Toymods » Tech & Conversions » Good new turbo to replace CT26 on 3SGTE
benmeyer
Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 00:01 Go to next message
I'm looking for even more power than than the ct26 will provide when i do my gte swap into the 162. What are good brands and indeed good sizes for the 3SGTE? also, do you have the exact model numbers? i think the ct26 has a ceramic bearing, would ball bearings be better? thanks guys
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 00:27 Go to previous messageGo to next message
I have been told the turbo off a 7MGTE is a good starting point.
benmeyer
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 00:38 Go to previous messageGo to next message
got a model number? how about aftermarket turbos?
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 00:54 Go to previous messageGo to next message
Dont know model number sorry.
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 01:31 Go to previous messageGo to next message
Its a single-entry CT26...
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 01:42 Go to previous messageGo to next message
Thats right, now I remember. Then get it hi-flowed.
Danners
Central Coast, NSW
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 02:02 Go to previous messageGo to next message
A popular one is taking the CT26 from the 7M-GTE and getting it hi-flowed with the internals from a Garret T04 Turbo.
http://www.jblmk3.com/186f4c60.jpg
for more info ^^ If you decide to go for this let me know! i'm interested in getting it done as well
Dan Very Happy
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 02:17 Go to previous messageGo to next message
Farrrk Yeah. That looks good. How much would that cost?
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 02:43 Go to previous messageGo to next message
That would have MUCHO lag on a 3SGTE. You'd be better off looking for perhaps one of the Garrett GT series turbos. I've heard the GT25R is a popular upgrade for an MR2, so it'd be perfect for you probably.
Re: Good new turbo to replace CT26 on 3SGTE Fri, 14 March 2003 03:20 Go to previous messageGo to next message
I dont think there would be to much lag at all. All that has been changed is the compressor! Not the turbine!
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Sat, 15 March 2003 09:08 Go to previous messageGo to next message
Shane changing a compressor can INDEED create a lot of lag .In order to make a decent amount of power these turbos usually undergo BIG mods and end up somewhat laggy .
It all comes down to how much power is needed
If you can get a ct20b twin entry turbo and look at a wheel change and extrusion honing for manifold turbo housing and intake .for around $2500 the total package WILL (and has) made 320 H.p++++ to all fours this is good for low 12 second 1/4 mile (or quicker) .You will still need a good clutch
If youd like to see how good this setup goes im helping a mate prepare that exact setup for the nationals this easter .come along and see the results
Otherwise frank is dead right go for a gt turbo but unless your budget is close to $10,000 then i would look at the above mod
turbo $3,000
manifold $1500
ecu $2500 ++
Clutch $1,000 ( engine has to come out so add more$$ unless diy )
injectors 600
then you need intercooler ,plumbing, gaskets ,boost control etc etc etc
Re: Good new turbo to replace CT26 on 3SGTE Sat, 15 March 2003 09:23 Go to previous messageGo to next message
320Hp seems like a bit of a crap figure considering that TA22-3SGTE Trevor is getting 260Kw at the wheels using the standard turbo as far as I know!
Re: Good new turbo to replace CT26 on 3SGTE Sat, 15 March 2003 09:25 Go to previous messageGo to next message
Take a look at THIS PAGE.
Its from Cypher Industries in WA. They offer a bolt-on ball-bearing upgrade for a Celica GT4 which would only require new oil and water lines as it bolts to the standard manifold.
If you were keen on a totally different turbo, you could pick up a GT25R, they list the price as high 2000's or something.
All options to consider.
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Sat, 15 March 2003 23:20 Go to previous messageGo to next message
hey bolt on to factory manifold thats AWESOME !!.although to get 320 4whp you would need more like 470 h.p the big frame custom job at $3800 is promising . Saves like $700 on manifold but to get more than 320 rwhp youll still need ecu injectors etc
shane
the turbocharger i am talking about IS a stock turbo for an ST205 WRC 3sgte .they are just a much more efficient turbo .EVEN the factory dump pipe can BARELY be improved on
Considering that a stock Group a st 205 makes about 205 HP @ wheels ( 3 inch exhuast) . then 320 is a considerable improvment .Remember everything else is stock ecu,intercooler ,injectors and this is a conservative figure based on around 17 psi boost .(wait and see)
The actual wheel has only been replaced with an almost identical steel item so no additional lag has been introduced .In fact the honing improved flow so much that lag has slighlty decreased
320 4whp = 238 4wkw @ all four wheels
in rear wheel drive configuration the power loss (from flywheel) would be at least 15% LESS than a 4 wheel drive
the power loss figures from TRD for MOST toyota transmission setups are
RWD manual 15% loss
RWD Auto 22% loss
4wd MAN 32% loss
i'll assume the 3sgte is manual
So 260 rwkw = 85% of engine H.p so 260/85 x 100 = 305 kw @ engine
and 238 4wkw = 68% of engine h.p so 238/68 x 100 = 350 kw @ engine
CRAP figue i think not !!!the engine is making some 45 KW more
from $2500 worth of modifications
hmmmm a 1400kg car with a 5 puck ceramic clutch and can be launched at 6000 rpm with 238 4wkw (more than ANY 1j has pulled with stock turbos).
