Toymods » Tech & Conversions » 3t-gte Airflow Meter pinouts.
elfunk
Bangkok, Thailand
3t-gte Airflow Meter pinouts. Tue, 11 March 2003 04:13 Go to next message
Well... the connector is gone. So I've traced the wires, there is Vs,Vc,Vb,THA,Ground...
I know it goes like fuel pump, ground, ground... then uhh... don't know how to order the Vc, Vs, Vb... already got the THA connected.
Can anyone tell me the pinouts from Left to right...
Cheers!
sideshow
Re: 3t-gte Airflow Meter pinouts. Tue, 11 March 2003 05:48 Go to previous messageGo to next message
lookin at the air flow from left to right
i think its
e1 fc e2 vb vc vs tha
e1 in earth
fc triggers fuel pump relay or cuircut openin relay
e2 is sensor earth goes to ecu
vb this is power to airflow think its same power that powers ecu
vc is signal from airflow to ecu
vs is signal from airflow to ecu
tha is air temp signal to ecu
elfunk
Bangkok, Thailand
Re: 3t-gte Airflow Meter pinouts. Tue, 11 March 2003 07:41 Go to previous messageGo to next message
Cheers...
I got it all connected now... started her up. The injectors won't fire at all until I ground one of the two pressure switched... (any of the switch, didn't matter.) After grounding one of the pressure switch wires, the engine fired. Are there any reasons to this? (the ecu is running on a Volvo B20 now... and I don't have any pressure switches...)
Thanks.
sideshow
Re: 3t-gte Airflow Meter pinouts. Tue, 11 March 2003 11:20 Go to previous messageGo to next message
yes the 2 pressure switches wires need to be connected
ive got notes of how to bypass the switches and what u have to do to the wiring
but like u siad u need to earth em out
to get injectors firing
the other switch is for boost i think
its rainin here and my wiring diagrams r in the car
ill get them next time if u need help
elfunk
Bangkok, Thailand
Re: 3t-gte Airflow Meter pinouts. Tue, 11 March 2003 16:13 Go to previous messageGo to next message
Cheers!!!
I am gonna borrow a scope and watch the injector frequency when I ground each of them... and see how I cam make a "fool" diagram.
Anyways, thanks!
Johnny Blade
Sweden
Re: 3t-gte Airflow Meter pinouts. Fri, 26 March 2004 22:03 Go to previous messageGo to next message
Where are these pressure switches located?
#1 is to get more fuel when charging?
#2 is to cut the fuel whith max pressure?
#3 is for the knock computer?
Byt i can't find any switches.
Anthony Kellam
Re: 3t-gte Airflow Meter pinouts. Sun, 28 March 2004 10:57 Go to previous messageGo to next message
They sit on a bracket near the brake booster on a TA63.
I was hoping these would be the problem on Boris' car but they seem to be installed/functioning fine... Sad
Johnny Blade
Sweden
Re: 3t-gte Airflow Meter pinouts. Sun, 28 March 2004 14:42 Go to previous message
OK!got any pic?
Previous Topic:3TGTE ECU
Next Topic:Need advice on replacement clutch
Current Time: Sat Oct 24 01:37:17 UTC 2026
Total time taken to generate the page: 0.0057101249694824 seconds
