Toymods » Tech & Conversions » Can I use AE101 Manual Bits to convert an AE92 Hatch?
inertia
Can I use AE101 Manual Bits to convert an AE92 Hatch? Sat, 08 March 2003 10:41 Go to next message
Anyone know the answer to this question?
inertia
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Mon, 10 March 2003 02:22 Go to previous messageGo to next message
Anyone know?
I know the shifter bolts in... How about the;
clutch master cylinder
clutch slave cylinder
hard lines
clutch pedal assembly
brake pedal
accelerator pedal
throttle cable
associated shifter linkages
The reason is that I do not want to buy an AE101 halfcut if I cannot use it as a reference and install its manual gear in my AE92 Auto...
RSSTi
Melb, Victoria
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Mon, 10 March 2003 04:48 Go to previous messageGo to next message
All of those parts you have mentioned will fit except for the shifter bracket, the only thing i'm not sure of is the clutch pedal bracket, worst case you will have to buy a pedal set and a shifter from a 92.
Power steering rack from a 101 will also fit but you will need to use the 101 steering shaft or get a 92 shaft if you want to use the 92 plastic trims around the column.
Vic.
inertia
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Thu, 13 March 2003 12:34 Go to previous messageGo to next message
I already have a non power-steering AE92 shaft, will this do?
RSSTi
Melb, Victoria
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Thu, 13 March 2003 21:37 Go to previous messageGo to next message
No i tried this, the non power shaft is too long and wont bolt up.
Vic.
inertia
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Fri, 14 March 2003 02:56 Go to previous messageGo to next message
Cheers RSSTi,
Do you know if the AE101 brakes from a car with the 20v will bolt up to my AE92 hubs?
I hope that the 20v drive shafts will fit my hubs... Tis an Auto car, but I am told by a number of wreckers that the manual and auto drive shafts are the same.
RSSTi
Melb, Victoria
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Fri, 14 March 2003 03:43 Go to previous messageGo to next message
Use the shafts from the 20v they will fit your 92 hubs. I haven't fitted the brakes yet, from what i have read all single piston brakes and discs should bolt up, there is a bit of modification required for the twin piston ones. There was a post on twincam16.com that goes through the steps, i'll try find the link.
Vic.
RSSTi
Melb, Victoria
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Fri, 14 March 2003 04:02 Go to previous messageGo to next message
Found it
http://pub131.ezboard.com/ffwdtoyotafrm2.showMessa ge?topicID=2127.topic
inertia
Re: Can I use AE101 Manual Bits to convert an AE92 Hatch? Fri, 14 March 2003 15:10 Go to previous message
Cheers RS!
It's looking more and more like I should get a halfcut, and the bits that don't fit, by from a wreckers...
Previous Topic:If your into 4AGE's or race car construction check this site out!
Next Topic:efi temp sensor?
Current Time: Thu Oct 29 11:19:44 UTC 2026
Total time taken to generate the page: 0.0049159526824951 seconds
