Toymods » Tech & Conversions » 3T-GTEU / CT20
_ELiTeHaYDeN_
3T-GTEU / CT20 Mon, 10 March 2003 13:33 Go to next message
What should a standard 3t-gteu get on a compression test, in terms of PSI, The engine doesnt seem to be pulling like it used to. Does anyone know anything about the timing marks on the pulley, so i can check the timing/advance the timing a little?
any comments at all are appreciated.
inferno
Re: 3T-GTEU / CT20 Tue, 11 March 2003 07:22 Go to previous messageGo to next message
my 3tgte was running 110 on all cylinders, then i advanced the cam timing a notch or two and got it running 140 across all four. This is a fully rebuilt 3tgte, not yet run in, dry test, all plugs out and throttle fully open.
as for ignition timing, i'm not sure what the 3tgte stock timing is supposed to be. if it was me i would loosen the dizzy slightly and just very slowly adjust the timing until the engine revs smoother/free-er, or tighten it and take it for a spin, but i wouldn't recommend anyone who has never adjusted their timing before do it.
TA22 GT
Re: 3T-GTEU / CT20 Tue, 11 March 2003 10:43 Go to previous messageGo to next message
Standard timing for a 3T GTE is 12 degrees before TDC. There are 2 marks on the main crank pulley. Looking from the front of the engine the one most anti clockwise is TDC and simply timing so the next mark (more clockwise) is in line with the pin thats mounted to the front timing chain cover and your done. That mark is 12 BTDC.
To adjust the timing, loosen the bolt under the dizzy, run the engine and slowly rotate the dizzy until the mark lines up. Do this with the vacuum line to the dizzy removed so the timign doesn't advance at all.
Obviously you need a timing light to do this. If you don't have a light, then dont mess with it.
Good luck,
Simon
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:11 Go to previous messageGo to next message
That timing info is GOLDEN, thanks.. Im a tad confused by the vacume, advancing tho, when i disconnect the vacume hose from the vacume diaphram on the dizzy, there is no suction, even if it pull the throttle, theres never any suction there, i thought that when you put your foot down, it advanced the timing a tad? my engine does seem very very slow till the turbo charges up, then it holds yer back in the chair.
and where does that vacume line come from? cant track it back goes right down to the sump somewhere [/edit]
[Updated on: Tue, 11 March 2003 11:20]
TA22 GT
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:22 Go to previous messageGo to next message
Sounds like you could have a blocked vacuum line or even split somewhere. To check it out, do the following.
Leave it all connected, run the engine and put a timing light on the main crank pulley.
Rev the engine and check that the timing advances, if it stays still then there is a fault with your vacuum advance system.
Simon
http://users.senet.com.au/~mezz/stitle.htm
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:28 Go to previous messageGo to next message
TA22 GT = a man of much knowledge.
What kinda performance would one lose with no advancing? i assume quit a bit, got bet by a 2L N/A / 110hp celica few nights ago, edged passed me the bastard Sad
theres certinally no vacume at all no matter if i full throttle it or not, and by this i mean putting my finger over it, and i cant fell any suction, nor with it disconnected can i hear any sucking
Should there be a detectable amount of vacume there at idle? eg, you can feel it sucking?
[Updated on: Tue, 11 March 2003 11:33]
TA22 GT
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:35 Go to previous messageGo to next message
<TA22 GT = a man of much knowledge. >
Thanks...
No vacuum = poor performance.
Check the vacuum line. It can't be too complicated if there is no vacuum. There should be a small amount of vacuum even at idle.
Sounds like the advance on the dizzy is fine. You either have a split hose or maybe its disconnected or soemthing.
Fix that and you should be flying past N/A Celica's.
Simon
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:44 Go to previous messageGo to next message
What happens when boost comes on does it stay advanced or does it actaully retard timing? cause if it is still advanced when boost is on, then there could be a SHIT load of power being lost. advancing it without boost is one thing, but being advanced with boost = teh celica killer.. btw this was a 1995 celica Razz
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:48 Go to previous messageGo to next message
/ponders what someone really needs to do is make a DECENT site with all this information on it, i feel stupid, everytime i need to know something i hafta post here, ive posted like 5 threads asking stuff, because theres just no information availible anywhere else...
