Toymods » Tech & Conversions » 3tgte/2tgeu hybrids
AE25
Aucks NZ
3tgte/2tgeu hybrids Sun, 02 March 2003 20:11 Go to next message
im doing a bit of research into this as i have the parts for it and a ke70 converted to jdm te71 spec.
engines are two '82 te71 gex2 2tgeu's, one '83 te71 2tgeu and '83? ta63 carina 3tgteu
a toymods search has revealed the following posts:
http://www.toymods.org.au/msgboard/index.php?t=msg &goto=61777&rid=686&S=3926
d79bbf20a22ee938e32b064ad3d7
http://www.toymods.org.au/msgboard/index.php?t=msg &goto=21070&rid=686&S=3926
i was wandering if anything went ahead following these posts?
one concern i have is that the oil pump shafts are definately different! where the 2tgeu dizzy comes out the block and is driven by a dummy cam and the shafts continue down to the pump. 3tgteu however has the dizzy hole blocked off but still has a bush below it to hold the oil pump shafts in place which are driven by the dummy cam also. the 3tgte dizzy comes out the
side of the head and driven off the intake cam.
my idea is to use the 3tgte block and utilising the 2tgeu head, intake and dizzy arrangement, with aftermarket exhaust manifold and garrett turbo and 3tgteu efi gear, -injectors, ecu and knock control but with std te71 2tgeu igniter/coil and spark wiring. (tricked a little for boost) (ecu is fuel only)?
what i have yet to find out is whether it will all bolt uptogether without mods?? how to set up the oil pump? are the oil pumps the same capacity? what have other people done? im hoping i can use the 2tgeu oil pump arrangement in the 3tgte block as the engine size is the same (different stroke tho) which should theoretically use the same size pump. only concern maybe the extra heat generated by the turbo may require more oil flow??? anyways if anyone can contribute to my investigations id be greatly appreciative.
also from those posts linked above, ive fitted 3tgteu injectors into the '82 te71 2tgeu gex2 which did run them fine. tho the engine ran hell rich with sooty exhaust and lumpy idle and stutters a bit when revved. i measured the injector resistance and all being around 2.2-2.4ohms (2tgeu and 3tgteu).
thetoyman75
Club President
icon10.gif  Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 03:15 Go to previous messageGo to next message
The oil pumps interchange.
Use the 3TGTEU pump tho as they are a Higher volume !
Yes i am Still building my 2T-GTEU butit is still along way from finished. I will be using coil packs so no Dizzy but I can't see any reason the 2TGEu dizzy wouldn't work ?
Grega
melbourne.victoria.austra...
Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 03:22 Go to previous messageGo to next message
like rod says - the 2TGEU dizzy should work fine.
i'm building a 2T-TEU at the moment but mine will kinda run on straight gas via a gasresearch setup.
http://www.vncommodore.com/images/celica/CelicaEngine003.jpg
as you can see the 2TGEU dizzy i'm using is a close fit to the 3T-EU throttle body...
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 03:34 Go to previous messageGo to next message
Oh my! Nice runners!
ChuckLandwehr
Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 11:45 Go to previous messageGo to next message
Man you are going to have to sort out the valve to piston clearance scene. 3TGT pistons with 2TGEU valves, sorry they don't match, you will have to have the pistons flycut to accommodate the LARGER 2TGEU valves. Been there done that.
Regards Chuck.
juzzo84
Hornsby, N.S.W
Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 12:10 Go to previous messageGo to next message
looks very tidy!!!
Smile
thetoyman75
Club President
icon10.gif  Re: 3tgte/2tgeu hybrids Mon, 03 March 2003 22:19 Go to previous messageGo to next message
Chuck,
I am using forged pistons in my Hybrid so this was not a concern for me. I am just wondering tho if it is needed with stock 3TGTEU pistons ??
The 2TGEU and the 3TGTEU have the same size valves ?
AE25
Aucks NZ
Re: 3tgte/2tgeu hybrids Tue, 04 March 2003 10:00 Go to previous messageGo to next message
ok im getting lazy here but
has anyone researched using 2tgeu pistons? im thinking theres got to be extra height either in the 3tgteu block or in the 2tgeu pistons and/or conrods to counter the extra stroke of the 3tgte???
to 'flycut' meaning mill the valve clearances deaper? i could do that but at the expense of strength? anyone tried it with success? the 3tgte pistons are weak as they are so those forgies sound like the answer! $$$
as to valve sizes i havn't got a clue, usually the n/a cams have more duration/lift which i would think would be more problem than actual valve diameter?? something i'll have to spend hours trying to research Confused
ChuckLandwehr: do you know which specific 2tgeu/3tgteu you used for your hybrid? there are definite variations between early and late specs.
