Toymods » Tech & Conversions » rwd 4agze (map) air intake manifold 4 turbo conversion
sprinterboy4agze
rwd 4agze (map) air intake manifold 4 turbo conversion Mon, 03 March 2003 23:07 Go to next message
i know in japan sprinters came with 4age rwd intake manifolds but its hard to get hold on one of these so ppl usually do some cut n welding i want to know what intake manifold fits on my 4agze its map and from an ae-92
do i use the large port or small port and how to convert it to rwd does anyone do this in sydney? does anyone have any info on how to cut where to cut from and what to take in mind etc thanx
shane
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Tue, 04 March 2003 10:45 Go to previous messageGo to next message
You need the 100kW intake manifold, which only comes in FWD anyway, basically you chop a hole on the opposite end to the current throttle body, get a flange welded over the hole, bolt the throttle body to the new flange & bolt & seal a plate over the old TB flange.
Keep in mind bonnet clearance, the TB on RWD 4AGE manifolds angles down a bit to clear the bonnet.
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Tue, 04 March 2003 11:05 Go to previous messageGo to next message
I've got one you can buy, although it was actually done for a gasresearch throttle, not a toyota one. However, a ford/holden TB should fit, and be a lot easier to make work with aftermarket management as well.
sprinterboy4agze
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Tue, 04 March 2003 20:45 Go to previous messageGo to next message
so you have done this? and used it? whats a tb?
Ribbo
Northern Beaches
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Tue, 04 March 2003 23:09 Go to previous messageGo to next message
tb = throttle body
lots of people put the big port 4age head on the gze cos it flows better and you could then use the RWD manifold from the jap spec 4age
just another option
sprinterboy4agze
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Tue, 04 March 2003 23:30 Go to previous messageGo to next message
so whats better small port intake manifold or large port can both of these be used or only the small port can be used on the 4agze
Ribbo
Northern Beaches
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Wed, 05 March 2003 04:27 Go to previous messageGo to next message
as far as im aware the gze is small port so you would only be able to run the small port intake, im sure there would be ways to run the bigport one but id say it would require custom stuff and not worth it.
TA22-3SGTE
MACKAY
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Wed, 05 March 2003 11:30 Go to previous messageGo to next message
I'v bought 2 4AGZE motors and both are large port and the rwd manifold bolts straight on , It was bolted into a AE86 and turboed , all rwd mounts and accessories bolt on .
Trevor
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Wed, 05 March 2003 12:47 Go to previous messageGo to next message
4AGZE's come as both small + large port - AW11 MR2 and early (AFM) ae92 ones are big port, the MAP sensed later AE92's and AE101's are small port. I've got the manifold left over from my original motor when I broke it and replaced with a big port version. I'll also soon have the big port manifold I made myself so sale, as I'm fitting multi throttles to mine now. If anyone's interested, PM me.
sprinterboy4agze
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Wed, 05 March 2003 21:02 Go to previous messageGo to next message
is there anyway of telling what your ze came out out, i got told by looking at your spark plug leads which mine says 91 so does that mean its from a ae-92 91 model trueno? if so then is this a small port or large port but im guessing its a small port because the guy did tell me its a map but how can u b sure?
Invisible Throw
Re: rwd 4agze (map) air intake manifold 4 turbo conversion Wed, 05 March 2003 21:46 Go to previous message
Easy.
Look at the head (big or small ports) or look at the block for the external oil drain.
Previous Topic:4A-GE conversion help needed!
Next Topic:braided lines
Current Time: Wed Nov 25 12:08:27 UTC 2026
Total time taken to generate the page: 0.029965162277222 seconds