AND it was only good for low 5 sec 0-100 when it has making 165 4wkw
YEP its crap Very Happy
[Updated on: Sat, 15 March 2003 23:55]
Re: Good new turbo to replace CT26 on 3SGTE Sun, 16 March 2003 00:09 Go to previous messageGo to next message
The figure I quoted was for a 165! But i'll be interested to see how you got with what your doing!
Also the CT20B turbo fitted to the ST205 is a ceramic item! Not something I would like to have fitted to an engine producing big power!
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Sun, 16 March 2003 12:13 Go to previous messageGo to next message
shane it would really help if you actually read what i say
165 or 205 the are basically the same engine different turbo different ecu
the best way for him to improve that power figure would be to change to the ct 20b
The only component that is ceramic is the wheel itself .high H.p is not an issue with ceramics only high boost.
ceramic wheels cannot handle the heat that is generated at high boost .However this is relative to the actual compressor efficiency .if a turbo is still within its efficiency range at 20 psi and has a ceramic wheel then reliability is not an issue . the factory boost cut is 18 psi .and the ecu maps to 17(standard).ct 20b's will handle 17 psi all day .and extrusion honing a turbo charger actually decreases compressor temps
The only reason for changing the wheel was so that more boost could be run at a later date
As far as using that turbo in high h.p .the ST205 WRC is the wrc spec .in other words that is the turbo designed for toyotas wrc gt4
So toyota intended that turbo fot HIGH h.p applications
The ct26 was actually considered as it has been extensively previously modified with good results .however after doing my homework. The guy doing the turbo advised me to use the ct20b as he has successfully modified this turbo to produce well over 500 h.p before
you are more than welcome to inspect the setup at the nationals
If you bring your Celica along i can show show how to PROPERLY mount the 1j in the Ra23 so that it handles MUCH BETTER than a 23 with an 18rc
[Updated on: Sun, 16 March 2003 12:19]
Re: Good new turbo to replace CT26 on 3SGTE Sun, 16 March 2003 12:33 Go to previous messageGo to next message
I'm not using a 1j!! Where did that come into the story?
So how is this guy modifying the ct20b to get over 500hp? I'll be interested in this as long as the ceramic wheel gets dumped! There is no way in hell i'll be running a ceramic wheel on a hight hp high boost engine!
But i'm interested anyway! Who is this guy and how much is he charging to do the modification?
Also I dont know what the standard boost cut is on the ST205, but I have the mines ecu with the higher boost cut and I hope to be using this to its full potential!
Cyber-punk
Brisbane, QLD
Re: Good new turbo to replace CT26 on 3SGTE Sun, 16 March 2003 12:47 Go to previous messageGo to next message
Maybe he puts a NOS sticker on the turbine housing and some neons around the exhaust manifold?
benmeyer
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 11:50 Go to previous messageGo to next message
Or perhaps he has a speed-increasing bodykit or one of those subwoofers which adds nearly 300hp?
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 12:59 Go to previous messageGo to next message
No wonder you guys drive slow cars
Shane sorry i had you confused with another guy on another forum that is always giving me shit .his handle is cool 1j ( i went back and checked).with a pic of a red ra 23 i was sure you where the same guy (always whinging about how he cant get it to handle). ANYWAY sorry about the mix up
ring ATS is melbourne they can do the steel wheel and organise the extrusion honing .as i said before to get this result total cost is $2500
here is a power run of the exact same setup on an st185 .It was using the shitty factory air/air unit .and a LOT more work has gone into the manifolds on the st205
but i guess you get the idea full results on wy webpage in about 3 weeks
as you can see the power run was done in third gear a reasonable hold figure here would be 310-315
http://home.kooee.com.au/celicamad/ported%20ct20b.JPG
[Updated on: Mon, 17 March 2003 13:04]
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 13:10 Go to previous messageGo to next message
So with the steel wheel and the extrusion honing the turbo would be capable of flowing 500hp? I wouldn't mind spending $2500 on that turbo for this kind of power potential!
