Toymods » Tech & Conversions » 15inch rims into a sprinter
zeus-ae86
15inch rims into a sprinter Tue, 04 March 2003 05:55 Go to next message
ive just managed to get my hands on a set of 15inch tommy kaira rims with 205/60's on em.
i currently have the stock 13inch rims on my sprinter and when i tried the 15inch rims on, the inside of the tyre was pushing against the shocky and base of the spring so much that i could fit my fist inside the guard.
is there anything apart from spacers i could do to make these rims fit cos they look absolutely sick. also what size spacers you rekon?
[Updated on: Tue, 04 March 2003 05:56]
roger
Re: 15inch rims into a sprinter Tue, 04 March 2003 06:06 Go to previous messageGo to next message
Sounds like you bought the wrong rims dude. Your offset is wrong hence the need for spaces. You will have to find what offset the rims are to work out what size spacer you need. Spacers are illegal and they add more load on to the bearing.
[Updated on: Tue, 04 March 2003 06:07]
zeus-ae86
Re: 15inch rims into a sprinter Tue, 04 March 2003 06:35 Go to previous messageGo to next message
which one of the numbers on the rim is the offset?
J-AE86
Re: 15inch rims into a sprinter Tue, 04 March 2003 06:53 Go to previous messageGo to next message
i got 15" deep dish on rears running 205/50's
i have to drive slow over speed humps or not carry heavy loads otherwise it starts guard rubbing apart from that i got no problems at all. The wheels stick out of my guards about 0.5cm
Kman
Re: 15inch rims into a sprinter Tue, 04 March 2003 08:41 Go to previous message
Try this site dude.
http://www.miata.net/garage/tirecalc.html
Not sure about the offsets but if you put the details of your original tyre in and then put the details or your new tyre, or maybe the tyre you will have to get it will tell you the overall diameter of your wheels.
You might be able to get away with lower profile tyres. Might want to check with RTA regulations if your in NSW that is.
Noticed your in WA.. Embarassed
[Updated on: Tue, 04 March 2003 08:42]
Previous Topic:Starting a 1G without gearbox and bellhousing
Next Topic:Gearbox 3sge
Current Time: Thu Nov 19 05:03:11 UTC 2026
Total time taken to generate the page: 0.0052680969238281 seconds