this project is for drift so im after low boost high compression style if possible so theres no off boost lag or low rpm turbo lag/ mid rpm boost surge found with larger turbo's. looking at an rb20det t25 bb turbo or s14/s15 t28 bb Smiley =
laters
Grega
Re: 3tgte/2tgeu hybrids Tue, 04 March 2003 20:22 Go to previous messageGo to next message
i'm not really after "drift" capability with mine, but, will be using an rb20det non roller bearing turbo and 8.5:1 (or maybe higher, still deciding) compression (but only running 7-10psi, intercooled, and, also using LPG)
thetoyman75
Club President
icon10.gif  Re: 3tgte/2tgeu hybrids Tue, 04 March 2003 23:35 Go to previous messageGo to next message
AE25,
All the T series engine use the same size Rods. They vary in strength but are all the same length (Exculding the 1400cc T engine) The 3TGTEU and 2T, 2TGEU etc also all use the same basic block design. there are some minor differences but the deck height is the same on all of the. It is the Pin height in the piston itself that counters the increased stroke of the 3T crank, Hence the need for 3T style pistons and the inability to use 2TGEU pistons with a 3T crank.
Yes flycutting a standard or cast piston does have limitations. You would be surprised however how far you can go. Smile And yes flycutting is increasing the recease for your valves in the top of the piston.
Your cam specs will indeed dictate how big a flycut you will need. The thicker the base of the piston the deeper you can go at the expense of increased piston weight.
The first series 2TG (88220 Head) has smaller valves than its predessesors. The 88222 head thru to the 88262 head all have the same size valves which are the same size as the 3T-GTE valves.
Oh I also have a Ball Bearing R32 Series 2 Skyline Turbo for sale if your interested. Drop me an email if you are Smile
AE25
Aucks NZ
Re: 3tgte/2tgeu hybrids Sun, 09 March 2003 08:55 Go to previous messageGo to next message
hey cool
that sort of info you can't find on the net Very Happy
im thinkin... since you have to flycut the 3tgte pistons to suit the extra lift of the 2tgeu cams, then why not swap the 3tgteu cams into the 2tgeu head? ever researched this? not sure if there are any differences apart from the extra cog to run the 3tgte dizzy Confused
actually the only reason i'm researching putting the 2tgeu head on is that i don't want the intake going over the cam cover.
i have more thoughts now. will the 2tgeu intake manifold fit/bolt to the 3tgte head? (the runners anyway- the plenum will hit the dizzy i believe) if this is the case then it could be possible to modify the plenum/throttle so that it fits around the 3tgte octopus dizzy? hmm or even an 18rgeu intake??? Evil or Very Mad
Syc02T
Lake Macquarie
Re: 3tgte/2tgeu hybrids Sun, 09 March 2003 10:46 Go to previous messageGo to next message
Rod i finally got my engine together and found out that T series rods are not the same, I used the 3tgteu rods and we had std 2t bearings, the rods look exactly the same except for the oil hole. it misses by enough to be a bastard.
thetoyman75
Club President
icon10.gif  Re: 3tgte/2tgeu hybrids Mon, 10 March 2003 08:31 Go to previous messageGo to next message
Dude,
Yeah the Oil holes are in slightly different locations. Just means you need the right bearings for the rods. The Size of the 2T and 3TGTE Rods are the same tho. Smile
And heres a pic courtesy of Chris. (SYC02T)
http://www.toymods.org.au/~rod/Technical%20Info/3tgteu_rod_with_2t_bearing_not_aligned_closeup.jpg
[Updated on: Mon, 10 March 2003 08:47]
inferno
Re: 3tgte/2tgeu hybrids Tue, 11 March 2003 07:37 Go to previous messageGo to next message
Hangon aren't the 3T end bearings same as the 3TGTE end bearings, but the 3T crank bearings are something like 8mm off the 3TGTE crank bearings?? Is this correct?? and aren't the 3T and 2T rod bearings the same??
EDIT: sorry 'bout the confusion i misread rod's post and freaked out, thinking the bearings i used may not have been right Confused
So.. end bearings are all the same for T series engines, except the 1T engine, and crank bearings are same for 2T and 3T, different for 3TG and 2TG?
[Updated on: Tue, 11 March 2003 10:20]
AE25
Aucks NZ
Re: 3tgte/2tgeu hybrids Thu, 13 March 2003 11:35 Go to previous message
im getting more thoughts, cripes there must be something wrong with me Rolling Eyes
keep the 3tgte nearly internally stock, head and all. but remove the intake and dizzy. either replace dizzy with 2tgeu item and run aftermarket ecu with quad igniter/coils or modify a crank angle sensor to run the coils. this way the huge 8plug dizzy can be removed from the head making more room for a custom forward facing intake...
Previous Topic:Air Con & Heater Problems
Next Topic: 70-75mm Throttle Body ???
Current Time: Sun Nov 1 05:03:00 UTC 2026
Total time taken to generate the page: 0.0071141719818115 seconds
