Toymods » Tech & Conversions » starter motor
ae86slaver
starter motor Thu, 06 March 2003 11:16 Go to next message
how easy is it to change the starter motor on a 4AGZE? and where is it located/what does it look like? any help appreciated
juzzo84
Hornsby, N.S.W
Re: starter motor Thu, 06 March 2003 17:29 Go to previous messageGo to next message
the starter motor is right down the front of the engine, its hiden in behind the exhaust manifiold, and looks kind of a like a cylinder that is bolted into the gearbox sideways throught the block.
justin
BDRAGN
Auckland N.Z. (Currently ...
Re: starter motor Thu, 06 March 2003 18:59 Go to previous messageGo to next message
I recomend building a heat shield for the new starter motor while you are there.... because the manifold & engine cook the thing and as a result some engines do not start when hot.... you will save yourself a lot of grief if you take the time to improve the oem heat shield.... trust me....
ae86slaver
Re: starter motor Thu, 06 March 2003 22:33 Go to previous messageGo to next message
thanks a billion guys, appreciate it
BDRAGN
Re: starter motor Thu, 06 March 2003 23:26 Go to previous messageGo to next message
what chassis have you got?
ae86slaver
Re: starter motor Fri, 07 March 2003 12:33 Go to previous messageGo to next message
it's an AE86 sprinter. had a look today and the wires around it were pretty melted from the headers. Can I replace it myself? Are they universal fit? And how much?
BDRAGN
Re: starter motor Fri, 07 March 2003 13:21 Go to previous messageGo to next message
You could repelace it yourself but i think it will be an absolute pig of a job (never done it myself though... im only guessing).... cos its right under everything.... seings as a lot 4age parts seem to be interchangeable.... i would assume that they would be for this.... but i cant gurantee... sorry im not much help.....
BDRAGN
Re: starter motor Fri, 07 March 2003 13:22 Go to previous messageGo to next message
86 sprinter? the oringinal initial d car eh? cool man... im buying a ae86 levin when i get back to nz.... (dont like the sprinters... the pop up lights piss me off....
ae86slaver
Re: starter motor Sat, 08 March 2003 02:34 Go to previous messageGo to next message
haha, nah man, i haven't got the Trueno, i meant 'sprinter' as in the levin - Australian spec (it has the sprinter badge on the back and most ppl in Aus say sprinter- well i do anyway!) Yeah i'm not too much of a fan of the pop up lights either!
Awesome, do you know how much they cost? what can i use as a shield? I thought of foil or something of that criteria
thanks for ur help dude
BDRAGN
Re: starter motor Sat, 08 March 2003 04:26 Go to previous messageGo to next message
this was from a site i found... sirect quote... ive got other info about common levin or sprinter issues... i can email you them if you like... by the way... gts is the stupid name for the 4age levin.... (yes some sick bastard actually put a 4afe in some of the levins at the factory....
On the GT-S, the starter is sandwiched between a relatively hot engine block and an even hotter exhaust manifold. To their credit, they installed decent OEM heat shields on the exhaust header and starter. Don't be surprised when you get back to the car and the starter won't turn--acute heat soak. The problem's worse if you use aftermarket exhaust headers that don't have heat shields like the KBD unit I'm using. Solution? Fabricate your own heat shield using a sheet of 304 stainless steel and weld on some mounting tabs on the header. You can also buy some of that "heat wrap" for starters that they sell at speed stores. '
BDRAGN
Re: starter motor Sat, 08 March 2003 04:30 Go to previous messageGo to next message
oh yeah.. this too for troubleshooting problem starters....
Check each step in order:
Battery charge
Battery terminals and immediate cables in good condition--no fraying
Ground strap from tranny to left frame rail in good condition
Ignition key cylinder
Clutch start safety switch
Starter relay; P/N 28300-16010 (Be forewarned that this relay costs $70+)
Main power cable from positive terminal to starter; P/N 82122-12310 (~$30)
Starter solenoid
Starter
ae86slaver
Re: starter motor Sat, 08 March 2003 09:28 Go to previous messageGo to next message
Sweet as dude, yeah I've basically checked all those possibilities, but after all that i think the starter motor is calling it quits. Sometimes in the most needed situations, i crank the engine and it just cringes, not even turning over, and lately it's been happening way too often, sometimes i wait at least 10 minutes! Yeah heat is a problem there, it's absolutely rediculous these engines place the starter there!
BDRAGN
Re: starter motor Sat, 08 March 2003 11:01 Go to previous messageGo to next message
Yeah mate... ive got the same issue with my ae92 age.....
little trick.... try switching the engine from on to start rapidly till it starts kicking.... it worked for me.... i get a little click and a kind of straining noise and sometimes no straining noise... but that little trick always works within ten seconds....
Youll be right to change the starter anyway.... cos if its already been slammed by the heat you dont want to repair it, install a heat shield and then have to take the whole f%&@ing thing apart in 6 months... But if youve got the cash.... it might be cheaper to buy a whole damn engine.... and keep the rest for spares or sell it on... over in new zealand the junkyard people are absolute thieves... unless your buying something big....
fOOZ86
Re: starter motor Sun, 09 March 2003 20:34 Go to previous messageGo to next message
The main wire going into the starter motor (with the little black rubber sealy thing on it) seems to be important on my engine, if that's not firmly pressed on the engine won't start - problem seems as though it's cracked a bit so it slips back...
There's also another connector down there too, have you checked both of them?
juzzo84
Hornsby, N.S.W
icon4.gif  Re: starter motor Mon, 10 March 2003 03:01 Go to previous messageGo to next message
he he Laughing
this thread is funny
justin
ae86slaver
Re: starter motor Mon, 10 March 2003 09:05 Go to previous message
funny?
'small things amuse small minds'
!!! haha j/k
Previous Topic:turbo for 4agte
Next Topic:pilot pen kinda noise from my 7afe?
Current Time: Fri Nov 20 14:32:55 UTC 2026
Total time taken to generate the page: 0.0075149536132812 seconds
