Toymods » Tech & Conversions » Which fuel hose???
TA22 GT
icon4.gif  Which fuel hose??? Sun, 09 March 2003 12:43 Go to next message
Hi all,
As part of the rebuild on my TA22, I decided to fit a high flow bosch pump inside a US style fuel tank that already had a surge system.
I pulled it out the other day to check there were no problems. It works perfect is quiet and hasn't caused me any trouble.
BUT, I did notice that the fuel hose I used to join the pump outlet with is swollen and obviously not fuel resistant. The outer casing that is. What hose is available for use on an internal fuel pump?
Nitrile is fuel resistant, the problem so far is I can't find a high pressure hose that has a nitrile outer casing. All seem to be normal rubber and only nitrile on the inside walls.
The size needed is 5/16.
Hope someone can help,
Simon
http://users.senet.com.au/~mezz/stitle.htm
BansheeBuzz
Gold Coast
Re: Which fuel hose??? Tue, 11 March 2003 08:38 Go to previous messageGo to next message
8mm efi hose should do - you can buy this from any repco, global or other parts store.
about $20 a meter. Bought some recently for the efi conversion i did.
TA22 GT
Re: Which fuel hose??? Tue, 11 March 2003 10:32 Go to previous message
I used EFI hose when I first did the mod. I took it out to check everything the otehr day and found the outer rubber was swollen.
Outside the tank the hose is great.
I have now decided to use stainless steel braided hose that I had left over from another job. Its an overkill but at least it will last inside the fuel tank.
I found out the braided hose is all nitrile, I don't think all EFI hose is nitrile on the outer case which is a problem if you put it inside a fuel tank.
Thanks,
Simon
Previous Topic:4agze on a mini? reckon it wld work?
Next Topic:how many differ types of rb20 turbos r there?
Current Time: Sun Nov 1 00:20:28 UTC 2026
Total time taken to generate the page: 0.029298067092896 seconds