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 13:19 Go to previous messageGo to next message
ATS-Turbo
20 Assembly Drv Tullamarine 3043 (03) 9335 1254
Is this the place dude?
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 13:33 Go to previous messageGo to next message
Also does the waste gate actuator get modified somehow to handle any extra boost?
ddeane
PNG
Re: Good new turbo to replace CT26 on 3SGTE Mon, 17 March 2003 21:57 Go to previous messageGo to next message
Gidday
This is most probably extending the discussion a little but if the 3SGTE can cope with the flow of a CT26 would there be any problems using a CT26 on a 1ggte. I read on an earlier threat that you would most like face excessive lag problems. I have a 7MGTE Ct26 that I would like to use??
Craig
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 04:58 Go to previous messageGo to next message
Well I rang ATS today and the guy didnt mention anything about modifing a CT20 for 500hp or more! The only thing that he said is that they fit a compressor wheel from a VL turbo!
So whats the secret word to get information on the ct20 that flows 500hp?
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 09:07 Go to previous messageGo to next message
as i said ATS can do the steel wheel mod and will put you on to someone that can do the extrusion honing .(THEY DO NOT DO EXTRUSION HONING).a wheel mod alone would increase the turbos flow by about 20 H.P .
ATS wouldnt even have a clue how much was gained from the honing .there is only one guy in Melbourne that does extrusion honing so really cant get it wrong .
i had the extrusion honing done by a mate as a one off .he wasnt any cheaper but spent a lot of time getting the design perfect
and yes i would suggest porting the wastegate
And no the specs are not available its not my turbo and the owner wants to to keep it to himself although i dont agree with this i have to respect it
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 09:14 Go to previous messageGo to next message
ddeane
Sorry i missed your post .yes a ct 26 would be a good swap for a 1ggte lag would be no more than a 3sgte .
In fact the reason im playing with these is im considering a kit for 1ggte and 1jzgte .
BUT having said that racecraft in melbourne sell a turbo and manifold for a 1ggte that uses a 550 h.p garret gt turbo .
the results have been AWESOME with over 300 kw at the wheels using stock internals
THIS IS THE BABY FOR BEST RESULTS
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 09:17 Go to previous messageGo to next message
Well i've had enough of this crap! When I see a CT20 flowing 500hp i'll belive it!
For starters you would have to do something to the wastegate to stop it from opening!
From your dummshit attitude it sounds like your either full of shit or your just relaying something someone else said!
I dont know why you even bother posting on this forum! So far every post you have made in this thread has not been very clear at all and then when i ask you something you reply with some fucked up dummshit remark! So from this point on untill you change your attitude, or untill you make your posts clear I'll just belive you are full of shit!
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 12:16 Go to previous messageGo to next message
what a BABY did you want me to ring them and organise it all for you .perhaps i can come and fit it as well .
maybe i can detail your car for you while im there ????
what was so unclear about this .
you ring dem ...day organize bloke to port turbos for u
did you even ask about extrusion honing do you EVEN know WHAT it is ????
you said
so one minute its a crap figure the next 470 is to unbelievable to be true
so which is it a crap figure or to good to believe
whos talking shit now ????
did it even occur to you that the factory wastegate MIGHT just handle 500H.P...HAVE YOU EVER TRIED IT
NO thats right some bloke in a pub or on a forums reckons it wouldnt work cause his mates cousin tried it(who is actually porking his sister)and when they ported the turbo with a gernie and some sand it NEVER WENT NO GOOD
If you even just looked at the link danners posted a few posts ago you would see a ct26 making MORE than 500 Hp you ignorant KNOB
http://www.jblmk3.com/id97.htm
ive given a few of my designs away for free on here before only to have them riduculed by people like you that sit at home and think........ohhh i dont think that would work ..without even trying them
well thats only because youve never tried
get off your computer and actually BUILD a real car .Ive built
10 or more serious high performance cars and have almost finished a 700++ h.p celica .
in 1988 i built a 200 hp @ wheels car thats ran 0-100 in 6 secs .where were you ...even born or just learning how to pull yourself off
stop doing it ..read a little and learn like i have been(and still am ) from people that actually do this stuff
the power graph above is from my dyno ya goose !!
