Toymods » Tech & Conversions » sprinter in tank fuel pump
purpleminiep
Mentone
sprinter in tank fuel pump Wed, 12 March 2003 10:38 Go to next message
Hello
If i want to run an efi system can i addapt a in tank pump in a standar sprinter fuel tank. I had a look inside the tank and it has two baffles, one on each side of the pickup. There is not one at the back because the fuel sender would get in the way.
Any help would be great and please dont say use wogadore fuel pump externally
Brad
riceboy
Japan
Re: sprinter in tank fuel pump Wed, 12 March 2003 13:20 Go to previous messageGo to next message
my Sprinter has an in tank pump apparently but unfortunately i don't know any of the details as i didn't do the conversion.
Pumpkin
Toymods Board Member
Re: sprinter in tank fuel pump Wed, 12 March 2003 21:14 Go to previous messageGo to next message
SSS Automotive had the genuine EFI tanks for the sprinters for sale a while ago..
EVOSTi
cambo
      no
Re: sprinter in tank fuel pump Thu, 13 March 2003 05:25 Go to previous messageGo to next message
forst of all whats the problem with using an external pump? its prob the easiest way to go. if not i think you can use an ae82 twincam one? someone correct me cause im not sure.
Pumpkin
Re: sprinter in tank fuel pump Thu, 13 March 2003 05:54 Go to previous messageGo to next message
The problem with external pumps is that you should be running a lift pump and surge tank.. And there noisy and smelly. Efi tanks have baffels to prevent fuel surging .. Just makes it a whole lot easier ....
JDM hachi
was adelaide now newcastle
Re: sprinter in tank fuel pump Thu, 13 March 2003 07:19 Go to previous messageGo to next message
in regards to external pumps and aussie spec sprinter tanks, when i put the 4age in my first sprinter i used a VL commodore pump mounted above the diff, no clearance probs (even with low springs) no surge probs, noise was suppressed with rubber mounted bracket, and since it didnt leak, it obviously didnt smell! mounted up to the standard lines it worked sweet, but admittedly the engine was left resonably stock, so i can't comment on problems which may arrise with higher output motors using this type of system. my levin import used a pump which looked identical to an aw11 pump, and when i fitted the gze the in tank pump was replaced with an sr20det item (only just fit in the tiny hole for factory in tank pump)
T.J.
Re: sprinter in tank fuel pump Thu, 13 March 2003 09:55 Go to previous messageGo to next message
A friend of mine has just had his sprinter tank modified by taking it out and getting a vn commo tank from the wreckers and getting the vn baffels and pump placed in the sprinter tank.
All up cost was around $250-$300.
This gives near no pump noise and is much cleaner and quieter than any external option.
Best way to go in my opinion...
Good luck.
IRA11Y
Club Member
Re: sprinter in tank fuel pump Thu, 13 March 2003 10:59 Go to previous message
If ive answered this question once ive answered it a million times Rolling Eyes
do a search all the info is there..or just read the articles section Shocked
Previous Topic: 70-75mm Throttle Body ???
Next Topic:COOL1!! - some questions about your 3s
Current Time: Sat Oct 31 08:52:41 UTC 2026
Total time taken to generate the page: 0.036710023880005 seconds
