Toymods » Tech & Conversions » Question on 1G conv. for TA & RA23
manipulate
Question on 1G conv. for TA & RA23 Wed, 26 February 2003 10:59 Go to next message
Hey all
im contemplating buying a TA23
now i know that u can go 1G-GTE's into RA23
but is it all good for the TA23's ???
Just thought id ask to make sure
cause the TA's have diff engines so i assume diff engine mounts etc ???
Thanx
Mani
Re: Question on 1G conv. for TA & RA23 Wed, 26 February 2003 11:27 Go to previous messageGo to next message
I thinks its easier to do a 1G conversion in a TA23 because it uses a cross member to suit a front sump Shocked
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: Question on 1G conv. for TA & RA23 Wed, 26 February 2003 11:30 Go to previous messageGo to next message
Yup, TA23s and RA23s are the same, chassis-wise.
Re: Question on 1G conv. for TA & RA23 Wed, 26 February 2003 11:35 Go to previous messageGo to next message
The crossmembers are different though. yeah?
GEEZE23
Western Sydney
Re: Question on 1G conv. for TA & RA23 Wed, 26 February 2003 11:52 Go to previous messageGo to next message
TA23 and RA23 are basically same car with different engines and gearboxes.
* The TA23 better as it has the crossmember you need for the big front- mount sump with the factory goodies (baffles, trapdoor, windage tray) as found on most water-to-air intercooled 1Gs.
* Its also easier to do a rack and pinion steering setup later. and;
*Its easier to get the motor back further Smile
Good Luck!
.oo Dave Oo.
Re: Question on 1G conv. for TA & RA23 Wed, 26 February 2003 11:55 Go to previous messageGo to next message
Just as I thought Very Happy
CrAiGzEE
south of the big smoke
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 04:08 Go to previous messageGo to next message
but its only good if ya using a front sump which are pretty rare
i had to get a ra23 crossmember to put my 1g in
eastie
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 06:18 Go to previous messageGo to next message
well then since my last post went to hell with major critisism ill try this one
ok so if i go buy this ra23 (lt 2000, anyone interested in a 2l enine??? $200/250) then the 1g should SHOULD with a little modification to the sump fit right in place??
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 07:40 Go to previous messageGo to next message
Ahh ok. So not all 1g's have the front sump?
manipulate
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 08:09 Go to previous messageGo to next message
Wow
Thanx heaps for the replys guys
Ta
Mani
CrAiGzEE
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 11:22 Go to previous messageGo to next message
nup i believe there are 3 types of sumps
front
mid
and mid/rear
the mid/rear is most common
Re: Question on 1G conv. for TA & RA23 Thu, 27 February 2003 11:27 Go to previous messageGo to next message
Ok thanks.
GEEZE23
Western Sydney
Re: Question on 1G conv. for TA & RA23 Sun, 02 March 2003 01:40 Go to previous messageGo to next message
There are 5 types of sumps that I have had for a 1G:
- small front (as found on GX81s)
- large front **BEST**(as found on water to air intercooled 1GGTEs)w/ wings to stop side leakage!
- mid/front ( very rare, Ive only seen one)
- mid
- mid/rear ( I think GA70s)
.oO Dave Oo.
[Updated on: Sun, 02 March 2003 01:40]
Nark
Cabramatta, NSW
Re: Question on 1G conv. for TA & RA23 Sun, 02 March 2003 23:41 Go to previous messageGo to next message
Hey Dave,
Good to see you on the Net again! Very Happy
From what I know, front sumps came in Gen 1 1G-GTE's, 1G-GZEs, and 1G-GEs. Wasn't aware that there were different types of front sump!
The mid/rear sumps seem to be the ones found on the later model 1G-GTEs.
Soo, if you have a front sump, get a TA23 crossmember.
If you have a mid/rear, you have to modify it slightly with a big arse hammer and stick it behind an RA23 crossmember.
This applies to RA40s too. Not sure about what you'd do if you had a front sump...
My RA60 uses a front sump.
Re: Question on 1G conv. for TA & RA23 Sun, 02 March 2003 23:56 Go to previous messageGo to next message
Hey Nark, did you have any clearance issues with the swaybar? I'm helping a friend put a 1G in an ST141 Corona, and we're not sure if a front sump is going to cause us grief. The engine is out of a GA70 so it's a mid-rear... any idea which type of sump we should be tracking down? FWIW we're using a crossmember from an RT142 (22R-E engine) so it should be much the same as an RA60 1G conversion.
Nark
Cabramatta, NSW
Re: Question on 1G conv. for TA & RA23 Mon, 03 March 2003 00:52 Go to previous messageGo to next message
Well, I have a front sump and I needed a new swaybar made up for it.
I've never actually looked at how the mid/rear will sit in the RA60, so I can't really help you there.
Just see if it will fit, otherwise, you may have to track down a front sump.
The front sump, as Dave said, is the best sump configuration for the 1G. It's larger, has the wings, and has better internal baffling.
ddeane
PNG
Re: Question on 1G conv. for TA & RA23 Mon, 03 March 2003 05:16 Go to previous messageGo to next message
There's one more. The Mid Rear on the gen 3 motor is different from the mid rear from the earlier motors. It is not as deep.
Craig
Re: Question on 1G conv. for TA & RA23 Mon, 03 March 2003 05:29 Go to previous message
The mid-rear sump definitely won't fit; the RT142 crossmember requires a front sump. What I meant was, after this discussion of different front-sump configurations, should I be looking for a specific model which will clear the swaybar? From your post it sounds like the swaybar will have to go, which is what I kinda suspected. Sad
Previous Topic:Boost on a MA70 Supra with a 7MGTE
Next Topic:1jz in 82 corona
Current Time: Thu Nov 19 20:02:00 UTC 2026
Total time taken to generate the page: 0.006850004196167 seconds