ALL YOU HAVE TO DO IS ACTUALLY READ WHAT I SAY......YOU CAN READ RIGHT ????
and then make the call . now try again tomorrow ring ats and ask them for the name of the guy in Melbourne that does the power porting .i think its called specialized power porting
youve got the shits with the forum becasue everyone wont go out of their way to all the work for you
i can hear your call now
"yeah mate umm can i get one of doze 500 h.p tirbos maate .like doze fully sick one dat guy on toymods got
fuck im glad i didnt give you his number .hes already sick of knobs like you telling him his proven shit wont work
i' bet youve got a pod filter a VERY expensive blow off valve
a crap restrictive exhaust . a monster tacho and have apersonal best 1/4 mile time of 14.6 ......full siik maate
change your name to tool 1 ...its far more fitting
i couldnt give a shit if you think im full of shit
ive got nothing to prove to you i do it on the drag strip
PLEASE DONT do it !! ....NOT THAT YOU WOULD OF ANYWAY
perhaps youd like to line this st 205 up it will be on the road in about three weeks
nah your cars not quite right at the moment
not running enough boost and your mummy cant give you pocket money till next week
you couldnt posibly have time to actually work on a car youve been too busy racking up 2647 posts
Laughing Laughing Laughing Laughing Laughing
Re: Good new turbo to replace CT26 on 3SGTE Tue, 18 March 2003 12:27 Go to previous messageGo to next message
Well you've just proven your full of shit! You cant even read your own posts!
Not one of your posts made sense at all! And when I asked you a simple little queston you got narky and said some shit!
You've been babbling some shit about a CT20 that will flow 500hp plus but you have nothing to prove this(so whos full of shit?).
You said "ring ATS is melbourne they can do the steel wheel and organise the extrusion honing .as i said before to get this result total cost is $2500"
So I ring them up and ask what they can do with a CT20! They say we can only do a wheel exchange for $690.
Now how the fuck am I meant to know from your posted shit that I was meant to ask for contact details for someone else to do the job?
Maybe you should be more clear! Maybe you should read all your past posts and you would realise that none of them made sense!
In fact the only post by you in this thread that made a tiny bit of sense is your last one where you acted like a school girl!
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Wed, 19 March 2003 07:21 Go to previous messageGo to next message
Sorry i didnt relaise that a dyno graph wasnt enough proof ...fuck you are DUMB!!!!
did you even go to school????
you are what we commonly call a GUNNA.....gunna do this gunna do that but expect everyone to go out of their way to do all the homework for you
and eventually NEVER do it anyway Twisted Evil
from what ive been told you haven't even got the engine yet .
anyway don't bother replying to this cause Ive actually got two fast cars to work on UNLIKE you .so i haven't got time to waste my time on uneducated fools like you
Re: Good new turbo to replace CT26 on 3SGTE Wed, 19 March 2003 08:17 Go to previous messageGo to next message
Well you obviously didn't read all your past posts! As I said, I cannot understand them! If you read them you will understand that I do not understand them! You need to be more clear!
I was happy with all the posts but I just could not understand them, thats why I kept asking you questions! But your reply was always a stupid remark! This is why I was lead to believe that you were full of shit! If your replies were to the point and not just an attempt to sidestep the question, everything would still be fine!
Also I don't know you told you I don't even have an engine yet but I have posted over a link to over one hundred photos of it! I have also sold parts from the half cut on here! So this proves the fact that you believe any dribble that you hear!
Also that dyno graph does not prove anything about a CT20 flowing 500HP+.
So please read your past posts! I am willing to settle this in a civil way, but you need to understand that I did not understand your posts! You also need to more to the point when making a post!
bergerac
Re: Good new turbo to replace CT26 on 3SGTE Sat, 22 March 2003 06:32 Go to previous messageGo to next message
Not likely on the stock injectors and fuel system. 320hp at the flywheel would be pushing it. With a 30% drivetrain loss 320hp at the wheels would be over 450hp at the flywheel, the ST205 has 239hp at the flywheel stock, thats an amazing a slightly modified stock turbo that adds over 200hp!
Quote:
shane
So your saying having the cat right on the turbo outlet is a design you wouldn't change? Its strange that when I replaced my dump pipe with a 3inch one I gained .1bar boost in the mid range and the turbo spools up much faster. That was just changing the dump pipe, the rest of my exhaust is still stock.
Quote:
165 or 205 the are basically the same engine different turbo different ecu the best way for him to improve that power figure would be to change to the ct 20b
Have you even looked at either of these engines? The ST205 has a different intake manifold, head, injectors, intercooler and throttle body just to name a few differences. As a matter of fact the CT20B wouldn't even go on a ST165 engine without a modified or custom manifold.
The ST205 WRC turbo is exactly the same and a normal ST205 turbo. You must be very naive if you think Toyota used a CT20B on their Group A car, maybe in a Group N car but they made much less power. The ST205 never ran in WRC mainly because the class didn't even exist at that time.
