Toymods » Tech & Conversions » Throttle Body conversion for 2TGEU
7mgtema71
Throttle Body conversion for 2TGEU Thu, 13 March 2003 21:49 Go to next message
Hi guys,
As most of us know, the standard Throttle Body is one of the main restrictions of the STD setup. I read some where ages ago that you could fit a larger throttle body from a cresida or a corona (not too sure) onto the original efi setup of the 2TGEU. What i read was an easy conversion that bolted straight onto the plenum and did show obvious improvements.
If any one has done similar conversion or could shed any light on the situation i'd be much appreciative. Thanks!
Frank
ddeane
PNG
Re: Throttle Body conversion for 2TGEU Thu, 13 March 2003 22:45 Go to previous messageGo to next message
Gidday
Not sure about the throttle body but understand that an effective plug in mod is to use a 4AG AFM. appears as though it works a treat.
Craig
gene
Re: Throttle Body conversion for 2TGEU Fri, 14 March 2003 01:14 Go to previous messageGo to next message
about adding the 4age AFM... Is any ECU adjustment required? or is it a straight plug in and go ? Razz
7mgtema71
Re: Throttle Body conversion for 2TGEU Fri, 14 March 2003 02:13 Go to previous messageGo to next message
Yeh, good point, but the AFM wont be a problem for me as i going towards the map sensor path.
gene
Re: Throttle Body conversion for 2TGEU Sun, 16 March 2003 04:27 Go to previous messageGo to next message
bump...
anyone know about the ecu thing?
gmsta27
Fl
Re: Throttle Body conversion for 2TGEU Mon, 17 March 2003 02:26 Go to previous message
I have a 1982 5mge throttle body and afm that will go on my 2tg when i get the wiring harness figured out the ecu is from a 22re all parts are from analog efi. I have been told that these will work with little or no modification the only change was 210cc injectors and a change on the afm spring tension.
Greg
Previous Topic:'92 soarer steering question.
Next Topic:Does anyone have Air/Con on an 18RG
Current Time: Fri Nov 20 07:32:33 UTC 2026
Total time taken to generate the page: 0.005958080291748 seconds
