Toymods » Tech & Conversions » Boostn the 1J
mx83toy
Boostn the 1J Thu, 13 June 2002 14:35 Go to next message
no one can resist when they se 1J can they Smile anyway
what hoses do i cut to put in the "t" peices, plese be descriptive...
3t-RA40
Re: Boostn the 1J Fri, 14 June 2002 00:39 Go to previous message
I would not surgest cutting the orginal lines, just put them aside and start afresh, if you make a mistake you can always put the originals back on. It is a little involved as you need to tee off both turbos back to one boost controler, if you don't then one turbo will run more boost than the other.
You need to run lines from the fittings (on turbo housing) on each of the turbos back to a tee piece then that single line needs to go to intake of boost controller. Then you need to run lines from the each of the wastegates back to a tee piece then that single line needs to go to the outlet side of the boost controller. Rolling
So, boost flows from the turbos fittings along the lines, through the boost controller Arrow back along the lines and to the wastegates. Nod
Make sure you use some good quality vacum/boost hose and fittings. This is how we done it on a 1J in Newcastle an it worked OK. Good luck, and if your not sure what your doing get someone who dose to check it.
Previous Topic:Problem's with my brakes... arrghh!
Next Topic:2TG/4AG part 2
Current Time: Wed Nov 18 17:02:11 UTC 2026
Total time taken to generate the page: 0.0052509307861328 seconds
