Toymods » Tech & Conversions » COOL1!! - some questions about your 3s
gabe
COOL1!! - some questions about your 3s Tue, 11 March 2003 04:39 Go to next message
just curious as to what you are doing as far as intake and exhaust manifolds for your 3s conversion.
also are you running the factory ecu and what did you do about crossmember and engine mounts??
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 06:51 Go to previous messageGo to next message
Complete new manifolds need to be made Evil or Very Mad
I'll be using the standard ECU and crossmember.
As for the mounts, i'll be using a combination of the TA22 and 2S mounts.
TA22-3SGTE Trevor is the expert on this subject. I have been learning everything from him.(Thanks Trevor).
I actually received some pictures of his beast just the other night Shocked
Trevor, if you read this thread let me know if you want me to host the pictures and post them on here!
TA22-3SGTE
MACKAY
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 09:01 Go to previous messageGo to next message
Shane
Yes that's ok with me .
Trevor
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 09:34 Go to previous messageGo to next message
Here we go Cool
http://members.iinet.net.au/~shanej/TA22-3SGTE/Alt.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Diszy.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Front.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/MANIFOLD.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Mount.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Outlet.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Plenum.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Starter.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/T MANIFOLD.JPG
http://members.iinet.net.au/~shanej/TA22-3SGTE/Turbo.jpg
gabe
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 10:49 Go to previous messageGo to next message
VERY helpful cheers,
another question for trevor (or anyone for that matter).....
whats the best way to go about making an inlet plenum. ie runner length and internal diameter, and plenum volume in relation to engine capacity.
wheres a good place to get forged pistons from and whats a good price?? anyone??
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:00 Go to previous messageGo to next message
What you want forged pistons for? Trevor has 260Kw at the wheels of his beast with standard internals Shocked
gabe
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:12 Go to previous messageGo to next message
i assumed he had forgies Rolling Eyes
i read somewhere that he was running gapless rings.....?
how do you get the piston ring on if it is gapless?? Embarassed
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:14 Go to previous messageGo to next message
errr...glue?? Confused Beats me Rolling Eyes Good question
TA22-3SGTE
MACKAY
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:53 Go to previous messageGo to next message
Gabe
With gap-less ring the top ring is a normal ring and the second ring is classed as gap-less which is actually two rings half the width of normal rings which are fitted onto the ring groove with their gaps 180 degrees apart which give a near total seal , I've also sent Shane some pics of a inlet manifold I've been making .
Shane could you post the pics up here , thank you .
gabe
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:57 Go to previous messageGo to next message
trevor id love to see the pictures, and where did you get the rings from and are they any particular brand??
thanks for the help guys
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 11:59 Go to previous messageGo to next message
Sure Smile
http://members.iinet.net.au/~shanej/TA22-3SGTE/Manifold/manifold%201.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Manifold/manifold%202.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Manifold/manifold%203.jpg
http://members.iinet.net.au/~shanej/TA22-3SGTE/Manifold/manifold%204.jpg
TE72_Turbo
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 12:01 Go to previous messageGo to next message
TA22-3SGTE: Is that a 7M supra turbo?? What wheel combo are you running?
TA22-3SGTE
MACKAY
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 12:07 Go to previous messageGo to next message
Gabe
The ring are called Total Seal , Do a search for (Total Seal) Their in Sydney
gabe
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 12:25 Go to previous messageGo to next message
I think trevor is running a high flowed ct-26
could be wrong though Razz
TA22-3SGTE
MACKAY
Re: COOL1!! - some questions about your 3s Tue, 11 March 2003 12:38 Go to previous messageGo to next message
Yes it is a CT26 from a ST165 Group A , Rear wheel and housing is standard and front is 50mm wheel compared to 40mm on standard CT26 .
Trevor
jase
Re: COOL1!! - some questions about your 3s Thu, 13 March 2003 07:27 Go to previous messageGo to next message
Doesn't look like your TVIS is gonna work real well trev Wink
And I like what you've done to fix your actuator, I'm having troublt with my wastegate staying shut too. How well does it work?
TA22-3SGTE
MACKAY
Re: COOL1!! - some questions about your 3s Thu, 13 March 2003 10:55 Go to previous message
TVIS butterfly's & shafts were removed then the TVIS plate was cut out between the twin runners to port match to the head then the dividing section between the runners were blended to a knife edge as no to affect flow .
The spring on the wast-gate works very well , this spring gives me 21psi on low boost and 26psi on high , I have a bleed solenoid for high and low boost .( Switch on dash ) .
Trevor
Previous Topic:sprinter in tank fuel pump
Next Topic:4AGE RWD Alternator mounts
Current Time: Fri Oct 30 21:56:49 UTC 2026
Total time taken to generate the page: 0.03902006149292 seconds