Maybe you should have a look at a real ST205 before you go around spreading your 'expertise'.
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Sat, 22 March 2003 13:22 Go to previous messageGo to next message
actually your right about two things i should perhaps have written group N assumed (god forbid) that the group A badge on the centre console meant exactly that( being very technical).
but toyota did develop st 205 for rally application as to when or how it was used in competetion(or if at all) i do not claim to know
but based on the fact that i dont actually know or care i accept you are probaly correct.
i was merley trying to pont out the BREEDING behind this model
second of all i am aware of a person that HAS done this conversion onto an st185 i cant swear by it but im sure he used a factory manifold .again i assumed the 165 was the same as 185
happy to put shit on people when they are wrong equally happy to admit that i am wrong as well
BUT CAN YOU?????????????
seems to me you just wanted to join the "ya couldnt POSSIBLY get that much power bandwagon"
NOW TO THE STUFF THAT I HAVE ALREADY DONE AND KNOW WORKS
as far as the dump pipe mod ..well that was easy remove the cat and fit a high flow after market further down the system .this gave a similar result to that of which you have already described . in fact this car made 220 h.p @ whels at 16 psi and this was noted in h.p comp at the toyota nationals .
having said that a custom dump pipe IS in the making .BUT gains are only expected to be minor .the main reason for changing the design is i feel the new design will remove more underbonnet heat as we are also having it ceramic coated .as far as increasing flow that is highly unlikley
using the factory 440 cc injectors and the standard manifold at 294 rwhp duty cycle was 90 %
so we decide to extrude hone the intake manifold .
the much smoother manifold allowed for less manifold wall quenching and faster air fuel flow .
cylinder n.o 3 was some 30% more restrictive than all others
at 320 H.p duty cycle was reduced to 87 %.
fuel rail pressure has since been increased but as i did not personally do the tune im not exaxtly sure of the current duty cycle.however in the tuners words .it should be safe for another 20 h.p and thats about all
as far as the turbo mods go the only component that was SLIGHTLY modified was the ceramic wheel it was replaced with a steel item of SIMILAR spec
the real gains are from the extrusion honing the exhaust housing was so heavily ported that its now 30% larger than the original.the exhaust manifold was also ported and ceramic coated .The reason the turbo is so effecient is the gains from porting the compressor housing and intake manifold
i asssume you meant to say the same as a normal st205 turbo
(NOT PICKING ON YOUR TYPO MY TYPING SUCKS)
perhaps you should check the link below
this clearly states quite a big differnce including the turbo .and the fact that the wrc IS A full second faster 0-100 IN STANDARD FORM
http://www.alltrac.net/specs/comparison.htm
should i mention the anti-lag(standard in wrc) or the injector sprays also standard
perhaps you should take your own advice
the vehicle in question ...NOTE MY CRESSIDA IN FRONT
look carefully under the gt4 badge it says GROUP A RALLYE
it also has an id plate on the console with a build no ## of i think 77 in AUST
http://home.kooee.com.au/celicamad/Picture_0363.jpg
again quoting the above link to alltrac an st205 WRC has 255h.p (st205 has 242) so thats about 173 h.p @ wheels .well we actaully got a figure of 181 so we are close to the claimed mark
we added 3 inch exhaust and cat mod ,cold air induction and 16 psi boost power figure rose to 225 h.p @ wheels as i said this has been varified
so the actual gain from turbo mods has only been 100 h.p @ wheels .But this is still a substantial gain considering the cost
i still have a few pics on the role of film with the before and after pics of the turbo .so when i finish it i'll get it developed and show the results
for those of you that are actualy interested in this mod
Finally if there is any doubt what so ever this vehicle IS competing in 1/8th mile drag racing at THE toyota nationals this year .
and previously won the go-to-whoa by a substantial amount
i have a 4.5 sec 0-100 car and i am SCARED ... VERY scared of this vehicle
you are more than welcome to take it on
it WILL have fitted at the time a dyno plus for 0-100 and 1/8 th mile and h.p readings
twinturbo1uz
melbourne
Re: Good new turbo to replace CT26 on 3SGTE Sun, 23 March 2003 08:36 Go to previous messageGo to next message
holy shit that power porting works awesome .on my old twin ct26 turbos .power porting the exhaust housings made 200 h.p at treads more .
believe this shit!!!! i have seen first hand the results of this process and celicamad would power port his radiator hoses given the chance
you really know your turbos man THANX AGAIN FOR ALL YOUR HELP WITHOUT YOU I WOULD NEVER HAVE CRACKED INTO THE 8 SECOND BARRIER
bergerac
Re: Good new turbo to replace CT26 on 3SGTE Tue, 25 March 2003 09:13 Go to previous messageGo to next message
Did you even read what I wrote?