Im thinking I might just put a site togeither, scour the forums and make a FAQ outta all these questions.
3T-GTEU seems to be becoming quite popular..and theres still no information.
[Updated on: Tue, 11 March 2003 11:49]
TA22 GT
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:51 Go to previous messageGo to next message
The timing should stay advanced under boost. So yes, there will be much more power.
I have alot of info on my site, trouble is that there are hundreds of little things that can go wrong so its hard to cover it all.
Most of my info is about technical mods and how to do things rather than fixing the more basic problems.
Simon
TE72_Turbo
Re: 3T-GTEU / CT20 Tue, 11 March 2003 11:55 Go to previous messageGo to next message
you should definately be able to hear/feel the vaccum in the line to the distributor diaphragm. if not, run a new line straight from the diaphragm into a fitting on the plenum that you can both blow & suck through. you may need to tap into one of the existing lines with a "T" piece. the fuel pressure regulator line is a good place to go.
without vacuum, the car will be pretty doggy off boost, particularly at part throttle acceleration (less than 5" manifold vacuum) BUT the bigger problem is that the distributor will not retard timing on boost!! THIS IS BAD as you will be much closer to detonation, & we all know how well the 3TGTE pistons go with just a little bit of pinging! goodbye ring lands Crying or Very Sad
TA22 GT
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:01 Go to previous messageGo to next message
My mistake, the timing will retard under boost. Obvious since there is no vacuum and actually positive pressure.
Simon
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:02 Go to previous messageGo to next message
So it will actaully be slower under boost if it is properly connected?(atm its basically disconnected causes theres no suction) theres absolutaly no hint of pinging at all. (stock boost too, well boost gauge shows 7.1psi)
So when you floor it, it advances? then when it boosts it retards bak to normal or does it actaully retard it past normal?
[Updated on: Tue, 11 March 2003 12:09]
TE72_Turbo
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:14 Go to previous messageGo to next message
are you running the factory ECU & knock computer? This will retard timing when it senses knock.
another thing if you are using the knock computer, it may not work properly if you hook the dizzy up directly to the plenum as i mentioned earlier... I think it runs through a series of wierd valves/bypasses under the plenum in the factory setup..
No, it does not advance when you floor it, it advances more with INCREASING manifold vacuum, ie: when cruising, decelerating, or on light load. It will retard back to the base 12 degrees at zero manifold vacuum (accelerating before boost hits) plus whatever advance the mechanical weights in the base of the dizzy take it up to.
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:20 Go to previous messageGo to next message
Well if it doesnt advance timing when you floor it, and actaully retards it on boost, then by connecting it im going to see a loss? its pulling a 0-100 in like 11secs, it used to pull 7-8secs.. donno wtf is going on..nothing really has changed
Ill get a timing light tomorow and see what the timing is like.
[Updated on: Tue, 11 March 2003 12:22]
TE72_Turbo
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:24 Go to previous messageGo to next message
Then leave it disconnected if you feel its such a rocket right now Smile
if its taking you 11 seconds to 100kph, you got bigger dramas then worrying about the small handful of kilowatts that a few degrees of timing is going to make.
So do you run the factory ECU?
_ELiTeHaYDeN_
Re: 3T-GTEU / CT20 Tue, 11 March 2003 12:29 Go to previous message
yeah stock computer, i cant for the life of me figure out where the powers gone, what should a normal 3t-gteu pull 0-100 kinda times?
Its got mildly modified cams, body is TT142 Corona
[Updated on: Tue, 11 March 2003 12:53]
Previous Topic:Option for manual boxes on 1JZGTE
Next Topic:4agze on a mini? reckon it wld work?
Current Time: Sat Oct 31 19:09:18 UTC 2026
Total time taken to generate the page: 0.0098950862884521 seconds
