Toymods » Tech & Conversions » 1 bar vs 2 bar MAP sensors?
TWSTD
Auckland, New Zealand
1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 20:18 Go to next message
Ive been going over this in my head for a couple days and was wondering if anyone here could shed some light on the matter for me.
OK - so NA cars come with 1 bar MAP sensors and most turbo cars come with 2 car ones (some with 3 bar).
Now all a MAP sensor does is sense the manifold pressure and convert this into a voltage and output it to the ECU which then looks up values in a table and supplies fuel and timing accordingly.
So how do 1 bar and 2 bar MAP sensors differ? Now im unsure about what range of voltage output to expect (anyone know?) but would i be correct in thinking that a 1 bar MAP outputs say 0-5v on a certain (possibly linear?) scale, and a 2 bar sensor say puts out 0-10v on the same scale.
Or, is it that these 2 sensors output the same voltage range, say 0-5v, but the scale is different (yet possibly still linear)?
Can anyone shed some light on this?
HedgehogSandwich
UK
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 21:06 Go to previous messageGo to next message
Theyre all 5volts (well,most of them) All that happens is the output voltage is halved on a 3bar as opposed to a 2 bar.
Ie 1bar pressure one a 2bar map=5v. 1bar pressure on a 3 bar map=2.5v.
roger
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 21:56 Go to previous messageGo to next message
HedgeHog has it right a 2bar bassically halves the calibration ie
1 bar pressure on a 1 bar sensor gives 5 volts.
1 bar pressure on a 2 bar sensor gives 2.5 volts.
2 bar pressure on a 2 bar sensor gives 5 volts
1 bar pressure on a 3 bar sensor gives 1.67 volts
2 bar pressure on a 3 bar sensor gives 3.34 volts
3 bar pressure on a 3 bar sensor gives 5 volts
this is only a rough guide there are some curves around for the GM sensors if you search.
Roger
HedgehogSandwich
UK
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 22:38 Go to previous messageGo to next message
Just to clear up why the 2bar/3bar thing for those that are wondering..
Roger, i think you describe the pressures the same as me ie a 1bar map is 14.7 psi boost pressure on the sensor.. however some people call this a 2bar map as atmospheric pressure on the map sensor is 1bar, so 1bar of added boost is actually 2 bar pressure, which i think is what twztd refers to them as.
Its the same thing really, just that roger explained it better ! Very Happy
[Updated on: Wed, 12 March 2003 22:38]
Ribbo
Northern Beaches
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 22:42 Go to previous messageGo to next message
ok a question just off to the side, but if ive got a microtech and want to go turbo, currently n/a, do I need to get a new MAP sensor or is there a way to trick it or something to handle to boost?
HedgehogSandwich
UK
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 22:55 Go to previous messageGo to next message
no.. you need a new one.. you cant turn a 1bar into a 2bar.
gold28
Madrid - Spain
Re: 1 bar vs 2 bar MAP sensors? Wed, 12 March 2003 23:35 Go to previous messageGo to next message
You can dodgy it by putting a bleed on it but this convenience comes at a cost. I am guessing that if you are using a Microtech, this is your primary sensor for calculating airflow and density. In this case, putting a bleed on it could stuff up your fuel metering.
If you do have an aftermarket ECU though, just get any old 3bar map sensor and chuck it in. Tell the computer the different map values and away you go.
HedgehogSandwich
UK
Re: 1 bar vs 2 bar MAP sensors? Thu, 13 March 2003 00:58 Go to previous messageGo to next message
That just defeats the fuel cut, it doesnt allow you to measure the increased pressure.
roger
Re: 1 bar vs 2 bar MAP sensors? Thu, 13 March 2003 00:59 Go to previous messageGo to next message
Just to clarify.
when I say 1 bar I mean atmopheric pressure(atompheric pressure is 1 bar) when I say 2 bar you are at atmosphere + 14.7psi
A 1 bar sensor will only measure from -14.7psi (vacumn) to atmosphere.
