Toymods » Tech & Conversions » Removing 2T flywheel
Removing 2T flywheel Sat, 15 March 2003 05:01 Go to next message
Anyone got any tips for removing a 2T flywheel? Or even if someone can come over and lend me a helping hand? I'll give you a beer Very Happy
shinzui
Re: Removing 2T flywheel Sat, 15 March 2003 05:05 Go to previous messageGo to next message
Mate, I'd love to help but I am having troubles removing the flywheel on my 18R/C Smile
If you work out how to do it, it'd be great to find out how, in case the same tips/ideas apply Smile
Re: Removing 2T flywheel Sat, 15 March 2003 05:11 Go to previous messageGo to next message
You undo the bolts and the flywheel comes off... how's that for a tip? Or am I missing something?
I think a rattle gun would be very handy! Or another person with a 1/5inch 17mm socket and flex handle!
Bugman
Re: Removing 2T flywheel Sat, 15 March 2003 05:12 Go to previous messageGo to next message
get a 5m pole.
Re: Removing 2T flywheel Sat, 15 March 2003 05:15 Go to previous messageGo to next message
Hey norbie, it sounds like you have done this before so how bout you come around and give a hand Smile
munki
Gold Coast
Re: Removing 2T flywheel Sat, 15 March 2003 05:40 Go to previous messageGo to next message
put the car on a stand and use your body weight to undo them.
Re: Removing 2T flywheel Sat, 15 March 2003 05:43 Go to previous messageGo to next message
And how do you stop the crank from turning?
juzzo84
Hornsby, N.S.W
Re: Removing 2T flywheel Sat, 15 March 2003 06:19 Go to previous messageGo to next message
ha ha, let the king of the 2t tell you how to do it!!!
get one of the gearbox bolts and bolt it into where it would go, then hold a flat blade skrew driver against the bolt and push it between the teeth on the flywheel and you have got your answer to stop the spinning crank problem.
not a prob gald i could help Very Happy
justin
the home mechanic
Re: Removing 2T flywheel Sat, 15 March 2003 08:06 Go to previous messageGo to next message
Well I got the flywheel off!!! Now how do I get the bearing out of the crank?
juzzo84
Hornsby, N.S.W
Re: Removing 2T flywheel Sat, 15 March 2003 21:53 Go to previous messageGo to next message
ha ha Rolling Eyes
um cant help you with that one!!!!!
justin
Re: Removing 2T flywheel Sun, 16 March 2003 00:56 Go to previous messageGo to next message
Couple of ways.
My favorite (and easiest IMHO) is to get a slide hammer with a hook attachment and pull (by bashing) it out.
The 'classic' way is to pack the space behind the spigot bearing with grease. Then fashion a rod that is exactly the same diameter as the inside of the bearing. Poke rod thru inside of bearing and bash with large hammer. The theory is that grease (being non compressible) will push the bearing out. Tried it once and it was a whole lot of fucking around to no avail. Other folk swear by it. I obviously must have done something wrong!
Re: Removing 2T flywheel Sun, 16 March 2003 01:18 Go to previous messageGo to next message
So I have to buy me a slide hammer?? Hmm ok.
inferno
Re: Removing 2T flywheel Sun, 16 March 2003 14:19 Go to previous messageGo to next message
goodluck getting that sucker out!! i would suggest if the bearing has gone, buy a new engine Laughing
keep us informed how you get it out because i still have to swap the bearing in my engine, i gave up after 3hrs.
Grega
melbourne.victoria.austra...
Re: Removing 2T flywheel Sun, 16 March 2003 20:01 Go to previous messageGo to next message
two words : slide hammer
re: getting the flywheel off, i put my multigrips on the bastard and undid using a socket and air impact ratchet - worked ace!
Re: Removing 2T flywheel Sun, 16 March 2003 20:49 Go to previous messageGo to next message
Inferno, the bearing has been smashed! Its just the outer casing thats stuck in there now!
Re: Removing 2T flywheel Mon, 17 March 2003 01:09 Go to previous messageGo to next message
Shane, sounds like you definitely need a slide hammer. If you had eternal patience you could use a Dremel to grind out the casing.
I suggest you HIRE a slide hammer dude Cool. However, a slide hammer is damn handy and a reasonable one will set you back about $150.
Cheers Dave.
PS. A good way to stop the flywheel from turning is to bolt a bit of chain from one of the pressure plate holes to a bellhousing hole. None of this nonsense with big screwdrivers and jamming it into the ring gear (which works but almost always results in skinned knuckles).
[Updated on: Mon, 17 March 2003 01:13]
Re: Removing 2T flywheel Mon, 17 March 2003 06:59 Go to previous messageGo to next message
To stop the flywheel from turning, I made a jig that slotted through one of the bellhousing bolt holes then bolted to one of pressure plate bolt holes on the flywheel!
