacing gaskets Wed, 26 February 2003 07:29 Go to next message
I'm currently pulling parts off my engine to detail before it goes into the engine bay, but I want to replace the gaskets while I'm at it.
1) I was just double checking, I SHOULD be using gasket goo with the gasket material to seal them all off right?
2) Also, someone told me to be careful with the order that you tighten the bolts on your intake manifold and make sure they are torqued to the right setting when putting it back on, is this correct?
Thanks,
Nathan
Youngy
Eskilstuna, Sweden
Re: Replacing gaskets Wed, 26 February 2003 07:36 Go to previous messageGo to next message
A bit of Gasket sealant is not going to hurt the situation at all, I'd use some, just not too much like some people who think it can be a 'replacement' for the gasket itself.
The order should simply be a criss cross fashion, like what you should use when you change a wheel. The reason for this is to make sure that the manifold is flush or square with the mating surface.
Hope this helps
[Updated on: Wed, 26 February 2003 08:01]
Rolla Boy
Club Member
Sydney, NSW
Re: Replacing gaskets Wed, 26 February 2003 10:28 Go to previous messageGo to next message
Nathan, yes, bolts should be done up to their correct torque setting... Otherwise, they aren't too hard to break...
I've done it so many times...
Torque settings can usually be told by markings on the top of the bolts if they are still the original bolts...
And, most bolts for heads, manifolds, rocker covers should always be tightened in correct order... The orders are usually stated in workshop manuals for that specific engine...
Re: Replacing gaskets Thu, 27 February 2003 00:06 Go to previous messageGo to next message
You work in a Toyota dealership dont you? Razz
Does anyone have a workshop manual for a Gen2 1GGTE?
punkdefender
Dandenong/VIC
Re: Replacing gaskets Fri, 28 February 2003 02:59 Go to previous messageGo to next message
I am looking for the same workshop manual (gen2 1g-gte)...
Rolla Boy
Club Member
Sydney, NSW
Re: Replacing gaskets Fri, 28 February 2003 23:58 Go to previous messageGo to next message
Yeah, I work at Toyota... I can look for you but I'm not too sure if it'll be there...
I'll let you know how I go...
Re: Replacing gaskets Sat, 01 March 2003 04:49 Go to previous message
Thanks for that dude...
Previous Topic:anybody own a green ta22 with a yellow tailight surround ?
Next Topic:BIG THANKS!!!
Current Time: Thu Oct 22 22:59:34 UTC 2026
Total time taken to generate the page: 0.0041720867156982 seconds
