Toymods » Tech & Conversions » reverse lights dont work
reverse lights dont work Fri, 07 March 2003 03:13 Go to next message
ok, I found out the other day that my reverse lights dont work, and then yesterday noticed a cable hanging out the bottom of my gearbox.
now, I'm assuming this is the reverse cable (it's a w58 box).
is there an easy way to get this back into the cabin so I can hook it up??
lvn-ra65c
Wichita, Ks, USA
Re: reverse lights dont work Fri, 07 March 2003 03:40 Go to previous messageGo to next message
if you look closely on the transmission you should be able to find out where it plugs into ..i believe the left side of the tranny.
Re: reverse lights dont work Fri, 07 March 2003 03:43 Go to previous messageGo to next message
so it plugs into the tranny, it's not a cable coming from the tranny?
obviously I haven't been under there yet, or I might have a clue Smile
Re: reverse lights dont work Fri, 07 March 2003 03:52 Go to previous messageGo to next message
I'm not sure exactly what that box looks like, but it "should" be on the left side towards the top!
SupraPete
Re: reverse lights dont work Fri, 07 March 2003 04:55 Go to previous messageGo to next message
I've got exactly the same problem!!
two wires hanging from my gearbox, and no reverse lights.
Thing is my car was factory Auto. When some little japanese kid converted it to manual, he didn't connect up the reverse lights.
You need to track the lights down from the rear - pull some stuff off and find the colour of the wires from the reverse lights, then try and find them again in the front of the car. (or look in a manual). Then you'll need to connect one of the wires from your gearbox to earth and the other to the earth of the reverse lights (or is it positive?).
Then when the stick is in reverse the lights will light up.
If you want, we can organise a weekend and track it down in both our cars together.
Re: reverse lights dont work Fri, 07 March 2003 05:02 Go to previous messageGo to next message
sounds good Smile
I'll have to work out when I'm available... gotta get my ecu installed with paul this month, wedding next weekend ... but maybe in 2 weeks Smile
Re: reverse lights dont work Sat, 03 May 2003 01:27 Go to previous messageGo to next message
to bring up an old topic....
I had a close look at the various wires today (I was trying to fix a coolant leak)
first problem... both the wires coming from the gbox are black, which oughta make finding a positive lots of fun Crying or Very Sad
on top of that, I have 4 sets of 2-plug leads which could possibly hook into this.
one of them will be for the washer fluid pump, and should be easy to single out. I have no idea what the other 2 do
additional: there are almost 3 complete sets of wiring in my engine bay, which makes it all the more fun :\
one for the ma61, one for the 1jz, and one for the microtech
[Updated on: Sat, 03 May 2003 01:30]
Re: reverse lights dont work Sat, 03 May 2003 02:01 Go to previous messageGo to next message
Don't worry about the color of the wires coming from the box. They simply are two ends of a switch. When you select reverse gear, it merely closes the switch, allowing power to get to reverse lights. Polarity is irrelevant.
As for which set of plugs to use, just turn your ignition on and with a test light see which one has power. Use that. See if the reverse lights work. See if on one of them the wire color matches that at the reverse lights. Sometimes the plugs have little exclusion ridges such that only a certain plug type can plug together. You'll need to sus it out, but it shouldn't take longer than 5-10 minutes.
Re: reverse lights dont work Sat, 03 May 2003 02:47 Go to previous messageGo to next message
aahhhh
someone had told me that the box wires had polarity, so I was worried about blowing a fuse or light
if there's no polarity, I'll just stick it in reverse, and poke the wires in different holes until the lights come on Smile
juzzo84
Hornsby, N.S.W
Re: reverse lights dont work Sat, 03 May 2003 03:57 Go to previous message
its easy, just plug the two wires back onto the switch and bobs my uncle. Laughing
Previous Topic:KE55 vs AE86 seat rails
Next Topic:MA-70 steering
Current Time: Thu Oct 29 14:48:16 UTC 2026
Total time taken to generate the page: 0.031980991363525 seconds