BigBadBenny
Brisbane, Queensland
Re: Removing 2T flywheel Mon, 17 March 2003 09:32 Go to previous messageGo to next message
the bearing?
I asume you mean the spigot bearing, little small one in the end of the crank that the g'box shaft goes into?
Easy, pick up a spigot bearing remover, attach to bearing, wind remover untill bearing is out, should take you all of 10 seconds.
Oh you don't have a bearing remover?.. it's ok neither do I, I just use the workshop's one. Very Happy
Just go and buy one, I would expect to pay around $40. for a cheap one.
Hope that is of some help.
Benny Smile
Re: Removing 2T flywheel Mon, 17 March 2003 09:50 Go to previous messageGo to next message
Ok so what the hell does a spigot bearing remover look like?
BigBadBenny
Re: Removing 2T flywheel Mon, 17 March 2003 10:32 Go to previous messageGo to next message
looks like a horse shoe but with a bolt through the middle and a hook on the end of the bolt.
Re: Removing 2T flywheel Tue, 18 March 2003 10:48 Go to previous messageGo to next message
So who has a slide hammer or something I can remove this broken bearing with? I need to get this done asap and i'm having trouble finding something to do the job!
Pleeeesssssse help Crying or Very Sad
Re: Removing 2T flywheel Tue, 18 March 2003 11:01 Go to previous messageGo to next message
I do, but I'm 2000 km away. FFS, just hire one! Laughing
Re: Removing 2T flywheel Wed, 19 March 2003 06:45 Go to previous messageGo to next message
Ok now I have the old bearing removed, where does the new bearing sit? Does it sit just in the end of the crank or does it get pushed all the down to the back?
Hope that makes sense Confused
Re: Removing 2T flywheel Wed, 19 March 2003 10:18 Go to previous messageGo to next message
Get a socket that is the same diameter as the outer race. Put bearing in hole and gently drive it home with socket and hammer.
Re: Removing 2T flywheel Wed, 19 March 2003 10:26 Go to previous messageGo to next message
But is it meant to go all the way in?
Re: Removing 2T flywheel Wed, 19 March 2003 11:51 Go to previous messageGo to next message
If you look at the hole, you will see it tapers at the bottom. The bearing will come to rest here.
Re: Removing 2T flywheel Wed, 19 March 2003 11:52 Go to previous messageGo to next message
Ok. There is a sholder at the bottom! I was just wondering if it should go hard up against that?
Re: Removing 2T flywheel Wed, 19 March 2003 12:14 Go to previous messageGo to next message
Yep, to the shoulder will be fine.
Re: Removing 2T flywheel Wed, 19 March 2003 12:30 Go to previous messageGo to next message
Sweet thanks Very Happy
Re: Removing 2T flywheel Wed, 19 March 2003 23:42 Go to previous messageGo to next message
Anyone know the part number for the spigot bearing for the 2T?
Re: Removing 2T flywheel Thu, 20 March 2003 00:42 Go to previous messageGo to next message
Argh....do I have to help you with everything?
Measure the crank hole diameter and the inner diameter of old bearing (or diameter of th bit of input shaft that fits in there. Go to any bearing shop and ask for a spigot bearing with those dimensions. Expect to pay no more than $5.
Re: Removing 2T flywheel Thu, 20 March 2003 06:37 Go to previous messageGo to next message
I could of done that, but I was at work and the engine was at home!
And what made things worse is the fact that every bearing shop I rang gave me a part number for a bearing that doesnt fit!
Doesnt matter now anyway cause I found the correct part number!
BigBadBenny
Re: Removing 2T flywheel Thu, 20 March 2003 08:03 Go to previous messageGo to next message
thats why you always get the number of the old bearing before you hack it to peices, I do this for any bearing or seal I replace.
Re: Removing 2T flywheel Thu, 20 March 2003 08:42 Go to previous messageGo to next message
Easier said than done mate! The bearing was smashed! It was only the outer case left!
Re: Removing 2T flywheel Thu, 20 March 2003 11:48 Go to previous messageGo to next message
Shane, now you have to do something for me:
Explain your sig.
Re: Removing 2T flywheel Thu, 20 March 2003 11:50 Go to previous message
Laughing
Its from a Redhat newsletter! You can email Shadowman and ask questions or whatever! And somebody asked "Is there a URL on the Red Hat Network that I can point IE on a Windows box at to automatically reformat and install Red Hat Linux?"
And Shadowman replied with: Yes, but Shadowman will not tell you, because your Mommy will be very angry if you do that to her computer.
Just something I found funny. Thats all Smile
[Updated on: Thu, 20 March 2003 11:51]
Previous Topic:Where to go for a General Service on a Mark IV Supra?
Next Topic:Heater Valve
Current Time: Sat Oct 31 00:22:38 UTC 2026
Total time taken to generate the page: 0.11025404930115 seconds
