Toymods » General Car Talk » URGENT: Need to know surge tank hose size
willwal98
Toowoomba
icon1.gif  URGENT: Need to know surge tank hose size Fri, 14 June 2002 05:01 Go to next message
Can someone tell me what size to make the spouts on a surge tank. I'm getting one made now and I don't know what size hose I have to use.
the bits with @'s next to them if you can understand my ASCII art.
An answer within the next 30mins would be great
.._|_
[Updated on: Fri, 14 June 2002 05:05]
Re: URGENT: Need to know surge tank hose size Fri, 14 June 2002 07:25 Go to previous messageGo to next message
It depends on the pump being used and the outlets from the fuel tank.. but mine i have :
bottom hose is 12mm
the rest are all 8mm
but if the tank and return lines are only 6.5mm, then make the pipes in the tank the same.
willwal98
Toowoomba
Re: URGENT: Need to know surge tank hose size Sun, 16 June 2002 23:25 Go to previous messageGo to next message
Bill Sherwood
Brisbane / Gold Coast
Re: URGENT: Need to know surge tank hose size Mon, 17 June 2002 04:43 Go to previous messageGo to next message
When it comes time to build the surge tank, please take a little longer to do it properly.
The vast majority of the aftermarket ones I've seen are just rubbish.
This is how to shape it properly -
http://www.billzilla.org/swirl.gif
('Scuse the crude pic)
#1 pipe is the low pressure feed into the swirl pot.
#2 pipe is the feed to the high pressure pump to the fuel rail.
#3 pipe is the return from the fuel rail.
#4 pipe is the return to the fuel tank.
If you look at the path of the fuel, you can see that the hot & cold fuel will not be mixed up by turbulent flow, and that all the air in the pot will be removed, so there's almost zero chance of surge.
willwal98
Toowoomba
Re: URGENT: Need to know surge tank hose size Mon, 17 June 2002 05:18 Go to previous messageGo to next message
thanks, most people would not have bothered to draw me, i'm very grateful. I'll definitly follow that for my tank. I'll have to try and catch the guy making it before he goes home. Thanks again for the info - most helpful. Very Happy
Bill Sherwood
Re: URGENT: Need to know surge tank hose size Mon, 17 June 2002 06:29 Go to previous message
Ah!
You got lucky, I drew that for another thread on another forum a couple of weeks ago, and so was able to dig it up easily.
There was a link to a MUCH better picture of one, but it's gone now unfortunately ... Sad
Anyway, glad it makes sense that you can see how the air & fuel swirl around and don't get mixed up the wrong way. Little things like this make the difference.
Previous Topic:Where are the Sydney "Hot Spots"?
Next Topic:mclaren F1 vs Skyline : ae86 video.. check it
Current Time: Sun Oct 25 08:09:15 UTC 2026
Total time taken to generate the page: 0.028397083282471 seconds
