Toymods » Tech & Conversions » 3t-gte pressure switch confusion...
elfunk
Bangkok, Thailand
3t-gte pressure switch confusion... Tue, 11 March 2003 07:47 Go to next message
Well, I got it all hooked up now... I don't have any pressure switches. I fired her up, no pulses from the injectors at all... But then I accidently grounded one of the pressure switch wires, wrrrommm...the engine started. Why is this? I have to ground any of the 2 switch wires to get pulse...(doesn't matter which one...) Can anyone tell me how these switches work?
Thanks....
TA22 GT
Re: 3t-gte pressure switch confusion... Tue, 11 March 2003 10:49 Go to previous messageGo to next message
Check out my site if you want more info on 3T GTE's. Everything you need to know is there.
There are 3 pressure switches. One is fuel enrichment, one fuel cut and one is for the knock control.
The switches are normally open. So with them both not earthed it is saying that there is an overboost situation as well as a need for a richer mix. This is why the fuel stops.
If you have fuel enrichment only the engine wil keep running just like if you only have fuel cut it will keep running.
Basically you can't have fuel cut (set to about 7.5 psi) without fuel enrichment because its set to about 2 psi.
Hope this helps,
Simon
http://users.senet.com.au/~mezz/stitle.htm
elfunk
Bangkok, Thailand
Re: 3t-gte pressure switch confusion... Tue, 11 March 2003 16:02 Go to previous message
Oi... I get it now... (stupid me...)
Thanks!
ps. Real nice site you got there...
Previous Topic:Bolting CT26 to 3TGTE
Next Topic:TA 22 Weather strips
Current Time: Thu Oct 29 18:53:51 UTC 2026
Total time taken to generate the page: 0.0065751075744629 seconds
