Toymods » Tech & Conversions » 3SGE & Supra 5spd
mangopickel
icon9.gif  3SGE & Supra 5spd Mon, 17 March 2003 07:52 Go to next message
Does any one have a 3SGE set up coupled with a Supra 5spd??
If so, i'd be interested to find out what kinda flywheel you used and how you put it together??
I'm currently facing a bit of a pickel with mine.... i'd appreciate any advise!!
O
Re: 3SGE & Supra 5spd Mon, 17 March 2003 08:09 Go to previous messageGo to next message
Well you can either use a custom bellhousing and flywheel or use a shortened 2s bellhousing and the standard flywheel!
CelicaRA45
nth ringwood, Victoria
Re: 3SGE & Supra 5spd Mon, 17 March 2003 09:41 Go to previous messageGo to next message
i have 2 altezzas 3sge engines bolted to supra 5speeds whats your problem you are having with it
crazyracer
Re: 3SGE & Supra 5spd Mon, 17 March 2003 12:11 Go to previous messageGo to next message
It depends what generation of 3SGE you have.
If its a gen1 you can just use the standard flywheel that came with it (assuming its a manual).
Anything later than that and you are going to have to get a custom flywheel made.
You'll most likely have to shave about 5-6mm from the bellhousing to get the input shaft to locate properly in the spigot bearing (which you will have to source separately too). There were a couple of articles available on the net that described some of the basics of making a 3SGE RWD, but I'm not sure if they are still around.
Leave me a message if you need more info.
Re: 3SGE & Supra 5spd Mon, 17 March 2003 12:22 Go to previous messageGo to next message
It also has been said elsewhere before on these forums that using the shortened bellhousing causing problems with the clutch!
[Updated on: Mon, 17 March 2003 12:23]
mangopickel
Re: 3SGE & Supra 5spd Mon, 17 March 2003 22:08 Go to previous messageGo to next message
I think the dude that put my car together used a custum bell housing and modified the sandwhich plate and chucked a gt4 group A rally flywheel! The only thing is that it engages from the wrong side and its chewing up my flywheel!!
It such a pain in the ass!!
Thanks for your help!!
O
CelicaRA45
Re: 3SGE & Supra 5spd Tue, 18 March 2003 06:33 Go to previous messageGo to next message
your in melb im in the eastern suburbs if you get stuck i can look at it for you what car are we talking about any way .my mobile is 0412 045 467 later glenn
mangopickel
icon10.gif  Re: 3SGE & Supra 5spd Tue, 18 March 2003 06:47 Go to previous messageGo to next message
I've got a TA23 celica that looks pretty standard, however the engine and gearbox and a few little odds and ends are modified.
I've been talking to Toyospares in Bayswater who've helped shed a bit of light on it for me, but thanks for the offer of taking a look at it for me!! Much appreciated!!
I might give you a buzz later on the is week if its cool!!
My celica's currently up on a hoist in Keysborough!!
Owen
crazyracer
Re: 3SGE & Supra 5spd Tue, 18 March 2003 12:31 Go to previous message
Both a friend and I have shaved the gearbox and encountered no problems with the clutch engaging or disengaging.
As for the gt4 flywheel, I had an alloy made made for someone and it was much bigger in diameter than what I needed for the RWD setup. You would have to turn a lot off it and then I'm not sure that there would be enough meat on there to hold the ring gear.
Previous Topic:Supra 5spd shifters & speedo drive
Next Topic:coil over convertion
Current Time: Wed Nov 18 13:46:01 UTC 2026
Total time taken to generate the page: 0.04289698600769 seconds
