Toymods » Tech & Conversions » Update on 3T-GTEU Starlet RWD Project
Purple_Beasty
New Zealand
Update on 3T-GTEU Starlet RWD Project Wed, 05 March 2003 10:07 Go to next message
Firewall is basically finished. Actually moved the firewall back around 4 inches and should tidy up quite well.
http://www.picturetrail.com/gid1781336
Now onto the independent rear end, more fun!
Callum
Grega
melbourne.victoria.austra...
Re: Update on 3T-GTEU Starlet RWD Project Wed, 05 March 2003 19:46 Go to previous messageGo to next message
damn thats a bit of work!
dunno if you're across what bill sherwoods up to, but http://www.billzilla.org/starlet.htm might be worth a looksee for ya.
Purple_Beasty
New Zealand
Re: Update on 3T-GTEU Starlet RWD Project Thu, 06 March 2003 00:50 Go to previous message
Yeah I have seen Bills site. His project has a little more money behind it. Due to limited funds the cheapest way for me to get the 200hp I wanted was a 3T-GTEU and using as many factory Toyota parts as possibe.
I started with a TA63 Carina (which is where the firewall is from) for $100. Motor was no good but got me a W55 in good condition. I am also using the TA63 front crossmember, struts and steering as well. Just need to attach the castor arm and sway bar mounts. Unbelievablely the steering column bolted straight up and the crossmember is only slotted 1cm each side.
Since I was using the Carina crossmember, that set the engine back a bit (better handling) so decided I may as well use the Carina tunnel to fit the gearbox. Just measured from the crossmember to the gearbox mounts to get in the right place and was only $400 for the labour. Next the Carina rear end (IRS F code) is being fitted for $800, cheaper than most other diff options as not only do you need to get the mounts welded to the diff but you really need to move the body mounting points for decent handling.
Main advantage is I end up with mostly common factory parts in the car for when I bend it (which happens to most race cars at one time or another).
Will post up more pics as I progress.
Callum
Previous Topic:1G-GTE power!!!
Next Topic:modify KE30
Current Time: Fri Nov 20 12:58:10 UTC 2026
Total time taken to generate the page: 0.0062909126281738 seconds
