Toymods » Tech & Conversions » 1jz problems, need help
Majik16106
Atlanta, Ga, USA
1jz problems, need help Tue, 18 March 2003 05:15 Go to next message
Here is the story symptoms. Car starts, idles with a little bit of a miss, but nothing huge, rev it up, at 3000ish rpm is kicks back like a fuel cut, wont rev past. To solve this problem we ran a jumper wire in the Diagnostic box from the fuel pump to the positive power terminal. Car revved all the way up, but it ran pretty rich, Anyway finally melted my catylitic converter, so we gutted it, now it ran REALLY rich, after about a week it became hard to start, one morning it flooded, fouled out the plugs, does that now almost all the time. I can drive it around on new plugs, but once i park it, the next morning its dead, and it will hit fuel cut at 3k still with the jumper wire removed. Pulled codes, most importantly it ran the Map sensor code and the front knock sensor, My car is NOT knocking so it must be the sensor, I replaced the Map with a Boost Pressure sensor from a 94 supra turbo, havnt done the knock just yet but they Map didnt really fix anything. Also the car changes its idle state after about 2 min, like cold start shuts off or something and it sounds different. The harness for the car was made by Mike Urbano here in the states, who has done a few of these swaps, If it makes a difference, He actually makes a 7mgte harness fit the 1jz engine. Can anyone help me, any idea?
BlackSupra
Re: 1jz problems, need help Tue, 18 March 2003 08:38 Go to previous messageGo to next message
Im sure draven will tell you it sounds like its running in limp mode. Boost will also be retarded no doubt.
Are you running the auto ECU with auto gearbox?
Majik16106
Atlanta, Ga, USA
Re: 1jz problems, need help Tue, 18 March 2003 14:01 Go to previous messageGo to next message
No, its a manual with a manual ECU. The clip and the original car were both 5spd cars. What's Limp mode? Maybe something i know but you guys might call it something different, never heard that term.
HedgehogSandwich
UK
Re: 1jz problems, need help Tue, 18 March 2003 18:43 Go to previous messageGo to next message
For a start you cant run the MAP from a 94 supra on a stock 1JZ, its too big. the 94 supra map runs at 1.3 bar, where the 1JZ map runs at 1 bar, so you're running 30% lean.
It certainly sounds like your map was the problem, and now youve replaced it with the wrong one. Get the proper map and try it again.
[Updated on: Tue, 18 March 2003 18:44]
Majik16106
Atlanta, Ga, USA
Re: 1jz problems, need help Tue, 18 March 2003 18:48 Go to previous messageGo to next message
yah, i can tell you with the new Map and 440cc injectors, im 100% sure its not running lean, if you saw my post, its flooding its so rich.
HedgehogSandwich
UK
Re: 1jz problems, need help Tue, 18 March 2003 19:39 Go to previous messageGo to next message
sorry majik, didnt realise you were running the 440's as well.
Majik16106
Atlanta, Ga, USA
Re: 1jz problems, need help Wed, 19 March 2003 02:07 Go to previous messageGo to next message
c'mon any ideas? I really am at a stand still... is it possible the ECU is fried?
BlackSupra
Re: 1jz problems, need help Wed, 19 March 2003 06:10 Go to previous messageGo to next message
'Limp home mode'
where something is wrong somewhere in the system and the ecu accounts for this by upping the fuel, dropping boost and fouling spark plugs!
have you run the ecu for any codes?
Majik16106
Atlanta, Ga, USA
Re: 1jz problems, need help Wed, 19 March 2003 14:53 Go to previous messageGo to next message
well the car is hitting the fuel cut in neutral, out of of gear, so its not a boost cut, with the jumper plugged in i can get the full 15 pounds my boost controller is set at. the only important codes were the map sensor and knock sensor, but i replaced both of those, and all the grounds and everythign are fine.
Majik16106
Atlanta, Ga, USA
Re: 1jz problems, need help Wed, 19 March 2003 14:54 Go to previous messageGo to next message
oh, and if it makes any difference, there are two relays under my dash that keep clicking.
HedgehogSandwich
UK
Re: 1jz problems, need help Wed, 19 March 2003 23:04 Go to previous message
clear your codes and check again.
Previous Topic:Oil and spark plugs for MK2 supra
Next Topic:4age idling problem
Current Time: Wed Nov 18 21:38:29 UTC 2026
Total time taken to generate the page: 0.026507139205933 seconds
