Toymods » Tech & Conversions » 3TG turbo upgrade need other upgrades too?
Kach22
icon5.gif  3TG turbo upgrade need other upgrades too? Mon, 03 March 2003 06:41 Go to next message
Hey Guys'n gals. Does anyone know what alternative turbo may fit straight to the 3TG? I have done my turbo seal but dont want to put the same 1 back. Upgrade opportunity calls, but dont know much re turbo changes. Would I have to get an aftermarket computer and different injectors aswell to match? What is an inexpensive but better turbo to use for a 3TG. Would it be OK to get a second hand turbo and check the seal? Any hints greatly appreciated. Kach22 from SA with a TA22. TAA
Kach22
Re: 3TG turbo upgrade need other upgrades too? Fri, 07 March 2003 10:36 Go to previous messageGo to next message
Someone with any suggestions on my questions ,I'm sure plenty out there would be able to help me out. Anything at all. taa
inferno
Re: 3TG turbo upgrade need other upgrades too? Fri, 07 March 2003 12:59 Go to previous messageGo to next message
http://www.toymods.org.au/msgboard/index.php?t=msg &th=10747&start=0&rid=100&S=e54c88 b48703055aa2b36831ac826360
I've heard of people using the CT26 as a good upgrade, from what i've heard its a bolt on apart from a couple of oil lines. The twin entry model off the mr2's need a new manifold made, but the single entrys are the bolt on. I'm just going on what i've heard but, you know my 3TGTE is sitting on the garage floor atm Sad
This is probably the cheapest upgrade i can think of, then you start going into custom manifolds and big ni$$an motherf***ers Shocked .
EDIT: should really read what your asking before i reply hey. The 3TGTE computer should be able to handle more boost (<15psi), but then you run the risk of leaning out with the injectors. by upgrading the injectors you will have the same duty cycle but more flow, hence a much richer mixture over all RPM range, like i think simon mezz found out with his 400+cc/min injectors (the oxy sensor is too refined to selftune). Once you've upgraded turbo-->injectors-->computer your stock pistons may not be able to handle it. the cheap option would be to go with a high-flow CT20 or CT26, leave injectors, intercool, tune and not worry about custom manifolds or aftermarket injection. The powerful option would be something like 2L gemini hepatite pistons or forgies, aftermarket computer, W58 box, hilux diff, upgrade fuel lines, surge tank and garret turbos.
[Updated on: Fri, 07 March 2003 13:11]
Grega
melbourne.victoria.austra...
Re: 3TG turbo upgrade need other upgrades too? Sun, 09 March 2003 08:50 Go to previous messageGo to next message
this is what i'm planning to do :
http://www.fortunecity.com/silverstone/toyota/80/t 18/turbo.html
i'm just saving up for the turbo....(want to get an rb20det BB that a certain person on here has for sale)
FLY PSI
Re: 3TG turbo upgrade need other upgrades too? Sun, 09 March 2003 10:19 Go to previous messageGo to next message
I will be runing a T3 of an FJ20DET, with a steampipe manifold!
Kach22
Re: 3TG turbo upgrade need other upgrades too? Wed, 26 March 2003 06:49 Go to previous messageGo to next message
Yeah, at moment I think I may either have the car off the road or borrow your ct20 due to financial reasons. CT26 sounds good, looked at the differences at 4's N More recently. Thanks
inferno
Re: 3TG turbo upgrade need other upgrades too? Wed, 26 March 2003 12:22 Go to previous message
sweet avatar yellow submarine Very Happy !!
i can just see any decent turbo upgrade costing over a grand, and i know you'll have a few expenses comming up with the wedding. your very welcome to borrow my turbs so long as it only runs stock 8psi and you double check the oil and water lines are setup correct, oh yeah and i get it back when i sell my 3TG Rolling Eyes .
Previous Topic:cressida suspension
Next Topic:Rebuild R154?
Current Time: Sat Nov 21 00:47:05 UTC 2026
Total time taken to generate the page: 0.0042920112609863 seconds
