Toymods » Tech & Conversions » 1GGTZE????
sbyder
Ipswich QLD
1GGTZE???? Thu, 06 March 2003 12:06 Go to next message
OK, we all know that the 1G motor came out in three variations, the NA 1G-GE, the supercharged 1G-GZE and the twin turby 1G-GTE.
My question is, how hard would it be, and has it been done before to grab a stock good condition 1GGTE and throw the supercharger off the GZE on it and run close to stock boost through both forms of compressors? I know you'd need custom intake manifolds and a new computer and lil fiddly bits, but it wouldn't be 'that hard' would it?
Considering its basically the same motor with different forms of induction, shouldn't it be a basic bolt on of the supercharger?
Anyone shed some light on this plz?
If i do get my planned soarer, i think this would be a good way to reduce that unhelpful turby lag that it has.
Ben
PLZ- no flamage, im still young and dont like heat.
Cyber-punk
Brisbane, QLD
Re: 1GGTZE???? Thu, 06 March 2003 12:18 Go to previous messageGo to next message
From memory toyota released a 1000cc race engine with both supercharger and turbocharger opperated by some kind of electric clutch...or somthing like that
the SC would kick in from the word go up until the turbo started spooling then it'd drop out, well somthing to that effect
as to how hard it would be to do, not sure
there are probably some draw backs to this kind of set up as it doesnt seem to be widely used(if at all?)
Bugman
Re: 1GGTZE???? Thu, 06 March 2003 12:20 Go to previous messageGo to next message
a guy on these forums has a 1g-gzte in his celica
Helmann
Ipswich
Re: 1GGTZE???? Thu, 06 March 2003 12:56 Go to previous messageGo to next message
This engine does exist. I think it might be some kinda toyota race engine tho.
I know Bill Sherwood brought one but i don't think he used it and sold it back to the place he bought it from.
It was only a single turbo tho.
Re: 1GGTZE???? Thu, 06 March 2003 13:09 Go to previous messageGo to next message
Didn't Toyota used to use an S engine with a twin charge setup back in the ST165 days for rally?
It could well be done, just gotta make sure you hook it up with the pipes in the right places and with a suitable decent bypass for air around the SC once it's doing nothing. Easiest way is to shove a big daddy turbo on there with the SC blowing into it and a decent sized (e.g. 80mm) bypass valve (Goyen maybe?) that opens once boost exceeds, say, 8psi. The other way is to have a turbo going into a SC, with both operating full time, like the Bandag Bullet and some other similiar (big fat arse diesel) projects. Probably wouldnt work that well though...
Someday I'd love to play with a setup like this on a smaller engine like a 1g and try to have it pull big HP and still drive well.
sideshow
Re: 1GGTZE???? Thu, 06 March 2003 13:14 Go to previous messageGo to next message
its easy
the supercharger has a clutch type pulley on it
just use an rpm activated switch to turn it on at say 1500 rpm then turn it off just as yr turbos start makin boost
if u r lucky the standard ecu might get the mixtures close due to the map sensor/air flow measuring boost from the supercharger much earlier in the rpm and adjustin for it
Re: 1GGTZE???? Thu, 06 March 2003 13:15 Go to previous messageGo to next message
Twincharge kits have been available for 4A-GZE's for years. The general concensus with the MR2 boys in the US is it's a nice gimmick, but a well setup turbo engine can acheive the same results for less money and much less screwing around. It seems like a great idea, but there's a reason you very rarely see twincharged engines on road cars...
sbyder
Ipswich QLD
Re: 1GGTZE???? Thu, 06 March 2003 23:30 Go to previous messageGo to next message
<<< likes to be different Smile
anyone got any pics of detailed 1G-GTE's or GZE's???
Helmann
Ipswich
Re: 1GGTZE???? Fri, 07 March 2003 00:01 Go to previous messageGo to next message
I got some pix of a gte that has been detailed by a mitsubishi triton!!!
LOL
sorry couldn't help myself.
biased99
Re: 1GGTZE???? Fri, 07 March 2003 00:05 Go to previous messageGo to next message
Speak to Bill Sherwood - he tends to frequent the TwinCam16 forums...I think his web-site is www.billzilla.org or something like that...
Re: 1GGTZE???? Fri, 07 March 2003 00:10 Go to previous messageGo to next message
Here are the pics from Bill's site:
http://www.billzilla.org/1ggztefront.jpg
http://www.billzilla.org/1ggzteside.jpg
And this is the site itself:
http://www.billzilla.org/rallycar.htm
rob_RA40
c'town, NSW
Re: 1GGTZE???? Fri, 07 March 2003 00:48 Go to previous messageGo to next message
a guy recently came onto the forums, he has a 2wd hilux with a 1G-GTZE in it
im pretty sure if u search the forums you will find who he is, he may be able to help.
also this topic has raised a lot of interest on the performance forums, there is a VERY big thread with many inciteful posts, diagrams and info, well worth a look.
good luck with the project..
EDIT: by the way if you do start this project u have to start with a complete 1G-GZE and add bits from the GTE, not the other way round.
[Updated on: Fri, 07 March 2003 00:50]
1ggtze
melbourne SE.
Re: 1GGTZE???? Sat, 08 March 2003 01:00 Go to previous messageGo to next message
This is mine its all standard, 1ggtze. With the s/c on a switch and the tt running 9 psi and when the s/c is on it gets up to 26psi big injectors and wolf comp.
http://members.optusnet.com.au/gianttomato/1GGTZE/ 1GGTZEa.jpg
toycelica77
bris
Re: 1GGTZE???? Sat, 08 March 2003 13:03 Go to previous message
Cyber-punk wrote on Thu, 06 March 2003 22:18
wasnt it the nissan micra??
Previous Topic:ra23 indicator problems...
Next Topic:4AGZE into a TA22
Current Time: Fri Nov 20 06:51:02 UTC 2026
Total time taken to generate the page: 0.069200992584229 seconds
