Toymods » Tech & Conversions » Spark Plug dramas
CamryMan
Spark Plug dramas Sat, 15 June 2002 12:45 Go to next message
There has been a funny smell coming out of the exhaust so had a look at the spark plugs to see if it was running rich. Instead of a black carbon deposit, I find a strange rusty brown deposit. Mechanic tells me that the plugs are overheated. So I might try a colder plug.
The plugs were NGK Iridiums and had been used for about 15,000Km. I always thought Iridiums were long life but after some reading on the Denso website, only OEM Iridiums are long life. I assume this is somehow the same with NGK
Standard plugs - approximately 20,000km
Platinum plugs - approximately 80,000 - 100,000km
Iridium Power high performance plugs - approximately 15,000 - 20,000km
Iridium Original Equipment long-life plugs - approximately 150,000km
What is surprising is that the NGK Iridiums costed about $16.80 each!
Celica_RA40
Re: Spark Plug dramas Sat, 15 June 2002 12:56 Go to previous messageGo to next message
i hate to say it but a rusty brown colour sounds preety close to perfect
if they are black they are not cumbusting fuel properly ie a rich ratio and carbon deposits are forming if they are white there is too much heat ie lean. if you can look in the back of a haynes repair manual it gives a spark plug chart telling you what the colours mean
jza70-mel
Perth WA
Re: Spark Plug dramas Sat, 15 June 2002 13:15 Go to previous messageGo to next message
Accoding to the NGK (Aust) website, they indicate irridium plugs can last (up to) 160,000kms!
They seem to say that their precious metal electrode plugs last quite a bit longer than standard.
http://www.ngkspark.com.au/products_spark_plug_ind ex.htm
Soarer
Wollongong
Re: Spark Plug dramas Sat, 15 June 2002 14:20 Go to previous message
Plugs can go orange coloured due to fuel additives, or could even be normal. I pulled out my 100,000km NGK-R platinums and they were orange-ish in colour.
Previous Topic:Engine conversions for a T-18
Next Topic:what engine?
Current Time: Fri Oct 23 02:06:23 UTC 2026
Total time taken to generate the page: 0.013351917266846 seconds
