Toymods » Tech & Conversions » 5MGE problems
Roseboy
5MGE problems Sun, 09 March 2003 12:35
Hi all
I've recently put in a 5MGE into an MX62 Cressida. Anyway, I've recently had the TPS fixed and the car runs really well, however it hasn't eliminated a massive hesitation at around 4000rpm. It gets up to 4000 really quickly (in all gears) then either experiences what seems like total fuel cut or "bunny hops" around then once it reaches 4500-5000rpm, it then shoots off again and revs all the way to the redline without issue.
Has anyone got any idea on what this might be? Relevant info might be:
* the car is an automatic
* does it in each gear
* will rev easily once its past the hesitation and below the hesitation
* The 5MGE computer is being used with the motor
* Does it with the TPS disconnected too
Could it be it trying to change gear as it happens around that time that it normally would? A computer issue? Not enough fuel? Restrictive exhaust? Hole in the exhaust or air-intake hoses after the AFM (quite possible there are holes)?
Thanks a lot. As you can see, I really don't have much of a clue with what the problem is.
Glen
Previous Topic:sprinter ae-86 rwd disk conversion ques?
Next Topic:How to make an MA61 handle and stop??
Current Time: Fri Nov 20 12:42:51 UTC 2026
Total time taken to generate the page: 0.0047149658203125 seconds
