Toymods » Tech & Conversions » Does anyone have Air/Con on an 18RG
Blaze
Does anyone have Air/Con on an 18RG Sat, 15 March 2003 11:27 Go to next message
Hi guys,
(and Gals)
I am hoping that there is someone out there that has Air Con on and 18RG engine. What I am interested in is where the compressor goes and what the bracket looks like. If someones does have this set up could you please take a picture of it so I can see what I have to get. Or what sort of a bracket I need to get made up for me.
TA22-3SGTE
MACKAY
Re: Does anyone have Air/Con on an 18RG Sat, 15 March 2003 12:57 Go to previous messageGo to next message
I had the bracket and compressor years ago still might be in the shed somewhere , I will have a look tomorrow , The compressor sits high on the left side of the motor.
Trevor
Re: Does anyone have Air/Con on an 18RG Sun, 16 March 2003 03:26 Go to previous messageGo to next message
I have a bracket, but no compressor. It bolts to the cylinder head on the exhaust side.
Re: Does anyone have Air/Con on an 18RG Sun, 16 March 2003 07:05 Go to previous messageGo to next message
yes, i have the compressor and bracket, but i am going to use them myself of course Smile
here's a pic i found with air con fitted
http://groups.msn.com/_Secure/0UgCkA0sYB!gr4ogpFpntv471!Ij!SYqBRfBuVz7piJFsODIRpmySv9FI4STV7Wd4WwUi21qK2EyyNWtuaJuEhU123IRSLFrw8VVROeWPse6PUOKO!miVtuNJueo5asg9/s18rge,-with-air-con.jpg?dc=4675398442839363907
my compressor:
http://groups.msn.com/_Secure/0VAChBCcZHDJz03949dG2TzQopZH4hzPeeWJxnc4FLm5uBvi6092r*TQVn6IJnuAsecadpzqJSGB8xWfE6YgmEy*fmGa1tXldjcwt1u6NRed3uDl!IB*ZbII0zSlZY3oi/air-con-compressor-001.jpg?dc=4675413706707686925
http://groups.msn.com/_Secure/0VAD7AigZUzJz03949dG2TzQopZH4hzPeeWJxnc4FLm4nKoTY4hR2E7nMl3BXLh2rk5*OG4V5jywZ5t5U!TpQzeObK5Mv!GUl5UEta!z9MM9zwEnOUGOdoaJ29U54MJrk/air-con-compressor-002.jpg?dc=4675413706911751956
Blaze
Re: Does anyone have Air/Con on an 18RG Sun, 16 March 2003 10:58 Go to previous messageGo to next message
I have the 18r-c compressor. I don't see any reason why I can't use this. If there is a problem with this can soemone tell me what it is. I can always get the brackets modified.
Re: Does anyone have Air/Con on an 18RG Sun, 16 March 2003 11:23 Go to previous messageGo to next message
The 18R-C compressor is not at all compatible with the 18R-G bracket (I've tried it). Of course if you want to get the bracket modified anything is possible.
Re: Does anyone have Air/Con on an 18RG Sun, 16 March 2003 11:27 Go to previous messageGo to next message
It should fit (the 18R-C compressor that is).
Those extended mounting points (in THE WITZL's pics) look very much like the one on a compressor i got from the Toyota section at ABC wreckers (oxley) - and my dead compressor (leaking front seal).
You might have to find different shaped/pointing connections as the 18RC ones are setup for pipes coming from two directions?
Blaze
Re: Does anyone have Air/Con on an 18RG Mon, 17 March 2003 01:22 Go to previous message
Can some one that has one of these compressors tell me what model number or part number that it is. Is there some sort of code on it. I might be able to find another one that will fit. It looks similar to one that is on a cressida.
Previous Topic:Throttle Body conversion for 2TGEU
Next Topic:7MGTE AFM Dimensions
Current Time: Fri Nov 20 08:16:42 UTC 2026
Total time taken to generate the page: 0.0090792179107666 seconds