If you could possibly make that much power I would happily pay you to work on my car, my problem is you make alot of claims that aren't possible or are incorrect and then abuse people for pointing it out. Show me some real proof and I wont bother you, actually I'd be quite impressed.
Quote:
using the factory 440 cc injectors and the standard manifold at 294 rwhp duty cycle was 90 % so we decide to extrude hone the intake manifold . the much smoother manifold allowed for less manifold wall quenching and faster air fuel flow . cylinder n.o 3 was some 30% more restrictive than all others at 320 H.p duty cycle was reduced to 87 %.
For a start ST205's have 540cc injectors stock. By getting more air in the cylinder you would need to add more fuel not less. How is it possible to the duty cycle to go down if you using more fuel?
Only Japanese ST205's have ceramic compressor wheels, all of the cars exported to other countries (including Australia) have steel wheels.
http://gtfour.supras.org.nz/Turbo%20photos.htm
Well that page is obviously wrong since there has never been a 3S-GTE engine with a CT12A turbo on it. The power figures are correct though. All Jap spec ST205's had 255hp, UK spec had 242hp and Australian delivered cars came with 239hp(178kw)
http://gtfour.supras.org.nz/pics/aug94h.jpg. If you can show me a stock Australian delivered car that can do 0-100 in 5.45sec then I will admit defeat.
Mines #22 thanks. Would you like to start throwing VIN numbers around too? Doesn't prove you've actually been under the bonnet of one of these. From what you've said it certainly doesn't sound like it.
Funny, in your earlier post you claimed the turbo was the only mod? Got a slip from an actual dyno?
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Tue, 25 March 2003 10:19 Go to previous messageGo to next message
whoops typo they are 540 cc injectors .
well obviously
ill send you the ceramic wheel from the turbo .obviuosly you have never pulled one apart .send me a P.O box or something
http://home.kooee.com.au/celicamad/dave%200-100.JPG
stock gt4(ST205 wrc) but with 3 inch exhaust ..the owner LOVES his car and wasnt game to REALLY launch it (didint want to break anything).so a few tenths quicker would be easy the car could easily handle another 2000 rpm on the launch
yeah there are 15 4 wheel drive dynos in newcastle ...ooops i mean NONE .ask about 30 or 40 people on this forum my dyno plus has proven to get EXACTLY the same figures as the toymods dyno
a dyno is far easier to give a wank figure on than a dyno plus
the following quote was my first post so i dont know where you got that shit from about the turbo being the only mod
This proves that you dont even know what extrusion honing EVEN IS.you are not effectivley adding MORE air the same amount of air has already passed through the throttle body .
you are Evening cylinder flow .the ecu will provide the same amount of fuel to each cylinder required to .complete the combustion cycle on the highest flowing cylinder
when you have EXACTLY equal runner flow .AND increasing overall flow to all runners .you can use the same amount of fuel to make more power .so if you use less fuel you will make the same power
So if 1 runner flows 28% less air than another then that cylinder WILL run ritch.so you are effectivly wasting fuel to that cylinder.(have you noticed how rich yours runs factory)
in any car simlpy by leaning out the mixtures you will increase power and decrease duty cycle .
do you know what manifold quenching is .and how more fuel can reach each cylinder in an unburnt state
if you dont undestand this basic shit then talk to the hand boy
ill send you a copy of the 1/4 mile time you can calculate h.p from the terminal speed with good accuracy that will satisfy you
Just because i dont know every gt4 ever built doesnt mean i dont know more abut engines than YOU have ever dreamt
if i where you id do some homework and find out WHAT i HAVE actually done before you embarras yourself any further
seems you just looking to appear as if you know heaps
gee im impressed
oh yeah and as far as helping you get similar results
BITE ME!!!!! i dont need to prove a thing to you little boy
[mikey]
Re: Good new turbo to replace CT26 on 3SGTE Tue, 25 March 2003 12:20 Go to previous messageGo to next message
Hmm.....
Extrusion honing is a process of forcing an abrasive substance through an orifice and opening it out, smoothing it internally in the process, this increases internal diameter and removes any possible turbulence causing casting flaws...yes it can improve air flow by improving induction efficiency. A CT20 is an utter piece of crap...I dont know why you would bother, sure it was great for rally, only because its response was reasonable and with the steel wheel they could push 1.5bar odd of boost through it, heat controlled by the intercooler and water injection. They designed it around response and powerband, these are useless for top end as the exhaust housing is simply too restrictive.
