Classifieds » Parts Wanted » 1G-GTE driveline components
RA28
1G-GTE driveline components Sun, 16 June 2002 11:27 Go to next message
I need a flywheel, clutch, pressureplate and bellhousing from a 1GGTE. I also could do with a W57 or W58 cause mine is stuffed (and it's on a 18r-c so wrong bellhousing).
I could do with just the flywheel and bellhousing because I should be able to get the clutch plate and the pressure plate from any parts supplier right??
Any one that can help drop me a line
timscool@optusnet.com.au
Tim.
Dylo
Re: 1G-GTE driveline components Sun, 16 June 2002 14:28 Go to previous messageGo to next message
For my 1GGTE conversion i did this:
I used a 1J pressure plate, all that had to be done is to drill the locating holes out by about 2mm.
Also used an 18R flywheel, it fits straight on and it is about 2Kg LIGHTER, so bonus Wink
As for a clutch, i got some heavy duty version of a hilux clutch. havent driven the car much yet so i cant report on the clutch as yet, but seemed fine around the block a few times!
Dont exactly know what your doing, but this should hopefully simplify things...
Grant
Newcastle, NSW, Australia
Re: 1G-GTE driveline components Mon, 17 June 2002 21:50 Go to previous messageGo to next message
I think I have a genuine low km 1GGTE clutch and pressure plate lying around. I'll check and get back to you.
Grant
1G-GTE Clutch Wed, 19 June 2002 22:14 Go to previous message
Tim,
if you're interested I do have a 1GGTE 9.5" clutch and pressure plate. Came from a low km engine. No scoring on pressure plate and clutch plate plenty of life left.
$100 + freight.
Phone 0409 572904 or email me.
Grant
Previous Topic:AFM 2TG!!!
Next Topic:Weber x 2 48mm DCOE
Current Time: Fri Nov 20 23:49:50 UTC 2026
Total time taken to generate the page: 0.0052261352539062 seconds
