Toymods » Tech & Conversions » Replacing Thrust Bearing
Replacing Thrust Bearing Mon, 03 March 2003 23:51 Go to next message
I was wondering if anyone could tell me how to replace the thrust bearing, and if possible, does anyone have a picture to show me exactly what I'm looking for? Rolling Eyes
Thanks,
Nathan
Re: Replacing Thrust Bearing Tue, 04 March 2003 00:00 Go to previous messageGo to next message
Do you mean the thrust bearing in the clutch mechanism?
If so, you just press it off and press it on. Usually with a bit of ingenuity, you can do it in a biggish vice. Otherwise, off to a workshop - might cost $10.
If you mean those that support the crank, then that's a much bigger job. I'd suggest you get an engine manual.
Re: Replacing Thrust Bearing Tue, 04 March 2003 00:08 Go to previous messageGo to next message
Nah, the first one, I'm going to change the clutch in the near future, and I just needed to know what the bloody thing looks like Smile
I've been told it should be replaced, and I like the idea of being precautionary.
[Updated on: Tue, 04 March 2003 00:09]
Re: Replacing Thrust Bearing Tue, 04 March 2003 01:07 Go to previous messageGo to next message
When you buy a clutch kit, generally it contains a thrust bearing. Would be silly to not use it now, wouldn't it? hehehe Very Happy
Re: Replacing Thrust Bearing Tue, 04 March 2003 04:02 Go to previous message
i *think* i know what you are on about....
have a look inside the bellhousing, and on the end of the clutch throw-out forks (or whatever they are called) there is a bearing (like a ring) that goes around the input shaft of the gearbox. In my W50 there was these two spring type clips that held the bearing and bearing shaft thingy in, so i undid those, and tapped the centre shaft out from the bearing. THen got the new bearing from my clutch kit and tapped it on until it was all the way down.
Piece of piss really!
Previous Topic:Negative Supercharging
Next Topic:Smoking GZE
Current Time: Thu Nov 19 06:08:05 UTC 2026
Total time taken to generate the page: 0.0066978931427002 seconds
