Toymods » Tech & Conversions » 4AGZE Mount Help!!!
djb23_20v
Wollongong
4AGZE Mount Help!!! Sat, 15 June 2002 11:17 Go to next message
Hi guys,
I need some help with my rear gearbox mount in my '90 Corolla SX into which I've fitted a 4AGZE with ZE gearbox. I bought the engine and box from SSS, and they gave me a ZE front gearbox mount, and I've tried to fit the longitudinal member but the original rear gearbox mount no longer fits. The ZE box has the correct ZE bracket.
Help, what do I do? Do I need a ZE rear gearbox mount, or do I need to do some cutting and shutting to the original rear gearbox mount?
Darola
Taree, 4h nth of syd
Re: 4AGZE Mount Help!!! Mon, 17 June 2002 05:55 Go to previous messageGo to next message
hey there, the way i did it in my ae82, is i used the old mounts with the gze brackets on the box, its working fine for me
[mikey]
Re: 4AGZE Mount Help!!! Mon, 17 June 2002 13:09 Go to previous message
use the ae92 x-member, front mount should fit as normal.... you will need to redrill the rear gearbox mount further back..... and space the x-member down by what it takes to clear the bellhousing and driveshaft.... use a metal block and longer bolts...30mm worked for my AE82...but ae92 might be slightly different....hope it helps
michael.
Previous Topic:MA61 Shocks/Springs
Next Topic:what engine mounts for a 1ggte???
Current Time: Fri Oct 23 12:04:53 UTC 2026
Total time taken to generate the page: 0.0050511360168457 seconds