The problem with any CT2x is the wastegates are too small to cope with bypassing air around the turbine at high airflow levels (upwards of 35-40cfm) and cause boost spikes/surge, etc, and they restrict power.
If you're going to waste that much money, just buy a good second hand turbo, make an adaptor for the manifold, new dump pipe, ECU (which you can do for a reasonable amount, Apexi Power FC if you own an ST205), and injectors should be fine, larger fuel pump cause the standard ST205 pump won't cope.
Oh by the way, the only real similarity between the ST165 and ST205 engine is the fact it bares the 3SGTE code, bar nothing else. Even the 165 and 185 engines are vastly different, the 185 was a total makeover of the piece of crap they used in teh ST165 from 86-89 in the WRC, it had a world of problems as why revised it, and the ST205 is that of the ST185 which was good, but they found it still had its flaws so they improved on it again. The ST205 is almost the ultimate evolution of the 3SGTE.
Manifold wall quenching is when due to an interruption in the airstream the tumbling fuel mixture is disturbed and coats the manifold wall, usually in cooler conditions though as a hot manifold will cause fuel vaporisation...pretty basic, so to compensate for this you have to increase the injector pulse time in ms...
The idea of evening out air flow per runner is very good though, and will lessen the chances of leaning out or hydraulic'ing a certain cylinder under massive combustion pressures......but also fixing the piece of shit standard fuel rail can solve this problem, as it basically causes a pressure drop from number 1 to number 4 cylinders....
An increase in volumetric efficiency means for a larger amount of air you can use the same fuel as you would for a lesser amount under conditions of lower volumetric efficiency....
Celicamad grow up and respond like the adult I am sure you are, use properly formed paragraphs and correct punctuation, etc. You are making yourself look like another village idiot. You're an intelligent bloke, so act like one.
Regards,
Michael.
Re: Good new turbo to replace CT26 on 3SGTE Tue, 25 March 2003 12:29 Go to previous messageGo to next message
Now at least I can understand that post!
GEE120
Re: Good new turbo to replace CT26 on 3SGTE Tue, 25 March 2003 23:50 Go to previous messageGo to next message
celicamad wrote on Sun, 23 March 2003 00:22
Celicamad,
You are right in some areas but wrong or mislead in others. Im not say the figures you are quoting are not achievable.
One quick quesyion i have for you though is, why in gods name would you spend $2500 on the stock turbo to get 500Hp (i'm assuming its running 20-25PSI to make the 500Hp) when for the same money you could get a bigger turbo that would work more efficiently ie:a lot less heat.
Now getting on to the parts ive quoted you on:
Toyota did devlope a car for rally this was the ST205WRC the turbine wheel in this application was steel and not ceramic.
Only the Jap Spec ST205 had ceramic.
The ST205 WRC was raced in rally but only for 3/4 of 1 season because they were caught cheating by removing the 35mm restrictor.
IMHO i think this is why the ST205 did not become a cult car like the WRX it didnt get the right exposure in its time, although the price point is another reason.
The specs you listed from alltrac.net are incorrect. They need to be swapped arround. The WRC is 242Hp and the Jap is 255Hp. The reason for the difference in HP is the more aggresively tuned ECU in the Jap model, its tuned for 100 Octane.
The antilag you mention is standard on the WRC but it does not work, its blocked and just looks pretty, It can be made to work but the stock ECU does not control it so youll need an EMS.
The injector sprayers you mentioned are little jets that spray the intercooler radiator with water to help cool it better. Ive tried using these and they made shit all of a difference unless your using the antilag it doesnt get hot enough for the jet spray to have any real benefit.
On your Finally point. I know my ST205 WRC is not making the same power as this one but i would love to go up against it at the Nationals, just to see how we go. Hmmmm 2x ST250 WRC running down the 1/8 mile together.
One more quick question. I the car your talking about David's or somebody else?
Guest
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 00:23 Go to previous messageGo to next message
OK Enough !
It will all be sorted out at the NATS ~ whos got what and what works.
It will be plain to see - can someone please vid everything. Unfortunately i wont be there.
Matt
benmeyer
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 02:14 Go to previous messageGo to next message
I'm taking along my DV camera and filming what i can. I'm currently talking to phil eacott about the possibility of publishing the video that is taken.
