Toymods » Tech & Conversions » 2.0L 2TG
SIKTA22
2.0L 2TG Sat, 08 March 2003 00:22 Go to next message
Hey i was wondering what crank would fit a 2TG that could increase displacement to 2.0L i have my engine bored to 1.8, i just need info on what crank i can use that could fit straight in.. what else would i need after the new crank installed?
Bugman
Re: 2.0L 2TG Sat, 08 March 2003 01:20 Go to previous messageGo to next message
fit the 3t crank
celicamad85
Banned member
Re: 2.0L 2TG Sat, 08 March 2003 01:46 Go to previous messageGo to next message
it isnt just as simple as fitting a crank
if you fit a 3t crank in the 2t block i am sure you have to machine something to make clearance, and also you have to flycut the pistons
if you use the 3t block it is very simple, apart from changing all the timing gear over you need to flycut the pistons also, this is the preferred method
if you have any more questions ask rod try (thetoyman75) he would be the expert here on this conversion
cheers a lot
wayne
Classique71
Colac, Victoria
Re: 2.0L 2TG Sat, 08 March 2003 05:04 Go to previous messageGo to next message
i think the later 2tgeu blocks shared the same machining as the 3t block - so it can just go in - the 2t's definantly need internal machining to fit the 3t crank
Nods to wayne - Check with rod try - he's done this swap over and is a guru on 2tg modifications
Syc02T
Lake Macquarie
Re: 2.0L 2TG Sun, 09 March 2003 10:58 Go to previous message
I can confirm the later model 2tgeu's do fit the 3tgteu crank plus rods in, i have just done this,but the pistons are the problem.
Previous Topic:How to make an MA61 handle and stop??
Next Topic:7M-GTE ecu question
Current Time: Fri Nov 20 10:39:49 UTC 2026
Total time taken to generate the page: 0.009821891784668 seconds