A 2 bar sensor will go from -14.7psi to +14.7psi in relation to the atmosphere. Here you can run up to 14.7psi of boost, you can run more but you will get the same fuel deliver as at 14.7psi
A 3 bar sensor will go from -14.7psi to +29.4psi in relation to atmosphere. Here you can run up to 29.4psi of boost, you can run more but you will get the same fuel deliver as at 29.4psi
Hence a 1 bar senor will only take up to atmopheric pressure ubove this and you will get the same fuel as you would at atmospheric ie run 7 psi but you will only get the same fuel as at 0. If you change to 2 bar sensor your computer must be remaped. By the way I have a couple of 3 bar sensor if anyone wants 1, will swap for 2 bar.
roger
[Updated on: Thu, 13 March 2003 01:05]
Ribbo
Northern Beaches
Re: 1 bar vs 2 bar MAP sensors? Sun, 16 March 2003 20:46 Go to previous messageGo to next message
where whould you get any old 2 or 3 bar map sensor? and how much are they worth?
is it more accurate to run a 2 bar one if you are only going to be running say 6 or 7 psi, but in the long run might run more if get gze bottom end.
TWSTD
Re: 1 bar vs 2 bar MAP sensors? Sun, 16 March 2003 20:59 Go to previous messageGo to next message
Ribbo: - I imagine any old wrecker - here in NZ we have "pick a part" where u take yr own tools and yank the parts u want and its way cheaper than regular wreckers - look for a fact turbo car - sat a startlet GT for example - it should have a 2 bar sensor. You will then need to retune your microtech because the signals it will be getttin fed form the MAP sensor will be half the voltage (2 bar) that they used to be.
Ribbo
Northern Beaches
Re: 1 bar vs 2 bar MAP sensors? Mon, 17 March 2003 06:26 Go to previous messageGo to next message
cool thanx
the sensor is in the computer isn't it? Is it hard to change the map sensor in the computer?
ive got a hose running from inlet manifold to computer
Twinky
N.S.W
Re: 1 bar vs 2 bar MAP sensors? Mon, 17 March 2003 06:43 Go to previous messageGo to next message
ok guys heres a quesiton 4 you.
My mate had an accident in his corolla (4age tvis) and the beaters must of taken stuff out to paint a part of the engine bay. Now after his car was fixed up, we got it running, but it was lacking power big time. The other day I was looking to see which loom the map sensor went on (so i could see to wire up my 4agze in my car) and im looking and looking 4 it and cant find it. Theres no map sensor but the plug is there.
Now 4 almost a year this car has not been able to rev over like 5-6 grand and is way under powered getting beaten by shit boxes. We just thought the motor was fucked from the accident.
Would not having the map sensor cause this prob?? I thought it would be running in limp mode. But wouldnt the check engine light be on?
I just couldnt belive it didnt have one! Shocked Shocked
STUPID PANEL BEATERS.
[Updated on: Mon, 17 March 2003 09:01]
HedgehogSandwich
UK
Re: 1 bar vs 2 bar MAP sensors? Mon, 17 March 2003 11:24 Go to previous messageGo to next message
No Message Body
[Updated on: Mon, 17 March 2003 11:27]
roger
Re: 1 bar vs 2 bar MAP sensors? Tue, 18 March 2003 03:26 Go to previous messageGo to next message
Twinky,
If your friend has no map sensor where there is supposed to be one. Yes the car would run like shit under any load, and could cause serious engine damage. Don't no much about the 4AGZE engine but if its map sensored, get one in there the results will be amazing Smile
SUPRAGTE
North Sydney
Re: 1 bar vs 2 bar MAP sensors? Tue, 18 March 2003 07:18 Go to previous message
Ribbo if your going Microtech you don't need to buy a MAP sensor,
its comes with one internally.
Previous Topic:In-tank fuel sensor question - AE86
Next Topic:TA22 suspension advice!!
Current Time: Sun Nov 1 16:09:47 UTC 2026
Total time taken to generate the page: 0.00518798828125 seconds
