Toymods » Tech & Conversions » Head Tension for 7MGTE
SUPRA MAN
Head Tension for 7MGTE Thu, 27 February 2003 15:05 Go to next message
I have a 7MGTE in my 3000GT Turbo-A Supra with a huge, larger than standard turbo, and I want to up the boost.
What is the max boost I can safely run ?
I have heard that tensioning the head tighter than standard will help preserve the life of the head, and stop the dreaded 7MGTE blown headgasket problem. My supra has only done 65,000km, so hopefully the head gasket is still in good condition.
I heard tensioning it to 72 was ok, but should I buy new head bolts and torque it to 80 ? How much are new head bolts ?
Any info would be appreciated,
Thanks guys.
[Updated on: Thu, 27 February 2003 15:19]
Danners
Central Coast, NSW
Re: Head Tension for 7MGTE Thu, 27 February 2003 21:44 Go to previous messageGo to next message
Mine blew at 81,000 k's. You can tension the factory Toyota gasket with standard bolts down to 72ft/lb and not have any dramas as the factory settings are around 50 ft/lb - this is way too loose.
After blowing my head gasket i decided to go all out and buy a HKS 2mm metal gasket, and ARP studs (more efficient than bolts) these are able to be torqued anywhere up to 120ft/lb's Laughing i'm running mine at 80 and don't forsee any head gaskets blowing in the near future)
The ARP studs were $250 from Victorian Performance Warehouse and were shipped to me in about 2 days.
My advice is at the moment to torque the current settings down to 72 - this can run for years and years without any problems - even while running high boost. How much boost are you wanting to run? The standard CT26 is only good for a MAX of 14psi but can run pretty smoothly on 10-11, anything higher you need a new turbo.
Gimme a yell if you have any questions!
Danners
Central Coast, NSW
Re: Head Tension for 7MGTE Thu, 27 February 2003 21:47 Go to previous message
Sorry,
Forgot you don't have a CT26! Very Happy
How much boost are you wanting to run? Its really time consuming but you might wanna think of going for the MHG - i wouldn't want to strain the gasket too much without knowing what condition its in etc.
The only other problem i had with the ARP studs was that once they were in the head there was no room around them to get a socket on to do them up - i had to manually grind away the surrounds slightly in order to get em on there properly.
Dan
Previous Topic:changing rear engine mount on a twinky
Next Topic:Max pissed
Current Time: Fri Oct 23 04:51:29 UTC 2026
Total time taken to generate the page: 0.027383804321289 seconds
