Classifieds » Miscellaneous » Supra rotors 300mm with calipers
7M-Brisbane
Supra rotors 300mm with calipers Fri, 14 March 2003 12:35 Go to next message
I have the calipers and rotors from a Mk3 Supra for sale, located in Brisbane. Looking for $200neg the pair. Big brakes - we're talking 300mm Smile
AmperSand
Re: Supra rotors 300mm with calipers Sat, 15 March 2003 00:08 Go to previous messageGo to next message
Are the rotors new or used? if used, what condition?
7M-Brisbane
Re: Supra rotors 300mm with calipers Sat, 15 March 2003 02:49 Go to previous messageGo to next message
The rotors and calipers are second hand - as they came on my Supra half cut. The cut has under 95,000kms on it. The brakes have a small amount of surface rust (normal for brake rotors), so it's probably worth machining them.. generally costs $10-$15 per rotor. As far as I can tell the rotors are fine - there is certainly more meat on them than there is on the ones that are actually fitted to my Supra.
3S-GE_Man
Gold Coast
Re: Supra rotors 300mm with calipers Sun, 16 March 2003 11:42 Go to previous messageGo to next message
what they 4 piston calipers, and would they fit a ST162, 5 blot, 38mm off set. and the caliper wouldn't need that much to fit the ST162 right???????
Nezza Cool
TurboCelica
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 02:13 Go to previous messageGo to next message
If these sell and someone wants a second set, i have the same set up altho mine is $300 as they are new in box.
Good luck with the sale
cressman
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 08:10 Go to previous messageGo to next message
might be interested,did you mean acomplete setup? ie.2x300 mm vented rotors and 2x4piston calipers,brand new?
TurboCelica
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 09:39 Go to previous messageGo to next message
the calipers (MA70) are not new, the disks are
but this is almost sold (pending of the first deposit)
3S-GE_Man
Gold Coast
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 10:32 Go to previous messageGo to next message
sooo, like they fit ST162 celica, and what type of caliper are they (no. of piston's), and will they fit a 16in wheels as i plan to get, but not for ages. as me interested.
Nezza Cool
TurboCelica
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 11:13 Go to previous messageGo to next message
there the supra caliper but i dont think the will fit the celica will they?
altho they are 5 stud. I never thought of them for a st162
make sure before you get interested cos i'd hate to lead you down the wrong path
7M-Brisbane
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 21:48 Go to previous messageGo to next message
Any of the Mk3 Supra brakes (as I have for sale) are actually large single piston units. The four spot calipers are only on the late late late late late model Mk4 Supras (I believe post 95?).
Keep in mind the Mk3 brakes are designed to pull up a barge arse Supra so they'd probably go pretty well on a Celica.
I would suggest that they are not a bolt-on conversion ( doubt it anyway), but it's just a matter of getting a bracket made up for the caliper... as for the rotors I'm not sure but you'd probably be able to fandangle an adapter of some sort too.
7M-Brisbane
Re: Supra rotors 300mm with calipers Mon, 17 March 2003 21:50 Go to previous message
Oh, and as for the wheels question.. a Mk3 comes with 16's from the factory so I'd say they'd fit no dramas under your new 16's.
Previous Topic:Set of 4 DUNLOP 205/65R15 94V SP SPORT 300E
Next Topic:wrecking sprinter
Current Time: Thu Nov 19 07:46:16 UTC 2026
Total time taken to generate the page: 0.0062777996063232 seconds