[mikey]
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 04:31 Go to previous messageGo to next message
Actually Toyota did run the restrictors, but due to the way that the intake and restrictor was designed, it allowed more air flow into the turbo than the restrictors should have allowed. So they called it cheating and banned the Celica from the WRC. By the time it was allowed back, the rules stated a homologation production of min 2500 wasnt required, and only (i think) 50 or 100 had to be built to satisfy their requirements.
GEE120
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 04:41 Go to previous messageGo to next message
Thanks Mikey,
I stand corrected. I was close though. hehe
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 07:32 Go to previous messageGo to next message
if the figures on alltrck are wrong then so be it as i said i DO NOT claim to now all about gt4's
the engine at hand was disassembled components where assesed
however aftermarket turbos where originally considered .
but at $2800 for a gt series turbo was out of the budget
the actual turbo itself has only had $1500 spent on it .the other mods would have been needed even with a gt series 550 h.p turbo .
320 rwhp @17 psi was achieved on an st185 using the EXACT same turbo (built buy the same guy)
personally if it where my car id be looking at the gt roller .
particularly if the factory exhaust manifold can be used
i was given a car and a budget and asked to organise someone to do the work .considering the budget the results at the nats willl speak for themselves
as far as the anti-lag goes yes i am aware it is disconnected but the system is in place thesre are articles on the net about how to get it to work(which i havnt read) .BUT i would NEVER consider using anti-lag it is WAY too hard on turbos
and yes i accept that with a water to air system very little is to be gained .except where heat soak is concerned .having set up my own system before i found that even with a large volume of water if the car was driven hard on a hot day and allowed to sit .intake temps could be brought down MUCH quicker however no power gain was achieved( just a consideration for yourself)
as matt said lets sort it out on the drag strip
we will soon find out
does anyone have a formula for calculating h.p from terminal speed on 1/8th mile ???
if not we can put the dyno plus in a stock car and then the 205
just for point of interest mikey i havnt seen your entry form yet are you planning on entering ??
if so can you please get your form off ASAP entry's close on FRIDAY
[Updated on: Wed, 26 March 2003 07:42]
[mikey]
Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 11:40 Go to previous messageGo to next message
Celicamad,
Unfortunately not this year, I still don't have a license (its suspended until 1st may), and my car won't be finished in time..just gotta get a computer and do the piping for the turbo and such...parts won't arrive till late april from Japan (some gaskets and oil line fittings), so I can't really do a great deal till then...
I might still come along if I don't have any family commitments I'll know pretty soon.
Michael
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon10.gif  Re: Good new turbo to replace CT26 on 3SGTE Wed, 26 March 2003 22:42 Go to previous messageGo to next message
Hey Mikey. Since you're such a good friend of mine, I'll volunteer to drive your car... Only because you're such a good friend though...... Wink
Lucid
Toymods Club Secretary
Re: Good new turbo to replace CT26 on 3SGTE Thu, 27 March 2003 07:54 Go to previous messageGo to next message
I don't reckon you could handle the power Max! Razz Laughing
[mikey]
Re: Good new turbo to replace CT26 on 3SGTE Thu, 27 March 2003 09:23 Go to previous messageGo to next message
Well considering my car wont run properly past 3500rpm at the moment, its no point even thinking about it...LOL maybe next year eh =]
Michael
celicamad
newcastle
Re: Good new turbo to replace CT26 on 3SGTE Thu, 27 March 2003 10:56 Go to previous messageGo to next message
oh well hope to see you there anyway .perhaps i can organise a run in this car if you are keen
[mikey]
Re: Good new turbo to replace CT26 on 3SGTE Thu, 27 March 2003 11:31 Go to previous messageGo to next message
CM,
That sounds excellent, if I can make it I'll look forward to it.
Cheers!
Michael
Nark
Cabramatta, NSW
icon2.gif  Re: Good new turbo to replace CT26 on 3SGTE Thu, 27 March 2003 22:59 Go to previous messageGo to next message
Lucid wrote on Thu, 27 March 2003 18:54
This coming from someone who drives a shopping trolley.... Riiiight.... Twisted Evil
Lucid
Re: Good new turbo to replace CT26 on 3SGTE Fri, 28 March 2003 01:19 Go to previous messageGo to next message
No... This coming from someone who has already driven Mikey's "Shopping trolley" Cool
Nark
Cabramatta, NSW
Re: Good new turbo to replace CT26 on 3SGTE Fri, 28 March 2003 01:29 Go to previous message
Bastard... Skull - Mad
Previous Topic:order
Next Topic:Recommendations for sway/stabilzer bar.
Current Time: Sun Nov 1 13:21:17 UTC 2026
Total time taken to generate the page: 0.13263893127441 seconds
